Hot Rods Hot Rod Sports Cars
Discussion in 'The Hokey Ass Message Board' started by ghornbostel, Dec 27, 2014.
  1. blowby
    blowby
    from Nicasio Ca
    Nothing says "Put the engine here, the wheels there..oh and stuff a coupe ****pit back there somewhere" like a Cheetah. Love 'em.
    scott27, dana barlow and loudbang like this.
  2. Offset
    Offset
    from Canada
    Roo, Art looks like he is stuffed into that cage with no room to spare.
  3. rooman
    rooman
    Art built a lot of transmissions for race cars (including this one) but this is not him
    Roo
  4. oj
    oj
    bv
    I worked on one of these that had the twin paxton cammer engine, they don't run worth a **** because the air inlet to the supercharger is just below the outlet to the carb. You can see it, that hose clamp just underneath the outlet. That hoseclamp is holding a piece of cheesecloth that is the 'airfilter', it sits so tight to the cylinder head you cannot p*** your finger between them, the cammer was worse than this pic.
    I managed to get it to putt around well enough on the street but at throttle you couldn't get air to the engine and it'd go pig rich. I posted pics of it years ago on the hamb, it might be near the beginning on this thread. That Cobra was in the raw aluminum, never been painted.
    loudbang and 63fdsnr like this.
  5. rooman
    rooman
    The car pictured was tested by Road and Track Magazine back in the day and ran mid 11 second quarter mile times so it did not ran that badly, and remember this was in street trim with Goodyear Sports Car Specials so traction was an issue.
    Roo
  6. oj
    oj
    The 289 DragonSnake Cobra with single 4bbl ran mid elevens.
  7. loudbang
  8. rooman
    rooman
    On slicks
    Roo
  9. oj
    oj
    Here's the bottom end of one of them engines I am working on right now, they're a goofy bore and the crank bearing O.D. went thru changes so you have to know the year of the block. This one was a Holman-Moody built engine and each piston had the CC's (i.e. +3.55cc) engraved and dated on each piston. The '427' is cast right into the block, above the lifter bore, cross bolted mains and high tin castings. Bad***ed. I hope to have it back together next week.
  10. loudbang
  11. Blues4U
    Blues4U
    from So Cal
    Brough Superior is a British motorcycle, not a car; V-Twin powered, very high end for the time. Lawrence of Arabia was known for owning one, he was killed riding it.
  12. rooman
    rooman
    Sorry, wrong answer. George Brough did build cars as well. The French text in the original post is incorrect in that the engine was a straight 8 rather than a V but the rest is correct as explained here: https://revivaler.com/1935-brough-superior-4-2-litre-drophead-coupe-yard-find/
    Roo
  13. Blues4U
    Blues4U
    from So Cal
  14. Blues4U
    Blues4U
    from So Cal
    Here are a couple of cars that I think fit this thread (maybe should be in the "Specials" thread...) These 2 cars were at the TROG event in Santa Barbara over this past weekend. They are pretty famous cars built by Willis Baldwin in Santa Barbara in the late 40's - early 50's, and were campaigned successfully on road race circuits. IMG_4376.jpg IMG_4377.jpg IMG_4378.jpg IMG_4379.jpg IMG_4380.jpg IMG_4381.jpg IMG_4382.jpg IMG_4383.jpg IMG_4418.jpg IMG_4419.jpg
  15. loudbang
  16. loudbang
  17. loudbang
  18. denis4x4
    denis4x4
    from Colorado
    Found these shots from the Colorado Grand when they came through Durango in 2009 DSC02841.JPG DSC02844.JPG DSC02843.JPG
  19. loudbang
  20. quick85
    quick85
    Harry Heuer in the small block Chevy powered Scarab Meister Brauser.
    12.2 quarter mile e.t.s make this a hot rod sports car. This photo was
    taken at Meadowdale Raceway, Carpentersville, Illinois.
    1947knuck, Oldioron, enloe and 7 others like this.
  21. gnichols
    gnichols
    from Tampa, FL
    They are very cool indeed! Thanx for the pix, Gary
    enloe and loudbang like this.
  22. quick85
    quick85
    Going through a group of 8x10s this morning and ran across this hot rod.
    Shot by photographer Dave Friedman, this is A.J. Foyt at Sebring in
    March 1967. Ford GT40 MK 11B, 427. Co-driver was Lloyd Ruby.
    1947knuck, oj, Oldioron and 5 others like this.
  23. gnichols
    gnichols
    from Tampa, FL
    This IS a sports car, not a hot rod sports car or special. Gary
  24. quick85
    quick85
    Okay...would you like me to delete that photo, all the photos of Cobras and
    the photo of the Scarab I posted? I don't recall you calling into question
    the photos of Cobra roadsters and Daytona coupes.
    To me, anything powered with an American 427 is a hot rod. Again, to me,
    this discussion is one that can be a bit more open when it comes to photos,
    ***les and descriptions. Drag racer John Force used to refer to his nitro
    burning AA/FC as a hot rod. It was a far cry from a '32 hi-boy but I don't
    believe too many gearheads took exception to his terminology. Funny what bothers people.
  25. loudbang
  26. SEEKONK JIM
    SEEKONK JIM
    hot rod...101...BIG motor in a small car.....dunn...
    seb fontana, loudbang and quick85 like this.
  27. quick85
    quick85
    Shot at Rt 66 Raceway, Joliet Illinois. Hot rod? Drag radials. Hot rod?
    Cobra. Sports car? 427. SCCA A/Production road racer? Knock-offs on
    the front, bolt-on stamped steel wheels in the rear. Is this "thing" all
    f****d up or a coat of many colors.
    Isn't it more fun to just dig on the photos than be picayune (trivial)?
  28. loudbang
    How about a Kellison? ;)
  29. foolthrottle
    foolthrottle
    That should get your blood pumpin this morning
    1947knuck, cactus1, mgtstumpy and 8 others like this.
  30. 64 DODGE 440
    64 DODGE 440
    from so cal
    MUSIC !!!
