Customs 57 FORD GASSER BUILD
Discussion in 'The Hokey Ass Message Board' started by Lee Veinotte, Feb 6, 2019.
  1. Lee Veinotte
    Lee Veinotte
    I would think the H+M chaps know what they're up to. I'll go with that!
  2. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    And I don't,just kidding as long as they flow in a circle your good.A well known header builder once told me if you think you can ,then you can and if you think you can't then you won't.I always remember that .
    scott27 and loudbang like this.
  3. I'm not sure why I do this but I do clockwise on the Driver side and counter clockwise on the P***enger side. I had a curious customer ask me why once. I was feeling like a bit of a Smart *** that day and I told him it was to keep the Exhaust torque rolling the ch***is into the Roll Center of the Car. He bought it and has p***ed it on. I still Chuckell under my breath.
    wvenfield, loudbang and Lee Veinotte like this.
  4. Lee Veinotte
    Lee Veinotte
    I'm a bit OCD on that stuff so I think i'll probably end up doing the same.
  5. Lee Veinotte
    Lee Veinotte
    No huge updates. Just been picking away at the front frame section. Got my spreader bar all tacked in place, need to make a couple end caps and it can all be finished welded and the axle hung. 20190320_203336.jpg
    Sky Six, loudbang and wvenfield like this.
  6. Sky Six
    Sky Six
    from Arizona
    looks clean, how is the knee?
  7. Lee Veinotte
    Lee Veinotte
    Its coming along thanks for asking, I can crawl around again just can't kneel on my left for a while yet. I'm back at the gym and all is feeling good.
  8. birdman1
    birdman1
    put a 383 1958 Merc in my brothers "57 custom in 1969. 312HP engine, with a T-85 3-speed. Nice motor. Have fun with your "57.
  9. Lee Veinotte
    Lee Veinotte
    Big day today. Got the axle located and the spring hangers tacked into their final resting place. Loving the look of everything so far. Engine positioning is next! 20190331_190955.jpg 20190331_192732.jpg
  10. Lee Veinotte
    Lee Veinotte
    Shes almost a roller! Studs for the tie rod are on the wrong steering arms I know lol. 20190401_212852.jpg
    Sky Six and loudbang like this.
  11. Lee Veinotte
    Lee Veinotte
    Shes back on 4 wheels! Loving it.
    Also got the plates fitted to the engine. Tomorrow night is mockup time. 20190402_201013.jpg 20190402_193458.jpg 20190402_211341.jpg
  12. Sky Six
    Sky Six
    from Arizona
    Looking good, you've done a boatload of work in such a short time.
  13. RmK57
    RmK57
    What are the casting numbers on the heads? I think the CJ's were D0OE-R.
  14. Firedup
    Firedup
    from Oregon
    I’ve been watching this build. Looks awesome. Keep up the good work
    Lee Veinotte and loudbang like this.
  15. loudbang
    Man you are moving along at a fast clip. :)
  16. Lee Veinotte
    Lee Veinotte
    Unfortunately they're not the original CJ heads. They've been swapped with a set of early PI heads. They are supposed to be a better street head. CJ sized valves with slightly smaller ports. The block is a true thick web CJ block however.
  17. Lee Veinotte
    Lee Veinotte
    Appreciate the kind words!
  18. Lee Veinotte
    Lee Veinotte
    So i've got the engine mocked up in the front frame. The motor sits nicely between the rails but I may have an issue. The axle is only about 4" from the pan. The drag link will be even closer. I'm at 27" crank center from the floor on the balancer bolt. I'd like to get it down to 24" as per 67' rules. However i don't see how I can lower the engine or the suspension that much. Any ideas? 20190403_185751.jpg 20190403_185828.jpg 20190403_185839.jpg
    loudbang and Firedup like this.
  19. Lee Veinotte
    Lee Veinotte
    I got looking around at the Shakey Pudding '55 and she wouldn't have any more than 4" between the axle and the underside of the frame. And much less than that between the drag link and pan. I doubt my car will pull the wheels and come down like that honey does so i may be ok?
    "Photos borrowed from the build thread, please delete if it's not allowed" DSCN0460.jpg DSCN0461.jpg
  20. RmK57
    RmK57
    A rear sump pan. Like a 429-460 Fox body swap oil pan.
  21. Lee Veinotte
    Lee Veinotte
    Only thing is the drag link will have no clearance with a rear sump. Its path may even want to go through the sump.
  22. Dang,, it's all that Math stuff that gets us screwed up eh? If I'm reading this photo right
    [​IMG]Judging by your valve cover to master and carb base on tunnel ram to hood latch, looks to me like your motor is mounted way low based on where it would be in stock 57 mount location. Is this correct?
  23. Sky Six
    Sky Six
    from Arizona
    I just checked the position of my 292 in my '57 Fairlane, and the engine does look like its sitting low. Good eye PnB.
  24. Lee Veinotte
    Lee Veinotte
    Yes judging by the picture I have of the 289 that came in the car it is sitting a bit low. It can be raised but I'll have to build some fancy brackets for my plates. I'm basing the engine height on the rulebook for gas cl*** cars. My car is not very correct with the later engine ect but I'd like to keep it somewhat correct. I can raise the engine and lower the suspension, its very stiff as is so I would like to remove a leaf. But I still won't make up 3 inches of crank height. 20190209_190305.jpg
  25. saltflats
    saltflats
    from Missouri
    What is the angle of the shackles with all the weight on it?
  26. Lee Veinotte
    Lee Veinotte
    Haven't welded the shackle mounts on yet. Used a spacer to mimic the height of the shackle to the spring eye so when the weight is on I can set them at the proper angle.
  27. I could give you a valve cover to weld seam if you like. So, were I doing this job the motor would be sitting in Factory location no matter how it was mounted. Reason being is Clutch linkage, why re design something that works just fine? Now that will raise the Crank C/L but may solve some of the other issues. I kind of get the Nose Bleed ride height but you may need to adjust some to fit the rules. I know everybody does it just like you did, in other words you followed the crowd. They may not want to fit the rules you do. What happens when you raise the motor to where it started and then mount your Axle on Top of the springs. Take some time and do some Math and get back to me. Screw the instructions and Screw how everyone else has done it. Make it work for your needs.
  28. oldiron 440
    oldiron 440
    The crank centerline should be a few degrees up front frame centerline not nose down.
    wvenfield and loudbang like this.
  29. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The axle over the spring will get it down in a hurry, but might cause more interference issues.
    As the Wizard said, work to the clutch cross shaft. The front sump has always caused issues but they can be resolved. Another possibility would be to use a dropped axle. Seems like it's counter productive, but it gets the center of the axle out of the way.
    Looking at this, I'd say your WAY HIGH! For a guideline the South East G***ers have a max rocker panel height of around 11".
  30. Lee Veinotte
    Lee Veinotte
    In that picture I've got the carb mounting flange set at 0° which equals about 3-4° downward slope of the engine itself.
