Technical hauling a parts car
Discussion in 'The Hokey Ass Message Board' started by topher5150, Apr 3, 2019.
  1. topher5150
    topher5150
    So the plan is to in the next week or two to make the two and a half hour journey to pick up this parts car. It's just the shell sitting on the frame, and the front axle. I'm rigging up some pneumatic dolly wheels to bolt to the back of the frame because there's no rear suspension. What's a good way to keep this thing on safely on the trailer?
  2. Wooden blocks underneath and straps holding down, to the front and to the rear
    scott27, blowby and patmanta like this.
  3. GordonC
    GordonC
    Two come alongs. One hooked to a front frame rail to keep it from sliding backwards and one hooked to a back frame rail to keep it from sliding forward. Ratchet straps to hold down hood/trunk and another couple to keep doors shut. Bring extra straps they are handy to have when doing this.
    WB69 and patmanta like this.
  4. don't forget the roll of Duct tape. Couple wraps around the B pillars, always works great on hold the doors shut. And what ever wants to take flight.
    scotty t, WB69 and patmanta like this.
  5. patmanta
    patmanta
    from Woburn, MA
    I always keep 4-6 ratchet straps in the truck. I'd chain it at one end and tighten it down with a come along at the other and then strap the whole thing down like a mental patient (and re-tighten the come along if need be). If there's a lot of loosies, maybe tarp it before adding straps. I like the duct tape too.
    czuch and GordonC like this.
  6. topher5150
    topher5150
    loosies????
    .....never mind, no loosies just the empty shell. Could I run some straps through the door openings?
    patmanta likes this.
  7. patmanta
    patmanta
    from Woburn, MA
    LOL, loose parts, stuff that's barely hanging on, etc.
    As long as the doors are strong enough to take a little tension, sure. You don't need to crank it down super tight, enough to keep the body put down on the frame would seem good to me. The chains/come-along will handle most of the load.
  8. squirrel
    we always used chains and boomers to hold s**** on the trailer....be sure to wire the boomers
    scott27, 1stGrumpy and WB69 like this.
  9. oldiron 440
    oldiron 440
    Hauling a parts car is little different than hauling a complete car and two come a longs isn't going to cut it. You still need four 3000 lbs straps on the vehicle and then you need to take care of all things that can blow off or from the car being towed. I have a large tarp that's four feet longer than my trailer for such loads, I then strap that down over the complete vehicle. Your responsible for every bolt and nut that falls from that gold mine your hauling home and the last thing you need is to pay for someone else to get a new windshield. Believe it or not a bolt on the trailer deck is an unsecured load and can get you a fine.
    scott27 and czuch like this.
  10. iwanaflattie
    iwanaflattie
    Bring a 4x8 plywood as a slide... U might need it
    scott27 and squirrel like this.
  11. topher5150
    topher5150
    not much there, he said that he wants to wait until it dries up a little to get his forklift out there.
    40ragtopdown and MO54Frank like this.
  12. Lower body and floor looks pretty good after all those years.
  13. topher5150
    topher5150
    that's why i'm jumping on it...and it has a Ford frame
  14. looks like a decent body and frame. I would leave it up on the blocks, get everthing out from underneath and back the trailer from the rear. should get you more than 1/2 way loaded. hook up the winches and start pulling. bring some wheels and tire to make the chore a little easier. even if the front drums are locked up, adding a set of wheels and tires will give you a lot more ground clearance for dragging it up on the trailer.
  15. WB69
    WB69
    from Kansas
    Awesome avatar!!
  16. WB69
    WB69
    from Kansas
    A must on wire tying the boomers....
    czuch likes this.
  17. J. A. Miller
    J. A. Miller
    from Central NY
    What crate engine is that? Doesn't look familiar to me.
  18. Mr48chev
    On that one chained or strapped (with 3000 lb straps) at the front and chained with Boomers or strapped with ratchet straps at the back and you should be good, A strap though the door openings might be insurance.
    Clean out any loose **** that might blow out that isn't part of the car before hitting the road. It isn't fun to roll up behind a guy towing a parts car and have trash blow out of it and bounce off your ride when you are behind him.
    Harbor Freight has boomers for 15 bucks each right now but I usually find them at yard sales and farm sales.
  19. The37Kid
    The37Kid
    Two Ford wheels and tires that hold air, and a trailer axle with wheels & tires and you have a roller. Attaching the trailer axle is your deal. :) Bob
  20. topher5150
    topher5150
    ok i give....what in the same hill is a boomer?
    rust runner, partssaloon and squirrel like this.
  21. squirrel
    also known as a load binder. there are two different types, the screw type, and the overcenter type shown here
  22. Snap, chain Binder
    they make a hell of a racket when they release. they will put a hurt on you if you don't respect them
  23. MARKDTN
    MARKDTN
  24. squirrel
    old used ones usually don't say "china" on them
  25. finn
    finn
    Sixty four entries in Wiki, and none of them relate to a load binder.
    Must be a Southwest colloquialism
  26. squirrel
    that is likely.
  27. patmanta
    patmanta
    from Woburn, MA
    Looks like a super rare Hosereel Rotary to me :D
    That's a really nice parts car!
    J. A. Miller likes this.
  28. GordonC
    GordonC
    Please, 2 come alongs not enough for that shell! He's not hauling from Cali to Maine! He probably doesn't have chain binders and large tarps laying around either, may have ratchet straps and come alongs, and they will be more than enough to handle that car. If its questionable throw a chain on the front and rear. Sheesh he isn't a professional trucker for heavens sake just a guy wanting to pick up a parts shell from what I can see.
    topher5150 likes this.
  29. redo32
    redo32
    Thanks. I thought I knew what they were talking about, but I never heard them called boomers. I figured it was a regional thing until Mr48chev used the term too. I guess I'm sheltered despite hanging out with truckers.
    partssaloon likes this.
  30. topher5150
    topher5150
    or i could just do this
