Projects ReBuild Of my 1928 Model A Tudor.
Discussion in 'Traditional Hot Rods' started by Cliff Ramsdell, Jan 12, 2019.
  1. Cliff Ramsdell
    Cliff Ramsdell
    @drdave ,
    Thanks for reading through my thread. I also have read your 4 door build, pretty cool there.
    Cliff Ramsdell
    drdave, loudbang and 48fordnut like this.
  2. Cliff Ramsdell
    Cliff Ramsdell
    Hi all,
    Haven't had time to work on the car and post. last year I got the gl*** for my car from a local gl*** guy, Todd at Vintage Gl*** in Rockville, CT. did all my gl*** and did a great job. I got the windshield in last year but all the side gl*** and related items were a winter project as is the rear window.
    I have this about 95% complete now and i'm working on the interior panels and some fuel system improvements, here we go.
    While I wish I took more pictures of chopping the windshield frame it was very straight forward. There are six screws that hold the top rail of the frame in place, on on the front and two on the sides. Take them out and tap the rail out and remove the old gl*** and webbing.
    I measured down the 3" that I chopped the top and scribed a 45 degree cut and just cut the ends with my 4" wheel. I remarked the holes on each side (note, use ends you cut off as templates for the screw holes) I blasted everything, painted with the old reliable krylon appliance enamel black and got ready for ***embly.
    Cliff Ramsdell
    Fitted the cut frame to the car for fit.
    No picture because I was working alone but I wrapped the gl*** welting around the gl*** and put the split at the top center. I use cleat packing tape to hold it to the window in about six places, sprayed the frame and welting with my favorite gl*** cleaner and it pushed right in.
    Tapped in the top rail, insert hardware and good to go.
    I installed the hinge on the car first leaving the hardware loose ish and slid it in windshield frame ***embly. attached all the small hardware and viola, done. Opens, closes, works. Onto the side gl*** next.
    brEad, OFT, drdave and 3 others like this.
  3. Cliff Ramsdell
    Cliff Ramsdell
    SO, as a preface to this next section I'll say this, If I were to build another car I would spend the money and buy the most complete car I could find. The nicer the better within reason. My body came with nothing, no latches, gl***, regulators, rear panels, trim, nothing and this stuff will nickle and dime you (well more like dollar and more dollars these days) the living **** out of you.
    I'm not going to say who not to buy from on the new repop stuff but I had excellent luck with Snyders and the quality of their parts, i'll explain more as we go. As for used OEM stuff, I tried to buy this stuff and it was either priced the same as new or so close that it didn't make sense or no go getting what I needed.
    So, without further ado, we will start with the rear side windows.
    Cliff Ramsdell
    So, like everything else the bracket that holds on the side panel for the window regulator was missing on the p***enger side of the car. I use a piece of 16 gauge, cut and bent, installed 10/32 riv-nuts and a cost of paint before the gl*** install. Prep also included removing the broken 10/32 screws for everything and tapping out all the holes.
    Laying out for gl*** install included installing the gl*** channels, cutting down the felts 3" because of the top chop and mounting the regulators to the rear panels.
    So, with everything out I installed the gl*** first. This allowed plenty of room to drop it down from the top. The tab on the bottom of the window runs goes in the bottom and I drilled for a screw in the top since we cut these down.
    I sprayed the window runs with some silicone and slid them up from the bottom, installing one and then the other.
    I installed the rear panel and regulator next. Since mine were missing I drilled out what was left of the rivets and installed riv-nuts there too, makes removal and install easy. All done with the rear gl***. Repeat for the other side.
    You'll need to glue the top seal in when the gl*** is installed. This allowed me the keep the window closed tight and hold the seal in place.
    '52 F-3, BradinNC, brEad and 4 others like this.
  4. Cliff Ramsdell
    Cliff Ramsdell
    The front gl*** is next. Again, I had nothing so I had to buy the gl*** runs, window channels, regulators, everything.
    I picked up a pair of gl*** channels from one of the specialty dealers and when I went to install them, well I thought I was going to break the gl*** doing it. No way, no how these were going on. One is bent all the **** and I finally gave up and spent the money for another pair from Snyders Model A parts.
    Gl*** on the bench, spray with gl*** cleaner, install the welting and work from one side to the other, done. Both installed in like 2 mins.
    Cliff Ramsdell
    The ones with the black finish are the "lesser quality" and the ones with the zinc finish, well I will say that they are a better product and may have cost a a few buck more but... you get what you pay for.
    As you can see this one didn't fair so well trying to install it. I only tried the one and I can't believe I didn't break a window.
    The one from Snyders was smooth as gl***, so to say to get installed. the windows are ready for installation. time to prep everything else.
    BradinNC, loudbang, brEad and 2 others like this.
  5. hfh
    hfh
    from Western MA
    Good luck with the weddings Cliff. It will be nice to have gl*** in your car. Will you cover the top too?
    loudbang and Cliff Ramsdell like this.
  6. Cliff Ramsdell
    Cliff Ramsdell
    One wedding down, Monday evening. next one is Saturday evening and the third isn't till September.
    I have two different top materials for the car. One is a canvas material as I had before, nice and light, good for keeping the beating sun off, not so good for keeping the rain out as we found a couple years back heading to the Old timers reunion in Lancaster, MA.
    The other is a heavier black vinyl material for the colder spring and fall seasons along with better rain protection to the limits of the top not being sealed tight.
    Cliff Ramsdell
    loudbang and drdave like this.
  7. Cliff Ramsdell
    Cliff Ramsdell
    The front gl*** was pretty easy once I got the gl*** channels taken case of. Again new gl***, runs, regulators and all.
    The gl*** runs needed to be cut down like the rears but they have hooks top and bottom to retain them in the door frames. I measured and cut them down and removed the retainers and had to reattach them. I used 1/8" rivets and took the center out. I just used an anvil and punch to flare them, worked perfect.
    All ***embled and now the side gl*** is complete.
    Cliff Ramsdell
    They get installed in each side and there is a spot for the clip on the top and bottom. The originals I have hears are flexible and can be pulled into place. I just bent the tab slightly, hooked them on the top and tapped the tab closed.
    With the window regulator installed, crank it all the way up with the arm sticking out the top like this. This will allow the regulator to engage the gl*** channel.
    Crank the window down and the regulator will engage the channel. There is a top plate for the door that I haven't finished or installed yet but as of now the car has 5 of the 6 windows installed with some misc trim work needing to be done.
  8. Cliff Ramsdell
    Cliff Ramsdell
    On a gl*** channel installation side note. I put the gl*** into the runs and marked the gl*** on each side so I knew where the gl*** channel should be installed. This allowed me to get it right without having to pull the channel off the gl***. I used gl*** cleaner instead of oil, its messy enough doing this job, slippery too.
    I hope all this helps someone else and that would make this worth the time posting.
    Cliff Ramsdell
    loudbang, brEad, chop job and 2 others like this.
  9. 48fordnut
    48fordnut
    Cliff you make it seem so easy. Pics are great.
    Another day inside.
    Good Luck with the weddings.
    jim
    loudbang, brEad and Cliff Ramsdell like this.
  10. Cliff Ramsdell
    Cliff Ramsdell
    You can pick and choose the pictures so you don’t see the huge mistakes and steps done like 4 times.;)
    Cliff Ramsdell
    brEad, 48fordnut and drdave like this.
  11. Cliff, your pictures and text will surely help others.
  12. 48fordnut
    48fordnut
    They sure make the path easier for some of us. Cliff has helped me with knowledge and parts ,plus videos.
    Awesome encounters on the HAMB.
    Thanks all,
    jim
  13. drdave
    drdave
    Thanks for all the pics and details Cliff! Big help. Redoing all the runs, channels and new gl*** is on the to do list for mine before I put the new interior in.
  14. Tim
    Tim
    from KCMO
    This is a huge help man! Between you and @Aaron D. I feel pretty confident in tearing into this stuff. Pictures are great
  15. OFT
    OFT
    Thanks for taking the time for taking pictures and writing posts. It will help many in the days ahead!
  16. David Gersic
    David Gersic
    from DeKalb, IL
    Curious why you did the wood on a table saw. Seems like both more dangerous than necessary, and harder. An inexpensive 10” band saw from HF or Menards, with a good quality blade, would make those cuts a lot easier, and without the risk of kickback.
  17. Tim
    Tim
    from KCMO
    Because that’s what he had, he’s talked about this more than once.
  18. jhexide
    jhexide
    Awsome ReBuild there Cliff,My Hats off to you...!!!
  19. Cliff Ramsdell
    Cliff Ramsdell
    David,
    As @Tim said, I only had the table saw. I took the chance and was prepared for the potential consequences best as possible.
    As with every build there is always something people don’t agree with. Cutting the wood was mine and while I didn’t agree some what, it was what I did.
    Don’t condone it, don’t recommend it. Did it, lived to tell.
    Cliff Ramsdell
  20. Cliff Ramsdell
    Cliff Ramsdell
    Thank you.
    Cliff Ramsdell
  21. Cliff Ramsdell
    Cliff Ramsdell
    Thanks Nick.
    Cliff Ramsdell
  22. sloppy jalopies
    sloppy jalopies
    lots of great ideas and the pix to show it !
    stopped by the local flee market every sunday morning,
    found the $15 Sears tabletop ban saw I was looking for …
    yet to need it but I will...
    Now if your next project was a coupester would give me even more ideas... er, changes... ha ha..
  23. loudbang
    Ha we all knew you couldn't put up with those inferior channels your build quality on all your projects is first rate ALWAYS.
    Cliff Ramsdell likes this.
  24. quickrack-alan
    quickrack-alan
    from Ireland
    Very cool Hotrod.
    Thanks for sharing.
    Other than being flat orange if mine I wouldnt change a thing.
    Cliff Ramsdell and loudbang like this.
  25. Tim
    Tim
    from KCMO
    Anything new?
  26. Cliff Ramsdell
    Cliff Ramsdell
    Hi Tim,
    Thanks for asking. It’s spring so my yard has taken over and work is 60 hrs a week busy.
    I have been working on fuel system upgrade and mods so that’s next along with finishing the gl*** install.
    Cliff Ramsdell
    drdave, loudbang and Tim like this.
  27. Tim
    Tim
    from KCMO
    Hopefully your getting some road time between chopping your yard down. It’s been raining non stop here for like three weeks. Barry have time to cut it before it’s three feet tall again lol
    brEad, loudbang and Cliff Ramsdell like this.
  28. Cliff Ramsdell
    Cliff Ramsdell
    Same here, I hit the mowing on the days it isn’t raining and I have some exterior house stuff to get done. Pressure wash the house and fences, paint some house trim and such but I got a killer jump on things and had some time to work on one of my carbs.
    Cliff Ramsdell
    brEad, drdave, loudbang and 1 other person like this.
  29. 30tudor
    30tudor
    Great stuff to say the least, anything new?
  30. Cliff Ramsdell
    Cliff Ramsdell
    Got the carbs done and on the car. Been doing some tuning on them and driving it 2 to 3 time a week back and forth to work.
    Fuel mileage was 9.7mpg local on my first tank. 500 miles or so later I have it dialed in to about 13.4 local driving, haven’t had it on a road trip yet, it’s been so busy.
    Working on the top right now, I’ll post more as things get finished and have some more tech stuff to post.
    Cliff Ramsdell
    90FD87BB-426D-49A5-9455-90D448CE9E91.jpeg C81A80C1-1C46-4177-AC04-954813EA5350.jpeg 23840026-CA93-48D8-B391-283B114DDDA1.jpeg 08A489E8-BA52-4AB5-BEDB-4D84EC4F8BDA.jpeg 869B6A74-FC43-4E80-891A-84768AB09789.jpeg
    phelan9251, Stogy, brEad and 7 others like this.
