Projects Young blood builds an AV8 (New England)
Discussion in 'The Hokey Ass Message Board' started by Travis latour, Mar 17, 2019.
  1. Travis latour
    Travis latour
    from Putnam CT
    What’s going on guys. I’m an avid browser and figured I’d put my project up here since it’s on its way. (Slowly)
    Current State of Affairs:
    Picking up the motor in my “truck” lol
    Nice 29 ch***is all loaded up in the back of my buddy’s van
    My wife “helping out”
  2. adam401
    adam401
    Nice looks like you've got most of the big stuff. Now the real work starts. Good luck seems like a good start.
  3. Travis latour
    Travis latour
    from Putnam CT
    Thanks Adam. In the process of moving to a new house and setting up the garage. Once that’s done I’ll be working on it more
    Stogy and wood remover like this.
  4. roseville carl
    roseville carl
  5. hoodwinx454
    hoodwinx454
    Looks like your off to a good start can’t wait to see it finished
    Travis latour likes this.
  6. harleyjohn45
    harleyjohn45
    Looks like you are using a 29 frame, the V8 is heavier than the 4 banger, you may need to box the frame. What do you plan for brakes? have fun
  7. GordonC
    GordonC
    Looks like a great start to a fun car!
  8. Ziggster
    Ziggster
    Looking good. It wasn't that long ago when I brought my flathead home in the back of my Subaru wagon. The machinist should be done soon I hope.
    I just noticed that it seems the oil return line from the filter canister appears to be plumbed into the cam gear cover. I had a question on that in another thread and it seems it should be plumbed from the cover to the intake as it is the vacuum brake signal for the dizzy. Just curious, is it plumbed as I stated?
  9. Travis latour
    Travis latour
    from Putnam CT
    Thanks! Haven’t looked into boxing the frame yet. Is it needed? I’m new to hot rodding. Brakes I have 40 ford juice brakes for the front, haven’t acquired rears yet, probably do the same.
  10. Travis latour
    Travis latour
    from Putnam CT
    Ill have to check it out, haven’t looked too closely at it as I am in the parts collecting phase. I’ll get back to you on that.
  11. dwollam
    dwollam
    Frame doesn't need boxed for a flathead V/8. Thousands of them done without it. My avatar was done in 1958 and still running, no boxing.
    Dave
  12. LSJUNIPER
    LSJUNIPER
    from ct
    Nice project, its good to have the wife onboard too.
    Stogy, flatheadpete and Travis latour like this.
  13. patmanta
    patmanta
    from Woburn, MA
    I found that the weight of the FH made my frame sag slightly, maybe 1/16th or so, that was corrected when I added some simple boxing just with some 4" x 1/8" flat stock.
  14. dwollam
    dwollam
    All stock Model A's have frame sag and need to be straightened during restorations/hot rod builds. Just the nature of the beasts from many years of horrible old roads. I arch mine ever so slightly so they are flat when ***embled. They bend at the firewall/steering box hole area.
    Dave
    ratrodrodder, Tim and Travis latour like this.
  15. Atwater Mike
    Atwater Mike
    Good that you mention this, Dave... I have straightened many that were bent, some were customers' builds...on already ***embled cars I'd use floor tie-downs, but hated that 'patch' type slipshod repair. I'd say every one was bent at least slightly.
    lothiandon1940 and Travis latour like this.
  16. alanp561
    alanp561
    Cover to the intake, yes. Just a question, when you're finished building YOUR WIFE"S CAR, what are you going to drive?;)
  17. Travis latour
    Travis latour
    from Putnam CT
    34 ford coupe
    patmanta likes this.
  18. Travis latour
    Travis latour
    from Putnam CT
    Thanks for all the great info. I thinking to make something that would bolt on to stiffen up possibly?
  19. patmanta
    patmanta
    from Woburn, MA
    Are you intimidated by the welding?
    The only thing I can think of that would bolt in is the inner channel boxing plates that Code 504 makes. I have a set but decided to go a different way. They are essentially smaller frame rails that sleeve into a model A frame. They COULD be bolted in but you're probably still going to end up doing some cutting and welding elsewhere. BUT, I suppose you COULD get a set and cut them to fit in and around things and then bolt them in with brackets for the crossmembers.
    I would advise you to figure out how you're going to mount your transmission, steering, and pedals first before going too far down this particular rabbit hole though.
    https://www.jalopyjournal.com/forum/threads/model-a-inner-channel-boxing-plates.962191/
  20. Travis latour
    Travis latour
    from Putnam CT
    True true I have a lot of thinking before that.
    No not afraid of welding at all. Just don’t want to ruin a perfectly nice a frame. It’s immaculate.
  21. patmanta
    patmanta
    from Woburn, MA
    If by "ruin" the frame you mean modify it, you're going to want to put the stock A engine and trans in there. Putting a flathead V8, its transmission, and juice brakes will necessitate modifications.
    Have you read this book yet?
    How to Build a Traditional Ford Hot Rod (Motorbooks Workshop) by Mike Bishop
    ratrodrodder, pitman and 48fordnut like this.
  22. Stooge
    Stooge
    Looks like a fun project and cool to see another New Englander! I don't have any strong feeling one way or another on if boxing is necessary and there are lots of unboxed frames with v8s out there, but if I had the car all apart, I would probably be inclined to box it.
    sub'd
    LSJUNIPER, patmanta and Travis latour like this.
  23. flatheadpete
    flatheadpete
    from Burton, MI
    Looks like you have a handle on a great project. And I'll second that it's awesome your wife is involved.
  24. Travis latour
    Travis latour
    from Putnam CT
    I don’t know what I’m doing yet I guess is what I’m getting at haha
    I have not I’ll go buy it. Thanks for the recommendation!
    lothiandon1940 and patmanta like this.
  25. patmanta
    patmanta
    from Woburn, MA
    Sure thing. It won't give you all the answers specific to your build but it will get you pretty far.
    You should hit the Fitchburg swap meet coming up on April 28th. It's a big one.
    https://www.jalopyjournal.com/forum...itchburg-swap-meet-and-car-show-2019.1138204/
    https://www.facebook.com/events/2213112132085991/
    The Ty-Rods swap at Stafford is coming up too (actually sooner) on the 14th.
    https://www.staffordmotorspeedway.com/event/33rd-annual-spring-ty-rods-auto-swap-meet-april-14-2019/
  26. Travis latour
    Travis latour
    from Putnam CT
    Sold the fibergl*** body...... now on the lookout for some real steel. Or a better gl*** body..... but preferably steel.
    I don’t want this thread to die so here’s a picture of the drivetrain I currently have. I have a 37 rear I have my eyes on from my new found buddy Bob! And some other goodies....
    Stogy, Stooge, patmanta and 1 other person like this.
  27. patmanta
    patmanta
    from Woburn, MA
    That Model A rear end will get you going fine as long as you don't put a lot of meat on those wheels or grunt in the engine... or dump the clutch too bad. I wouldn't let that slow down the build too much. New England is thick with V8 banjo rears though. I've got like 5 of them and my pile isn't all that big or old.
    Millworks carries locally made spring hanger conversions https://www.millworkshotrod.com/collections/suspension made by Old Yankee Speed Shop http://www.oldyankeespeed.com/about.html that you'd just need the right spring for on a wider rear end.
  28. Travis latour
    Travis latour
    from Putnam CT
    Wow did not even know about millworks, thanks for the recommendation!
    Stogy, lothiandon1940 and patmanta like this.
  29. patmanta
    patmanta
    from Woburn, MA
    Yeah, man, there's more going on in New England than a lot of folks would suspect!
