Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. 1947knuck
    1947knuck
  2. loudbang
    1963 Corvette Grand Sport
  3. loner1
    loner1
    from Texas
  4. loudbang
  5. '51 Norm
    '51 Norm
    from colorado
    "Only" 8 carbs? ^^^^^^^^^^
    Deuces, deadbeat and loudbang like this.
  6. dickster27
    dickster27
    from Texas
    loner2, Stebo27, Deuces and 13 others like this.
  7. cruiserjohn76
    cruiserjohn76
  8. 1947knuck
    1947knuck
  9. 1947knuck
    1947knuck
  10. 1947knuck
    1947knuck
  11. loner1
    loner1
    from Texas
  12. XXL__
    XXL__
    Tunnel ram...
    loner2, Deuces, alanp561 and 12 others like this.
  13. mad mikey
    mad mikey
    TBirdGirl26, loner2, Stebo27 and 14 others like this.
  14. 1947knuck
    1947knuck
  15. mgtstumpy
    mgtstumpy
    Buick engineers experimented with this turbocharged 425 CID in the ’60s. Carter YH side-draft carbs fed a single TRW turbo, purportedly generating more than 425hp and 700ft/lbs of torque, far more than any OEM Buick drive-line could handles. As such, the project was parked. The engine now resides in the GM Heritage Collection in Michigan.
    He's a reverse flow Buick nailhead :D
    loner2, Stebo27, Deuces and 11 others like this.
  16. mgtstumpy
    mgtstumpy
    Buick XP300
    In 1951, Harley Earl’s famous LeSabre concept appeared, with a radically advanced 3.5 liter (216 CID) aluminum V8 that ran on both gas and methanol. It was supercharged and rated at 339hp. Here's schematic and the actual engine
    The little Buick engine had hemispherical/pent roofed heads, but with its valves in the cl***ic formation allowing for large valve diameters. If you look at the intakes on this, one can see that the nailhead used the same unusual arrangement, but for both its valves. The LeSabre/XP 300 engine’s exhaust push rods had a wild arrangement, and were designed to fit into the block between each cylinder.
    loner2, Stebo27, Deuces and 10 others like this.
  17. loudbang
    standard T Bird
    supercharged full body
    TBirdGirl26, loner2, Stebo27 and 9 others like this.
  18. loner1
    loner1
    from Texas
  19. 340HilbornDuster
    340HilbornDuster
    Deuces, loner1 and loudbang like this.
  20. loudbang
    Got one you may enjoy.... Mopar 273 dragster
    Silver Bullet
    loner2, 1947knuck, Stebo27 and 11 others like this.
  21. loudbang
    Pomona Swap Meet 2019
    Ridgerunner Ram
    TBirdGirl26, loner2, Stebo27 and 10 others like this.
  22. 1947knuck
    1947knuck
  23. loudbang
    loner2, Bowtie Coupe, Deuces and 2 others like this.
  24. loudbang
  25. loudbang
  26. 1947knuck
    1947knuck
  27. loudbang
    Ford GT40
    1964 Studebaker Hawk Supercharged
    TBirdGirl26, loner2, Stebo27 and 13 others like this.
  28. 28dreyer
    28dreyer
    from Minnesota
    Here's a very rare V8-60 with Riley side drafts on a Sandice manifold.
    loner2, Stebo27, BigO and 10 others like this.
  29. XXL__
    XXL__
    This W is a heavy drinker...
    loner2, Stebo27, mad mikey and 10 others like this.
  30. loudbang
