Technical Stromberg carb kit
Discussion in 'The Hokey Ass Message Board' started by LSJUNIPER, Mar 21, 2019.
  1. LSJUNIPER
    LSJUNIPER
    from ct
    I did a search and did not find any info that would answer my question. The question is, is there a vendor out there other than Speedway who has the intake, carb, linkage and anything else I may need to set up a 3 x 2 on my 39 flathead with Stromberg carbs? I saw that there are a few different types of carbs as well as far as CFM's. This is all new to me so any guidance will be appreciated.
    Thanks
  2. sdluck
    sdluck
    Where have you looked,
    Stromberg Carburetor Rebuild Kits 9590K-97 Summit racing
    LSJUNIPER likes this.
  3. Heavy Old Steel
    Heavy Old Steel
    Vintage Speed
  4. alchemy
    alchemy
    There is no better vendor than Stromberg themselves. Look on their website for all the parts you might need. Our own Uncle Max is a superior repair tech recommended by Stromberg too. His info is also on their website.
  5. Bandit Billy
    Bandit Billy
  6. wheeltramp brian
    wheeltramp brian
    The rebuild kits from speedway motors have garbage accelerator pumps in them
  7. chevyfordman
    chevyfordman
    I bought a Stromberg kit from Daytona in Fla., seems like a nice kit to me.
  8. LSJUNIPER
    LSJUNIPER
    from ct
    Thanks all,
    I emailed Clive at Stromberg for info.
    I also think I may have confused some of you guys, I wasn't very clear. By carb kit I meant is there a vendor who sells the intake, with the carbs, kind of like a bolt on set up. I purchased the Super 6 set up from speedway then found out that there more trouble then there worth according to what I have read here. Ryan did a side by side comparison and found that the Speedway set up is poor quality compared to a Stromberg set up. I hope this clears up what I was looking for.
  9. alchemy
    alchemy
    Yes, a carb kit is a small box filled with gaskets, and some small wear parts. You are looking for a complete intake setup. I still think you would be wise to make the purchase of carbs and all linkage and fuel lines from Stromberg. You can find intakes at a million places, but not as many sell the good Stromberg stuff.
    LSJUNIPER and Frankie47 like this.
  10. Model A Gomez
    Model A Gomez
    The Carburetor Doctor has good kits for Stromberg carbs.
  11. LSJUNIPER
    LSJUNIPER
    from ct
    Clive at Stromberg replied to my email this morning, I do plan on making the purchase from Stromberg. Thanks for all the help.
