Technical 1963 bel- air washer fluid bottle question
Discussion in 'Traditional Customs' started by trucker1, Apr 5, 2019.
  1. trucker1
    trucker1
    Hello, could someone tell me how far down the core support the washer bracket is mounted? I'm talking about the plastic part that hangs on the metal frame on the p***enger side beside the radiator. How far down from the top maybe with some measurements. Thanks, Glynn.
  2. saltflats
    saltflats
    from Missouri
    Goes on the drivers side, three existing holes, between the voltage regulator and the radiator.
  3. trucker1
    trucker1
    Thanks for your help.
  4. Never2old
    Never2old
    from so cal
    And do they repop the plastic tank?
  5. trucker1
    trucker1
    Yes I got mine from Cl***ic Industries in California. They have every related part and a whole lot more.
  6. harpo1313
    harpo1313
    from wareham,ma
    I think you will see the dimples for them .
  7. trucker1
    trucker1
    There is a rectangular hole the size of the bolt pattern torn out. I'll have to patch over the hole to make spot to drill holes. Some guys should never have been allowed access to tools. I need to get another core support since it's rusted out.
