Technical 50's Ford Fender Surgery
Discussion in 'Traditional Hot Rods' started by sparky232, Mar 18, 2019.
  1. sparky232
    sparky232
    Anyone have any insight as to differences in early/mid 50s Ford car fenders? I have a 53 Mainline and getting a fender doesn't seem to be happening less than $600. Seems to me the only difference is the front so I'm thinking I can get a different year and cut and weld. The front of mine luckily is in good shape, its moreso the wheel well and back thats all boogered up.
  2. green53ford
    green53ford
    from Wisconsin
    52 and 53 are the same except around the grill area. 54 should work also if you are using just the rear area.
    Squablow likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    The '54 fender is different, I bought a NOS '53 and found out the expensive way, fortunately I was able to recoup most of my money. HRP
  4. 6sally6
    6sally6
    Really?!....How different?!
    6sally6
  5. HOTRODPRIMER
    HOTRODPRIMER
    The forward grille area on the 54 fender is different and the '54 fender has a slight peek the others don't have. HRP
  6. sparky232
    sparky232
    Ideally what I would like to do is use entire fender but cut and weld the front grill area. Provided I find a suitable donor that doesn’t cost a mint. Thanks for the info!
  7. sparky232
    sparky232
    What do you mean about a slight peek?
  8. HOTRODPRIMER
    HOTRODPRIMER
    From the head light back on top of the fender, it will work but body work will be needed to match your '53 Ford. HRP
    sparky232 likes this.
  9. 54vicky
    54vicky
    actually the crease is on the side of fender it is on the bezel and runs for a short distance back toward the rear. it fades out and the shape of fender resembles the 52-53 the attaching to the inner fender will differ from 52-53 I think because of the flathead vs y block.the canadian 54 may differ on that point as well as we retained the flathead in 54
  10. lucas doolin
    lucas doolin
    Did you try the H.A.M.B. Cl***ified "Wanted" Section? Or the Ford Barn? Seems like you could do way better than $600.00 for a used fender. Of course I'm stuck in a 40 year old time warp with respect to prices. But still ...
  11. sparky232
    sparky232
    Yeah I’ve been looking for a few years and the only decent 53s have been in the $600 range. Guess that explains why previous owner filled it with bondo. Thanks for the heads up, I’m going to post in wanted section and check the barn
  12. lucas doolin
    lucas doolin
    Check this out in the H.A.M.B. "Cars for Sale" Cl***ifieds - '53 Ford V-8 with Overdrive
    It would provide the fender you need plus lots more parts including a very rare power steering option. You could sell what you don't need and wind up with a free fender.
  13. lucas doolin
    lucas doolin
    BTW, ad says it's from Nuevo Mexico so the fender should be rust free!
  14. fastcar1953
    fastcar1953
    how bad is your fender? could it be repaired cheaper than 600?
  15. sparky232
    sparky232
    It’s pretty rough. That side must have taken a good hit at some point and someone attempted to unmangle the fender and fill it with a gallon of mud.
  16. sparky232
    sparky232
    Only pic I have at the moment. It doesn’t look too bad here but on the inside there’s a lot of waviness and creases
  17. Only seeing that little shot of your damage I can tell you I would just fix it. Now you gotta understand 70 was not my last B-Day and I've been at it for most of my life. Metal work is a skill for sure but if I can learn it so can you. Some times a novice metal man works way to hard to save a section instead just hand building a new one. I have built many a round as well as squared off wheel opening and metal finished then into a quarter or fender. That fender would need to be in bad shape in more places than what we see before I would even up bolt it from the car. That's a fix in place for me.
  18. 1-SHOT
    1-SHOT
    from Denton
    IMG_1308.PNG Looks like a fixer to me, been bending tin over 60 years.
    Get the little book the Key to Metal Bumping . Amazon has it so does Jegs and they are on evil bay. They are put out Martin Tool and Forge. They also make great hammers. I have given a copy to all my helpers-trainees.
    I have used Fairmont and Martin hammers and dollies all my life. Frank
    Atwater Mike and sparky232 like this.
  19. sparky232
    sparky232
    Yeah that’s not the only bad spot, it’s just the only one where mud popped out. I’ll get some better pics over the weekend.
    I definitely don’t feel it’s unfixable, but it’s a bit outside of my capabilities. I was looking at a different year donor and some welding as an easier route because it’s a little more in my wheelhouse
  20. Post up a few more photos of the complete fender and maybe 1-SHOT and I can encourage you to expand your cut-n-weld talents into saving you some $$$ while discovering a hidden talent.
    The lip on the opening is the least to worry about unless you want a concourse restoration job. That can happen too but maybe not the first time out the gate.
    Check this out. The black line is a piece of 1/2" x 1" rectangle tube that will be the new opening. Note the horizontal line below the tube and above the blue tape. I'm going to move the horizontal line up and above the wheel opening, and it's not that tough.
    Body work 009.jpg Body work 012.jpg Holy Smokes!!.jpg Just welded solid 004.jpg Not bad; 001.jpg With this same basic treatment you can save the wheel opening on your fender. You can do this if you like with a little help. May take a little more bump and grind with a skiff of filler but a bucket full. Shaping the tube is quite easy. What do ya think?
  21. patsurf
    patsurf
    you working on a rambler?
  22. Wellll,,,,,, let's just say it's off Topic on this sight but I can still use photos to explain How to do things. That said I must confess it's the Rambler from Hell.
  23. patsurf
    patsurf
    well,it's got the devil to fix it-perfect match-up...it doesn't stand a chance! nice!
    Pist-n-Broke likes this.
  24. Atwater Mike
    Atwater Mike
    Exactly. I've been nudging metal awhile myself, but got the book and learned volumes.
    My wife got into it also, it's very distinct.
    My '54 Ford coupe had front fenders that were rusty in the water traps, luckily my bud Dennis Moomjean had a '54 Customline he gave me for $100. Perfect front 'clip', and many boxes of parts before I junked the bare body.
    Parts car is the answer.
  25. That project has been in paint and doing Time for a few years now. I just keep some Fab photos around to post up when I think they may help with some visual aids.
  26. 52HardTop
    52HardTop
    I have a pair of 53 Ford front fenders in my garage. They do have the slight peak along the top of the fender. The peak starts at the headlight and runs the top of the fender. Now you may ask why a guy with a 52 Chevy has a pair of Ford fenders in his garage. I picked them up when I was a little more ambitious. I always admired the way Bob Klessig had flaired front fenders on his Hard Top turned Convertible. I asked Bob what he used and he told me they were 53 Ford fender flairs. So, I picked up a pair and never used them. Are they what you're needing?
  27. belair
    belair
    Love that AMX
  28. 1-SHOT
    1-SHOT
    from Denton
    Nice work Pist-N-Broke, that looks like a AMX
  29. Yes it is 1-SHOT. It's way off topic for here so I only post up construction shots when I think they may help explain things and help out.
  30. loveoftiki
    loveoftiki
    from Livonia,Mi
    Wasn’t somebody making the 54 Ford fender opening?? I swear I saw that...look *****in on Merc’s
