Projects All escutcheon plates are not made equal
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Mar 27, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I found out last night all escutcheon plates are not made the same when we tried to install my new escutcheons on the rear window cranks, I was under the impression my interior window & door cranks were 40 Ford but when I tried put the handle on it was obvious I was mistaken, the hole on the escutcheon plate is too large and wont work, we dug around in the junk parts and found something spring loaded that does.
    I wanted to avoid the early style that had barbs on the back and are prone to slip around and tear the material.
    I will have to take it and go to the Early Ford V8 store and try to match it up, I never knew they had so many different types, live & learn and collect more parts for the next swap meet! :rolleyes: HRP
    3W JOHN and dana barlow like this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    On custom panels,just for info,over the years have found stuff in other then auto spots. House lamp parts and also in this case on my own handles; This last time I redid my inside. I used two rings from sewing store,made for d****s. I don't have those fanzy windows,just inside door handels. Worked well for my 28A
  3. DDDenny
    Listen to you, using them big words!:D
  4. HOTRODPRIMER
    HOTRODPRIMER
    What do you call them Doug?, I could have called them the thingies that fit behind the door handles, but I'm sure someone would have corrected me. :D HRP
    3W JOHN and mgtstumpy like this.
  5. DDDenny
    Danny
    Truth be told, I've had better results using the term "thingie".
    Don't remember what I was looking for at the time but I went to either Lowes or HD and asked the guy for an escutcheon and the guy looked at me like I had two heads.
    Life goes on!
    3W JOHN and HOTRODPRIMER like this.
  6. BamaMav
    BamaMav
    from Berry, AL
    I always called them window handle doughnuts.
  7. blowby
    blowby
    from Nicasio Ca
    I still don't know what this is about..:oops:
  8. squirrel
    I looked up the definition:
    Escutcheon (in medicine) the distribution of pubic hair.
  9. roseville carl
    roseville carl
    what we learn here ............
  10. topher5150
    topher5150
    i'm still trying figure out how to say that word
  11. HOTRODPRIMER
    HOTRODPRIMER
    Jim, you ain't right! [​IMG] HRP
  12. lothiandon1940
    lothiandon1940
    If I recall, the ones for '46-'48 Fords are the spring loaded ones. They really come in handy especially if your actual handle or the rod on the mechanism itself is worn. Like you, Danny, I'm not fond of the ones with the little barbs on the back.
  13. HOTRODPRIMER
    HOTRODPRIMER
    It's pronounced es·cutch·eon. HRP
    Escutcheon plates are what fit's between the material and the window and door cranks. HRP
  14. lothiandon1940
    lothiandon1940
    ................S Cut Chin
  15. wbrw32
    wbrw32
    Danny.Its a shame the HAMB has too many newbies nowadays...
  16. squirrel
    I can quote you on that
  17. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    On the universal spring loaded escutcheons I used on my 5 window and delivery they came with clear plastic bushings to make up for the difference in handle base diameter.
  18. da34guy
    da34guy
    Did sum1 say Donuts ??
    3W JOHN, HOTRODPRIMER and LOST ANGEL like this.
  19. beater32
    beater32
    What are those handles off? Just what I'm looking for!
    Sent from my ZTE R84 using The H.A.M.B. mobile app
  20. Sky Six
    Sky Six
    from Arizona
    I thought they were like Presbyterians, thanks for correcting me.
    3W JOHN, HOTRODPRIMER and blowby like this.
  21. trollst
    trollst
    You guys keep using big words, I'm gonna have to leave, I thought they were called hoomerhingies, or thingiebobbers. I only know a few big words, can't say them here.
  22. HOTRODPRIMER
    HOTRODPRIMER
    I have been accused of being somewhat of a sesquipedalian at times but every now and then I like to confuse people. :D HRP
    3W JOHN and The Shift Wizard like this.
  23. gene-koning
    gene-koning
    Yea, I'm not going to look that up either, so I'm just going to make up my own meaning for that word. I probably shouldn't print my meaning here, so you will just have to guess what I'm going to say you are.
    I saw an "escutcheon kit" that included "show quality" both inside door handles, both window cranks, all 4 escutcheons, 4 springs, and 4 new clips on Ebay yesterday for around $200. they are pretty proud of that stuff. Gene
  24. catdad49
    catdad49
    HAMB'r Speak 101. Cl***, please pay attention or you will be sent to detention~!
    3W JOHN, HOTRODPRIMER and trollst like this.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Where is this hub of activity accruing exactly?
  26. ClayMart
    ClayMart
    So... then... It's kind of related to the merkin. :confused:
  27. I thought escutcheons were for making Br*** Age shift knobs.?.
  28. blowby
    blowby
    from Nicasio Ca
    I'm glad we could have this discussion
    Of this part known as an escutcheon
  29. 5window
    5window
    Escutcheon comes from the Latin word for shield and was adopted into English in the 1400's as a place where you mounted your coat of arms on your armor. You can see how it descended down to Danny's need for a protective plate behind his door handles.
    As for descending, it seems that you, SQUIRREL, have descended far enough, so I refer you to this:
    JOURNAL ARTICLE
    *** differences in adult pubic hair distribution in Nigeria
    M. L. Ajmani and K. Ajmani
    Anthropologischer Anzeiger
    Jahrg. 46, H. 3 (September 1988), pp. 255-260 :)
    3W JOHN, catdad49 and HOTRODPRIMER like this.
  30. HOTRODPRIMER
    HOTRODPRIMER
    The origin of the word sesquipedalis, is Latin meaning a foot and a half long, to simplify the word sesquipedlis translated to English just means using BIG WORDS! :)
    My old Latin teacher would be proud that I finally used something I learned in his cl***
    HRP
