Technical Inverted Flare Adaptor Needed!
Discussion in 'The Hokey Ass Message Board' started by Crazy Steve, Mar 15, 2019.
  1. Yep, that says it's what I need... the local store says they have one, here's hoping! Thanks!
    gimpyshotrods, scotty t and Blue One like this.
  2. john walker
    john walker
    I used these for a clean brake line attachment to a master cylinder, but might work in other apps too. just another form of a flare nut.
  3. Beanscoot
    Beanscoot
    Scotty T's piece interchanges with Weatherhead 7916.
  4. Several interesting ideas... I have given some thought to just getting a 3/8" tube inverted plug and drilling/chamfering it for 5/16" tube, but I do have concerns about the mismatch between flare diameters. I won't get a full 'bite' on the smaller flare in the larger fitting, I don't want any possibility of leaks.
  5. Hnstray
    Hnstray
    from Quincy, IL
    I understand your concern....the br*** adapter would seem to best address that issue and is minimally con****uous. The kind of thing most observers would not even notice much less fixate on. But, you do have to worry about the ‘nut’ behind the wheel....:D
    pprather and scotty t like this.
  6. I wasn't thinking very clear yesterday or I would have asked you if you were aware that 3/8" fuel line will actually slid over 5/16" line. Several times I've double flared a piece of 3/8" tube and cut it the exact length of the line nut, put it in the nut slid it over the 5/16" and do a single flare to the 5/16 line to get a little overlap onto the 3/8" flare. Seems to work fine so far and the line nut spins just fine.
    Hnstray likes this.
  7. Edelman br*** part number 258650 should fix it.Try a real parts store like NAPA.
    This is the 5/16" version
    scotty t likes this.
  9. That was it (without seeing it in person I tend to be skeptical...LOL) and miracle of miracles, the on-line computer wasn't lying about it being in stock, they actually had it. And if I hadn't had the part number, the sales guy would not have been able to find it either... LOLOL
    Thanks Scotty!
    scotty t and saltflats like this.
  10. Glad I could help.I was running some fuel lines recently so the search was still fresh in my mind.
  11. BamaMav
    BamaMav
    from Berry, AL
    Cool. Now I need to get one for myself.
  12. And just in case your local AutoZone doesn't have one, two other part numbers: Edelmann 258560 and Weatherhead 7916. Dorman apparently doesn't make one...
