Customs 1940 Mercury trunk handle nut- suggestions?
Discussion in 'The Hokey Ass Message Board' started by SlmLrd, Apr 4, 2019.
  1. SlmLrd
    SlmLrd
    from DAGO
    Hi guys, its been a while since Ive posted on the HAMB, but Im in a bit of a fix..
    I just had my merc painted and the trunk handle NUT got lost.. (its the nut that holds the handle in its base).
    Ive looked everywhere, you name it- no luck. The piece is a 59/64 -24 jam nut, as far as I can tell... Anyone have one laying around they'd sell or maybe a source where I can find one?
    Thank you.
  2. Jim Bouchard
    Jim Bouchard
    Looks like the same kinda nut that a 46 Ford uses.
    I think you can get those from Bob Drake and the like.
    SlmLrd likes this.
  3. fordflambe
    fordflambe
    I just sent a list of convertible top hardware to Totally Stainless. They have a machinist that can make one for you if you can give spec.
    SlmLrd likes this.
  4. pprather
    pprather
  5. SlmLrd
    SlmLrd
    from DAGO
    41-48 is different. I’ve checked everywhere, even bought one online just to see- no dice
  6. SlmLrd
    SlmLrd
    from DAGO
  7. Jim Bouchard
    Jim Bouchard
    I’d take the handle to my local machine shop with a description of what I want. I’m sure they could whip one up in under an hour.
    SlmLrd likes this.
  8. SlmLrd
    SlmLrd
    from DAGO
    Just spoke with a lady there. No help at all and rude as they come. Thank you
  9. woodiewagon46
    woodiewagon46
    from New York
    Just a shot in the dark but Model A dash light has a large nut, let me dig one out and check.
  10. gatz
    gatz
    SlmLrd likes this.
  11. woodiewagon46
    woodiewagon46
    from New York
    Sorry slim, just checked a Model A dash light nut and the ID is .774.
    SlmLrd likes this.
  12. woodiewagon46
    woodiewagon46
    from New York
    Another thought, some dash mount cigarette lighters have a nut like you need.
  13. woodiewagon46
    woodiewagon46
    from New York
    I just checked on E-Bay Motors, under 1940 Mercury Trunk Handle and there is a new aftermarket nut listed.
  14. 31Dodger
    31Dodger
    SlmLrd likes this.
  15. SlmLrd
    SlmLrd
    from DAGO
    The nuts listed are 41-48.. I ordered one just hoping, and my buddy gave me a 41-48 handle complete. Way too big..
    Also, if you look at the handles that are actually 41 Mercury, theyre missing the nut too- hahaha
  16. SlmLrd
    SlmLrd
    from DAGO
    Thank you.
    I just sent him an email
  17. SlmLrd
    SlmLrd
    from DAGO
  18. SlmLrd
    SlmLrd
    from DAGO
    Final resort.. Well see by monday. Thank you!
  19. pprather
    pprather
  20. Machine shop is your best bet, make some extras and sell some since they're so hard to come by. Or if you can find a tap the same size anyone with a lathe can drill and tap an existing nut for you.
  21. gimpyshotrods
    gimpyshotrods
    15/16" multiplies to 60/64", for comparison sake.
    That is 1/64th (0.015625") larger than 59/64". That would be expressed as 0.0078125" at the tip of the threads.
    If it is not really exactly 15/16-24, and it is actually 59/64-24, 15/16-24 will fit.
    I cannot imagine that 1/128" will make the handle fall out, or not work.
    If it makes you worry, put a single wrap of pipe thread tape on it.
    Also remember, if this is a jam nut you can use a Stover nut, which is effectively pinched, to create an interference fit with the threads. Others are similar in function
  22. gatz
    gatz
    ^^. Can easily be that much undersize, esp considering the process of mfg those.
    They weren't cut or chased; they were "as-cast".
    If you want the exact nominal thread spec, go to your machinist and have him check with "Pee Dee" wires to get the actual pitch diameter. He'll need to compare the measurement to the ones provided with the PD wires or those in Machinery's Handbook for the nominal O.D.
    gimpyshotrods likes this.
  23. fordflambe
    fordflambe
    Sorry to lead you that way. Hope i don't run into same issue as they have a pot load of my stuff right now.
  24. gatz
    gatz
    @SlmLrd
    So... what'd ya find out ?
    SlmLrd likes this.
  25. 54vicky
    54vicky
    he may have closed the trunk while inside?:eek:
    SlmLrd likes this.
  26. gimpyshotrods
    gimpyshotrods
    Uh oh!
  27. SlmLrd
    SlmLrd
    from DAGO
    Haha!
    After searching high and low, I ended up having my local machinist spin me up a couple... Now I can brag about my $60 hand made NUTS ;)
    X-cpe likes this.
  28. 40desoto
    40desoto
    Save yourself the headache, shave the truck handle and install a popper on the truck. [emoji12]
  29. SlmLrd
    SlmLrd
    from DAGO
    The headache would be shaving and metal working a freshly painted car. I kept my door handles, trunk handle because they work :)
