Technical Ford -34 Windshield frame
Discussion in 'The Hokey Ass Message Board' started by fordor, Mar 16, 2019.
  1. fordor
    fordor
    from Finland
    I need to get a new windshield gl*** in the frame. What is the right way to di***embly the frame to get the gl*** in?
    Can someone help me before i broke something!!
    Greetings from Finland
  2. alchemy
    alchemy
    In each bottom corner there are L brackets inside the frame tube. These brackets have four small screws holding them in, and you remove the small screws on the sides to slide the bottom of the frame away from the upper portion.
    Note that these screws are probably very rusty, and might not come out easily. I bet more of them have been drilled out than removed as Henry intended. You might need to drill and then fish out the remainder when it's all apart. Or maybe even make new L brackets.
    clem and fordor like this.
  3. Dirk35
    Dirk35
    This....exactly. Pull the hinges off from the top and separate the windshield frame from the header, you'll see the screws Alchemy is talking about.
  4. fordor
    fordor
    from Finland
    Thank you alchemy.
    The frame is now separated, and yes i have to fabricate new L-brackets and fix some rust issues......
    Peter
