Technical Deuce guy's - What the heck are these?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Mar 22, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I have owned my sedan for more than 30 years now and I found these under the rear seat when we were removing everything to install the insulation.
    They are wood and the both have a slot head screw through them, they were not mounted to anything just laying there. HRP
    dana barlow likes this.
  2. Slopok
    Slopok
    Wedgies are tradtional!:eek:
    loudbang, dana barlow, blowby and 2 others like this.
  3. krylon32
    krylon32
    from Nebraska
    Are those the wedges that go directly behind the B pillar at the bottom to get the upholstery board going in the right direction?
    Fordor Ron likes this.
  4. partsdawg
    partsdawg
    from Minnesota
    Couple pieces left in there at the factory so all these years later someone would ask ‘ what the heck are these’
  5. dana barlow
    dana barlow
    from Miami Fla.
    Right side is the "Wiggel" an left is the "Waggel"
  6. little howard
    little howard
    from kcmo
    Kyrlon32 is right,
  7. HOTRODPRIMER
    HOTRODPRIMER
    That makes sense, they could have been removed and stashed for installation later. HRP
  8. hotrodA
    hotrodA
    Yep, what Gary said. Mine are missing. There is a 1/4" hole punched in the floor, same location, both sides. ReggieK on FB sent me dimensions. I couldn't figure out the compound curve required over the wheel well.
  9. Yep. They are the mounting points for the rear upholstery cards as Krylon 32 said. I just cut some new ones for the red 32 car last week so I could remount the trim panels in it matter of fact.
    There’s a factory hole on each side that they screw down into. Keeps the bottom quarter of the trim panel from flopping around.
  10. Chappy444
    Chappy444
    Has that mysterious rattle noise disappeared??? :D
  11. HOTRODPRIMER
    HOTRODPRIMER
    I never heard these things rattling around but without a interior there was so much road noise they could have been bells and I couldn't hear them! :D HRP
    VANDENPLAS likes this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    At least the original owner saved them and didn't throw away, why he took them from their original location and stored them under the rear seat is beyond me but I now know where they go and I will put them back in place. HRP
  13. 56don
    56don
    Everyone should remove their rear seat every 30 years or so......:p
    Irish Mike likes this.
  14. 5window
    5window
    With the added advantage of filling two holes that can let dirt, noise and moisture into your car.
  15. stillrunners
    stillrunners
    from dallas
    The rattle you couldn't find ?
  16. HOTRODPRIMER
    HOTRODPRIMER
    You ain't right Don! :D HRP
    56don likes this.
