Technical Original 32 3 window fix !
Discussion in 'Traditional Hot Rods' started by Flop, Nov 18, 2017.
  1. Flop
    Flop
    Laying the cowl into the rocker
    Someday it will be done [emoji23][emoji23]
  2. alchemy
    alchemy
    Old Fords are a journey, not a destination.
    Chief 64 and The37Kid like this.
  3. Flop
    Flop
    Journey isn’t the word [emoji23][emoji23][emoji23][emoji23]
  4. pumpman
    pumpman
    Hey Flop, none of my business but just curious how many 32's have you done? Or you don't keep count and just keep track of your waiting list. I have to ***ume both are long.
    Flop and loudbang like this.
  5. Flop
    Flop
    Als27T, Stogy, mgtstumpy and 4 others like this.
  6. Flop
    Flop
    Moving along
    Now for a bunch of little things to tie up . Then a stock floor is going in .
    Als27T, Darryl Deir, ls1yj and 9 others like this.
  7. redoxide
    redoxide
    are you managing most of the lows with a puller ? thats a stunning result on the door skin..
  8. Flop
    Flop
    No sir that’s only good for sharp dents in my opinion . Not lows that are large and shallow . Most of it was brought up with hammer on a high crown dolly
    Darryl Deir, mgtstumpy, Stogy and 2 others like this.
  9. Uncle Phil
    Uncle Phil
    About another case of Arnold Palmers and you'll have it. ;)
    Stogy, loudbang and Flop like this.
  10. alchemy
    alchemy
    Do you use a bullseye much?
  11. redoxide
    redoxide
    are your arms made of super bendy pipe cleaner type things ? How do you manage to get in behind the skin.. ? Ive done a few big panels but I've often resorted to cutting out the inner structure, doing the planishing work and welding the inner back in.. or suffer being cut to shreds and a week of back and elbow pain having contorted myself into the best possible position to reach through the small access holes, but you never can quite get to the bbit you need to work.. :( Hats off to you, the finnish looks perfect ..
    Darryl Deir, Stogy, loudbang and 2 others like this.
  12. Beat the lower hinge back toward the rear of the car with a heavy hammer, 1 to 3 taps and you're set for even door gap.
  13. Flop
    Flop
    Find some ****ty dollies clean them up to your liking and weld a stick on em !! [​IMG]
  14. redoxide
    redoxide
    Arghh .. one of those super simple "why didn't I think of that" solutions, bet you experienced lots of bloodshed before you came up with that idea..
    Darryl Deir and loudbang like this.
  15. Flop
    Flop
    My dolly holding arm was my broken at one point arm so it told me no way from the get go .
    mgtstumpy, Stogy, Fordor Ron and 3 others like this.
  16. Flop
    Flop
    Someone’s bent the hell out of the front brace for the top wood so that had to come out
    Also the wood above the door is permanently in
    Als27T, ls1yj, mgtstumpy and 8 others like this.
  17. Flop
    Flop
    Shape I need
    Check strap thing in
    Package tray block
    Made a die to make this inset for the running board brackets that goes into the cross channels on the floor
    Als27T, mgtstumpy, loudbang and 7 others like this.
  18. pumpman
    pumpman
    Thanks for keeping us posted on your progress and craftsmanship Flop. Sooooo cool to see you in action.
  19. steve hackel
    steve hackel
    A question that most of us who play with sheet metal (old cars) , but few would come out and ask: what do you use for the cracks on and around your fingers?
    Short cuts and or suggestions would be greatly appreciated. Thanks
  20. Stogy
    Stogy
    I believe that is actually called dimpling as the material is to thin to countersink. There is to Male and Female Dies
    and it can involve several layers. Csk fasteners or rivets are the fastener of choice for this application.
    Always incredible to see your Metalsmithing Magic @Flop.
  21. Flop
    Flop
    Have to put it on an original fram to fit the new old floor pans
    De rusted the subrails
    Got the back riveted in
    Now for 347 spot welds hahaha
  22. hotrodA
    hotrodA
    Nothing better than watching magic happening. Amazing skills.
    Darryl Deir, Flop and loudbang like this.
  23. Flop
    Flop
  24. pumpman
    pumpman
    It's amazing the amount of work involved to bring them back to "Flop condition".
  25. donrob
    donrob
    from Ohio
  26. Flop
    Flop
    loudbang and Cyclone Kevin like this.
  27. Flop
    Flop
    Alll the details [​IMG]
    New original feet put on
    What an original looks like
    Bent the break like original
    Als27T, mgtstumpy, loudbang and 4 others like this.
  28. alchemy
    alchemy
    I can sympathize on those cowl band feet. I did a pair about a month ago. Henry sure didn’t want them to fall off.
    loudbang, Flop and Stogy like this.
  29. Always a pleasure reading your posts Flop, your skill level is insane.
    Darryl Deir, loudbang and Flop like this.
  30. Flop
    Flop
    I don’t m ow what they are cast out of but holy hell the hardness [emoji15][emoji15][emoji15]
