Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. The37Kid
    The37Kid
    That yard work I was doing last week has carried over to next door. Maybe it is time to get started on the garage rear wall repair and new window & door install. Bob
  2. UNSHINED 2
    UNSHINED 2
    Got all the seat rebuilding supplies for my seat in yeaterday. Cleaned up all the listing wire, hogs rings and fabric off the seat for the Unibody today. 20190402_161804.jpg Tomorrow will be scrubing it down with Scotchbrite so I can throw a quick paint job on it this weekend. Supposed to be a balmy 70° here this weekend.
    chryslerfan55, MMM1693, Lil32 and 4 others like this.
  3. Hamtown Al
    Hamtown Al
    Made up wiring panel and fitted to firewall of my 32 Ford cabriolet.
    chryslerfan55, Lil32, Deuces and 6 others like this.
  4. The37Kid
    The37Kid
    ^^^^^^ What is that out of, it almost looks understandable. Bob
  5. Hamtown Al
    Hamtown Al
    It is the same simple panel I have made and used on a number of hot rods.
    The main hot lead will come from the starter to the terminal at the top of the bottom panel.
    The bottom panel will be hot all the time unless the battery cut-off switch is off.
    Power from the power terminal goes to the relay "power in" terminal via the bottom 10 GA wire.
    Power goes from the relay on the "power out" terminal via the top 10 GA wire and that wire powers the whole panel at the top. You also see a black "ground" wire for the relay that goes down to the bolt that holds the panel to the firewall and also serves as a ground. Not shown is the fourth wire which will be 14 GA from the ignition switch that will energize the relay and put power to the top panel when the ignition is turned on.
    The bottom panel will power things like lights, brake light switch, flashers, horn, etc.
    The top panel will power wipers, radio, air conditioner(I wish!), etc.
    Pick an outboard terminal and run a wire to whatever needs juice; insert appropriate size blade fuse in the box and you are done. There are 10 outputs from each panel. The ones I used to buy at Advance for about $10 each only had 6 outputs. Advance now wants big $$ for that same panel! I found these on-line for about $12 each and they have optional plastic covers which the Advance panels did not have.
  6. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^^^^ I'm past half way of understanding that. Can things get flipped so the numbers are not upside down? Bob
  7. Hamtown Al
    Hamtown Al
    ^^ Sure, the bottom one could be switched around to have the numbers not be upside down but then you have a hot terminal at the bottom and not in nearly a protected area as in the current configuration.;)
    Safety first.:)
    chryslerfan55, Hombre and UNSHINED 2 like this.
  8. Mike Miller
    Mike Miller
    Filed piston ring end gaps.:(
    Latigo, chryslerfan55, Deuces and 2 others like this.
  9. roseville carl
    roseville carl
    Turned useless chev distributors into Flathead dists
    40two, stanlow69, olscrounger and 5 others like this.
  10. The37Kid
    The37Kid
    Started raking the third lawn on the street, I'm thinking about turning pro. bob
  11. Grandadeo
    Grandadeo
    Sold a few early Ford parts at the Charlotte Auto Fair.
    Lee
  12. lumpy 63
    lumpy 63
    Went to Goodguys show at Del Mar , My friend Hot rod Holly is good buds with Gene Winfield so she brought him over to where we were parked and we all hung out with Gene for awhile:D He says his hip is all better and he's doing fine.
  13. swade41
    swade41
    from Buffalo,NY
    Finally got the last part in to finish up the rear end and redrilled the drums to Chevy pattern, should be back under the truck this weekend. Painted a couple pieces Chevy orange just to mess with my ford buddy that didn't like my red oxide primer 3rd member under a Chevy truck. 20190405_131207.jpg 20190405_165256.jpg
    lothiandon1940, 40two, LAROKE and 7 others like this.
  14. LM14
    LM14
    from Iowa
    I painted my engine!
    SPark
    paint36.jpg paint39.jpg paint40.jpg paint42.jpg paint43.jpg paint44.jpg paint48.jpg paint49.jpg paint50.jpg paint53.png
  15. deathrowdave
    deathrowdave
    from NKy
    No Pictures , but I got a good handle on a rebuild of a Turbo 400 , for my Buddy’s project . Gots some diesel repairs lined up , then a Harley carb and caliper swap out to later issued stuff , then a wire up home back up generator . A few weeks and all booked up so far !
  16. mad mikey
    mad mikey
    If the weather clears up here today, like it is supposed to, going to get the drag coupe out. Just put some race gas in the fuel cell and cleaning her up abit. WIN_20190327_17_38_06_Pro.jpg
  17. 62rebel
    62rebel
    So far today I've replaced the fuel tank on the Galaxie. Original had two holes in the top letting water in. Taking a Hamb break and heading back out in a few
    61Cruiser, UNSHINED 2 and Deuces like this.
  18. jimmy six
    jimmy six
    IMG_1988.JPG Donut Derilicks at 5:00AM, started raining 1/2 way there. Got to test the Newport electric wipers... happy with them. Proves the car isn't made of sugar......it didn't melt in the rain.
  19. The37Kid
    The37Kid
    Two months ago I was splitting kindling for the woodstove down in the ba*****t shop. Head flew off the hatchet on the third or fourth swing and shattered the sliding gl*** door. Taped it to keep it together, bought two sheets of 2 inch ridged foam for backup protection,, nice hillbilly fix. New door would run 800-1,500, and I never got to ask what a 4x8 replacement gl*** would cost. Wednesday I spotted three doors in town leaning against a building that was being remodeled. Took two days to get the ok, FREE DOORS! Installed it today and I can get in and out of the ba*****t again. Some day all three car projects in there can come out. It was a good day. Bob
  20. Black_Sheep
    Black_Sheep
    Worked on a digital slide show of build pictures which will be part of my display next weekend at the GSTA show.
  21. chevy57dude
    chevy57dude
    Mikey spent 10 bucks per gallon. eek!:eek:
    lothiandon1940 likes this.
  22. Rodders
    Rodders
    Started to pull the engine out of my 32 because it decided it did not want to participate this year
    UNSHINED 2 likes this.
  23. Mike Miller
    Mike Miller
    Figured how to install spirallocks and ***embled the short block on my 545 inch 460 stroker.
    40two, Latigo, Hombre and 3 others like this.
  24. RMONTY
    RMONTY
    Blew out the back wall of the shop for access to the new addition. Tomorrow is insulation and electrical day. Got a bunch of lights coming from Amazon on Tuesday. Moving right along! 20190406_153428.jpg 20190406_154951.jpg
    lothiandon1940, 40two, Hombre and 4 others like this.
  25. Deuces
    Deuces
    I should do that too my garage also... The alley was blocked off some years back and now I can extend the back 7 er 8 feet....:) Gotta check with the city first.... :rolleyes:
  26. David Gersic
    David Gersic
    from DeKalb, IL
    Finally finished re***embly of my engine and did the startup and break in today. Had a heater hose leaking, has now been replaced. Tomorrow I have some engine dress up items to install, and a tune up, then my 37 should be drivable again.
    And the forecast calls for rain.
    Hombre, osage orange and 61Cruiser like this.
  27. WB69
    WB69
    from Kansas
    Burned pastures again today...….almost done. Finally I'll be able to breathe again in the near future.
  28. 61Cruiser
    61Cruiser
  29. classiccarjack
    classiccarjack
    Week of busting a$$....
    New building foundation is poured. Now I can do other stuff as it cures. IMG_20190330_092722473_HDR.jpeg IMG_20190330_092727021_HDR.jpeg IMG_20190330_134856642_HDR.jpeg IMG_20190401_173653026_HDR.jpeg IMG_20190401_173704245.jpeg IMG_20190403_094048346.jpeg IMG_20190403_154858569.jpeg
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  30. gearhead1600
    gearhead1600
    Well it’s 2:34am
    Want to get up a 6
    Ahhhh
    Going to a model
    ( no not one of those )show 21/2 hours away
    but I worked on the flattie reverse sump
    For what ever reason ford never made a front sump flattie
    And I am probably the only guy that needs one
    But want to share this method of making a template to fill the void [​IMG]probably not a idea that hasn’t surfaced in the past but it was for me
    There has been a lot of Paper templates in my life .......
    This proved to be a time saver as it was cut out with a exato knife ( sorry for the spelling)
    [​IMG]and transfers easily to sheet metal (16 gauge)
    And yah finishing the day listening to Garden by the Groundhogs
    Happy motoring [emoji469]
