Technical Recommend an automatic shifter
Discussion in 'Traditional Hot Rods' started by Greasyman, Mar 20, 2019.
  1. Greasyman
    Greasyman
    I'm looking at shifters for my T bucket with a TH350. I'm planning on installing a Transgo shift kit that will convert the ****** to full manual operation. https://www.summitracing.com/parts/trg-350-3/overview/ I've never driven a car with an aftermarket shifter, so it's fairly confusing to pick one. I think I'm going to go with a ratchet shifter, and right now I'm leaning towards the B&M Hammer shifter. It's fairly inexpensive and in the videos I've seen it seems to be pretty slick in operation. I also like that I can replace the t handle with a more traditional ball knob. Any opinions on this shifter, or recommendations for others?
    1Nimrod and loudbang like this.
  2. Why not a column shifter? It certainly used to be done, so it's traditional, and there's no inconvenient lever between you and your girl... ;)
    1Nimrod, j3harleys and loudbang like this.
  3. finn
    finn
    Ratchet shifters are a pita in a street car. Not worth the complication when shuttling the car back and forth to spot it in the garage, Ora parking spot, at least if they operate like the two B&M shifters I have.
  4. Mike VV
    Mike VV
    from SoCal
    I put a Winters in my old Stude wagon.
    You can beat on it with a big hammer, it's made to handle anything.
    Three speed or four speed patterns.
    Mike
    1Nimrod, hrm2k, Baron and 3 others like this.
  5. Greasyman
    Greasyman
    That looks small, simple and easy to use. I'll take a look at those. Thanks.
    Baron and loudbang like this.
  6. desotot
    desotot
    how about an old Mustang shifter. Simple and easy.
    MO_JUNK and JeffB2 like this.
  7. sloppy jalopies
    sloppy jalopies
    Fords with a C6 had some floor shifters that had the "neutral safety lock out switch" built into the shifter, instead of bolting to the side of the ******...
    using one on my '30 coupe... [4 wires]
    1Nimrod, MO_JUNK and loudbang like this.
  8. Nailhead Jason
    Nailhead Jason
    the Hammer shifter is a giant pile of ****. I took the one out of my dads Nomad, and made sure it made its way to the land fill so no one else will be cursed with one. It is a pain to operate, period. if you must have a full manual valve body, it will be a complete nightmare. Why not just a Lokar shifter? they work great and operate smooth as gl*** when set up properly.
  9. bobss396
    bobss396
    I like those a bunch, so are the old Powerglide shifters, but most you need a console.
    1Nimrod likes this.
  10. Mike VV
    Mike VV
    from SoCal
    Greasyman -
    Small...no... Probably the biggest ***embly on the market.
    Simple, yes. Very simple in its construction. You can get them with reverse lockouts and without (shown).
    Mike
    1Nimrod likes this.
  11. Stock Racer
    Stock Racer
    I've had a B&M Quicksilver which is a ratchet style and a Art Carr which is now the Winters shifter (I think they call it Sidewinder or something like that) which is a gate type. I liked them both. Decide weather you would prefer to ratchet through the gears or prefer the winters which is spring loaded side to side to get to the next gate. Some of these guys sound like old ladies. Heaven forbid they'd have a 4-speed.
    1Nimrod, JeffB2, Bigblue61 and 3 others like this.
  12. egads
    egads
  13. gene-koning
    gene-koning
    I put a Sidewinder in my latest hot rod pickup. It took some time and modifications to get it to work on my late model Mopar trans, but its working pretty well now. I've only put about 50-60 miles on the truck at this point, so I can't comment on how its going to work long term.
    The plastic case is 15" long, 5" wide, and about 6" high, with the shifter handle above that, and the cable coming out the rear. Its going to take up some real estate in the T bucket. Gene
    1Nimrod, Stock Racer and loudbang like this.
  14. primed34
    primed34
    Got a B&M Quicksilver in my '34 but I used an older thinner console that put the shifter almost between the bucket seats. I like it and it works good. Hurst Quarter Sticks are good also. Lokar looks a little fake to me. If I wanted a shifter that looked like a manual transmission shifter, I'd run a manual transmission.
    1Nimrod, JeffB2, Stock Racer and 2 others like this.
  15. I am presently using a B&M Starshifter. It took a little getting used to, but I like it. I don't know where you would find one.
    I also have a Mustang shifter hung in my garage, that I plan to use in one of my other cars. It will be operating a C6, so no modification required, but it would be easy to adapt to a TH350 or 400.
    I also love the Hurst Dual Gate, and although I haven't looked lately, I believe they are getting expensive.
    My son is using a Lokar shifter for his B&M 700r4, and he likes it.
    Bob
    1Nimrod likes this.
  16. jimvette59
    jimvette59
    I used a Mustang shifter on the floor of my Thirty Four . Remember KISS !!!!!!
  17. 5brown1
    5brown1
  18. theHIGHLANDER
    theHIGHLANDER
    They should take the '&' out of the B&M shifters and it would be more appropriate. Although some folks seem to like to punish themsleves so they sell anyway.
    Hurst Autostick II. Simple and reliable, street or strip. And yes you can change the 'T' handle to a conventional knob. No moving parts on the lever. Maybe find a good used Gennie Shifter as I think they're outta business, but their stuff was always good.
    1Nimrod likes this.
  19. sloppy jalopies
    sloppy jalopies
    years ago a buddy bought a b&m…
    the cables would break up and the new one cost over 1/2 what the shifter cost...
    4woody and 1Nimrod like this.
  20. Stooge
    Stooge
    Gennie is still around in some form it seems, and I think in the last y or 2, they started introducing some new products, pedals, new style sticks, etc. and some of it looks pretty cool. I've used Lokar a handful of times, and although they are a little spendy, they make a good product that works well, and has good customer support. im not the biggest fan of the look of their shift knobs so in my last car, I did some cobbling and added a cast aluminum stick that I liked better. ( this was just a mockup adapter piece that I ended up remaking)
    1Nimrod likes this.
  21. saltflats
    saltflats
    from Missouri
    I run a B&M Pro Ratchet and love it.
    But this is in a race car.
    1Nimrod likes this.
  22. Straight Axle Guy
    Straight Axle Guy
    I've used Gennie in my last 4 cars, with no problems
    1Nimrod likes this.
  23. 56sedandelivery
    56sedandelivery
    Any transamatic automission shifter for me would have to be a Hurst Auto Stick 1; it's why I have 4 of them on hand. As far as "expensive" B & M, and other brands of cable shifters, just go to any marine supply outfitter; they are usually in the $20-30 range, a LOT cheaper than the B & M pricing (Morse cable for length/ends). I like the Hurst and B & M "race" cable shifters with a built in lockout feature, just not the one's with a pistol grip, but they don't really fit in with any traditional builds.
    I am Butch/56sedandelivery.
    1Nimrod likes this.
  24. Blues4U
    Blues4U
    from So Cal
    I use a B&M Pro Ratchet shifter in my pickup and it works fine, though as others have pointed out it's a bit of a pain for street use, really only when parking and needing to switch between reverse and drive, due to the lockout device. Eh, if that's the worst thing to deal with life is pretty good. Not very traditional looking though, if that matters.
    If I had to change it out, I'd probably do what Squirrel does and build my own.
    1Nimrod and saltflats like this.
  25. Blue One
    Blue One
    from Alberta
    1Nimrod likes this.
  26. hrm2k
    hrm2k
    1Nimrod likes this.
  27. Atwater Mike
    Atwater Mike
    I just bought a Summit shifter for my F100. GREAT mechanics, side-detent, positive lockup in Park and Reverse, neutral safety switch included, it's on the shifter.
    Uses the Summit stick ($110, stick alone...Not for ME!) Or any popular stick...Two bolts attach stick, like a Hurst: 7/8" apart.
    Shifter bolts to the floor, all bracketing included. #SUM 700062, look it up. Bolts, mechanical shift rod and lever for 350 T.H. shift arm. Bolts are ****on head allens, nice hardware. Shift 'box' is small, a 4" square boot will cover it.
    I made my own stick (last night, easy...Forge and anvil, then finish) Started with a 5/8" rod, warmed up the 3" of one end, anvil-shaped a nice 7/16" 'flat', worked the rest into a nice taper, will finish length and shape when I finish installing.
    Total price (without their stick) $179.00
    Way better (solid, CNC parts, all steel, not plastic) than the B&M junk (had one, never again) Look it over.
    Better than the Mr. Gasket $90 'special' that I modified...I had to locate and file my own detent reliefs! Get what you pay for...
    1Nimrod likes this.
  28. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    TCI in my '32 with the line lock and trans brake ****ons.
    1Nimrod likes this.
  29. Brian Penrod
    Brian Penrod
    All of the ratchet shifters are pretty good they just take a little getting used to. Never had a problem using on on the street. Precision Performance probably has the smallest one on the market, about an in wide.
    1Nimrod likes this.
  30. 40Standard
    40Standard
    from Indy
    Vega floor shift if you can find one
    1Nimrod and X-cpe like this.
