Projects NOT THE TYPICAL '30 ROADSTER BUILD
Discussion in 'Traditional Hot Rods' started by roll of the dices, Jan 1, 2019.
  1. roll of the dices
    roll of the dices
    Thank you
  2. roll of the dices
    roll of the dices
    A quick little update....
    Back from traveling for work and hoping to get some work done this weekend.
    Started by fabricating horns similar to the originals to be able to attach the rear crossmember to the Steadfast sub rails
    Started by putting a 90 to some sheetmetal in hopes to make a box. I could have gone to the metal place and could have gotten a square or rectangular but figured to use what I had.
    Once I had the metal boxed in, I put the radius to copy the original. I added a cut out on the bottom to be able to have access to secured the crossmember when the time comes.
    I now should be able to run a bolt from the rear corner of the body down into the cross member and secure it to this tail piece. The tail piece will be welded to the sub rail and that should solve that. At least in theory, I think it works...
    Let's see what tomorrow brings...
  3. roll of the dices
    roll of the dices
    Got some more work done on the crossmember ends. Using all the original attaching points on it. It should be nice and solid at the end.
    All together I have about 6 hours on these.
    Unfortunately, the welding part of it is what is taking me the most time...still not good enough at it.
    I am still struggling with weld penetration, speed and heat. I have what I think is a good solid weld but once I grind it, it cracks, showing penetration wasn't right. After a couple trials I get it right but it takes time.
    Good thing I have patience and have come to I love welding....
    My beads are getting better, not such thing as roll of quarters style beads....mine look more like loose change in my pocket :) but getting better
    Still need to properly squared the openings at the bottom.
    I made a base to prop the crossmember against the bottom of the car, since both corners are shot, and start tracing the sub rails to it.
    It should help while blending the two pieces together..
    Sub rails pitch down 10 degrees. and crossmember ends will come straight in to these.
  4. roll of the dices
    roll of the dices
    Slowly but continue making progress...
    Started working on the corners to bring strength back to them and be able to attach the panel below the deckled and eventually the crossmember.
    The return flange was very damage mostly held together by rust itself. This is the first thing to tackle.
    The corner bottom flanges were the crossmember attaches to were also gone beyond repair.
    I replaced those too.
    Holes for the bolts will be added later, once I match the crossmember to them.
    Spot welded in place for now. Will fully weld once the corners are fully repaired
    Panel below the deck now has something to attach back to it.
    Looking good for now.
  5. brEad
    brEad
    Looking good!
  6. roll of the dices
    roll of the dices
    ***embled the rear and started to squared the body off. Things are starting to take shape.
    Distance from the rear/side of the frame to the inner wheels wells are equal...a good sign!
    The piece of wood is prying the body over from the rear cross member to help center it. Once the rear sub rails are in place the body will have some structure back to it.
  7. sloppy jalopies
    sloppy jalopies
    my sportster quarters sag out not in... fixes ?
  8. vinniedatorch
    vinniedatorch
    Nice build, I'm starting a coupe and doing sub rail kit. Lots of questions on where and how they fit.
  9. roll of the dices
    roll of the dices
    Take your time with it. Measure 3xs and then cut.
    I've been fitting everything loose and clamped in place. In my case, there has been a lot of remove, remeasure, reclamp and move to the next piece.
    I am getting closer to the point where can start tack welding together but I want to almost fit everything and test that it works before start tacking.
    The rails for me didn't fit, at all, the way I was ***uming they would fit.
    Somehow, in my non-experienced mind, I was thinking they were going to run along centered on the frame, and somehow they were going to transition onto the rear crossmember.
    Well, my first surprise came when I realized that the new sub rails are not the same width as the originals. and that's why the "hats" come with it, and most installation I've seen, they blend the two where these meet.
    I cut mine at the starting point or front of the rear wheel arch, where the originals reduced in width; mostly, because the area in front of here was in good shape and the rear part was not.
    I see several people cut theirs 4" to 6" from the rear of the door. Not sure what the advantage of this is but what I did seemed to work for me. I was afraid to cut them further forward and weakened even more the already flimsy body.
    Once I recreated the cut out of the rear arch, the sub rails were pretty even along the way with the frame, but again, they sit wider on the rear than they do in the front.
    Bolt everything on, I will be bolting my deck lid tomorrow. Bolt as much as you can before tacking or welding.
    In the process, I've seen my rear quarters sag in and by the next adjustment I see them sag out, so bolt as much as you can.
    That's all I can say for now, since that's how far along I am in. Good luck!
  10. roll of the dices
    roll of the dices
    I started the work on the left subrail. The right side is pretty much done and so far, happy with it.
    I cut the front bottom of the wheel arch to expose the original rail. The side has some rot while the top appears to be nice and solid. I will cutting the side of the new sub rails long to splice into the existing one.
    I traced the scoop out of the original rail on the new subrail. I should be easier to blend once is all done
    I ran the side of the new subrail longer so I can splice on the existing and remove some of the damage rail along the way.
    Fitting nice against the frame and against the rear wheel well....and it is symmetrical to the right side...what do you know, I am happy!
    Tomorrow, the plan is to bolt on the deckled and to start blending in the support for the rear crossmember to both rails...Keep making progress!
  11. sloppy jalopies
    sloppy jalopies
    Thanks for the play by play, perfect timing...
    The angled braces that run from the rear of the quarter window down to the base of the B pillar on the '30-'31 coupes usually rust off at the subfloor.... the rusted ones are cheap and ready to cut down to the length you need in the trunk... that is what my sportster's trunk will get when I get back to it...
    oliver westlund likes this.
  12. roll of the dices
    roll of the dices
    Couldn't get much work done today. Real work got on the way.
    Still got an hour to spare, so I started thinking how to rework the rear corner braces and supports to fit the new rails.
    The supports will be easiest, just cut them to size, following the angle of the brace, and attach it to the sub rails same as original.
    The corners were a bit more involve but not bad. Stated with a cardboard template. Thank you USPS!
    Clamp it in place, trace the subrail, and look for the best fit and areas to trim.
    With some t*******, the original pieces will work just fine and the brace will sit behind it.
    The corners still will have the two holes to attached the curve trunk piece.
    You can see how little material I need to remove, to make the corner braces work.
    I will cut out the dimple and add metal to make flat so I can spot weld to the bracket that will run behind it.
    Feeling good about these!
  13. roll of the dices
    roll of the dices
    Got another hour of work in. I doing all I can to spend at least some time on it everyday.
    I've been getting requests for pictures from underneath looking up at the rails. You can see how they taper out. They are flush to the outside of the frame, where the rear wheel wells start and the at end of the frame they are out about an 1" out
    That's what I meant above by saying they don't seat dead centered on the frame. You can see the different color marks, as references, as I have been adjusting the position.
    Today, I trimmed back the rear of the sub rails and mounted again the rear crossmember.
    Now, I have a clear view of the transition between the two and plan to blend them both together.
    The outside of the crossmember now allows me to attach the rear wheel well same as it was originally.
    Once I fix the corner and install the new wheel wells it should look good.
  14. Malcolm
    Malcolm
    from Nebraska
    Looks like you're doing a fine job! Good choice on the Gary Maxwell frame. I also have one under my '28 Roadster and I've been very happy with it.
  15. roll of the dices
    roll of the dices
    Thank you.
    Agree. That frame is awesome. I wish my skills were anywhere near that. :)
  16. roll of the dices
    roll of the dices
    She is not going to win a beauty contest but I think I got her done.
    It is just tacked in place, as I am sure I will be reworking it before final welding it.
    thumbnail_IMG_4487.jpg thumbnail_IMG_4488.jpg thumbnail_IMG_4489.jpg thumbnail_IMG_4490.jpg thumbnail_IMG_4491.jpg
    It does what it needs to do.
    ...and off to the other side...
  17. roll of the dices
    roll of the dices
    A good day today. I finished tacking the other side sub rail and got the deck lid mounted on.
    Here is the driver side all tacked. Same as the right side, not winning a beauty contest but doing what is supposed to do.
    thumbnail_IMG_4500.jpg thumbnail_IMG_4501.jpg thumbnail_IMG_4502.jpg thumbnail_IMG_4503.jpg thumbnail_IMG_4504.jpg thumbnail_IMG_4505.jpg
    The cut out for the rear wheel well
    The deck lid mounted back on and the side gaps are looking fairly good. Looks like the back remains pretty squared.
    Love the look of that quick change peeking underneath!
  18. sloppy jalopies
    sloppy jalopies
    roll,
    Great work on the "how to" on the rear subfloor...
    I am not cutting my '32 rails like the As...
    I will piecut the '32 rails so they dip downward...
    will let the rails slide under the rearmost crossrail, letting the body sit flat on the center of the frame …
    will then weld A frame horns to the piecut '32 rails but upside down...
    will mount a stainless spreader bar between them...
    your post shows me the angle change from '32 back to level and the subfloor's offset involved... cool !
  19. roll of the dices
    roll of the dices
    Sounds like a solid plan. I am tuned for your built.
    Looking forward to it
  20. drdave
    drdave
    Just now tuning into this. Great start, and I have to say, your fab and bodywork skills exceed some I've seen out of "pro" rod shops. Humility and an honest ***essment of one's own skill level goes a long way to making sure you stay on track and end up with a good result. Gives you time to take it slow, study, learn, ask questions as opposed to blowing and going. ;) Really enjoying what you are doing and looking forward to where this is going.
    Kodak Jack likes this.
  21. Peanut 1959
    Peanut 1959
    I'm just now joining the fun, also. Great thread with lots of good detail. And I'm a kustom guy, so roping me in for a hot rod build is quite an accomplishment! [emoji39]
  22. roll of the dices
    roll of the dices
    Bit of a slow day today...but a productive one.
    Stating to secure the body to the frame and starting to measure the wood blocks to ensure the doors fit and close properly.
    Started by securing the package tray to give the body all the rigidity possible. Just now I realize that i should have secured the fuel tank too to keep the front from bowing.
    Front blocks are 1-1/4" but most likely will end up at 1". The middle blocks might not be needed and the webbing might be enough.
    The crown on the doors is sitting nicely against the body. I might have to rework it a bit, to get it to sit flush.
    Not sure how close is suppose to fit to the body but as of now, it is as close as it should.
    The gaps in front of the doors are starting to come together. The driver side fits better, even top to bottom, The p***enger side wedges top to bottom.
    I may end up adding metal to close the gaps...3/16" finish gaps would be nice
    The upper belt moldings are starting to line up correctly. too The driver side looks better than the right one.
    The belt molding in the aftermarket door skins are a bit wider than the rear quarter panels....might have to do some cutting and diccing to fully get them to match.
    Gaps in the inside are looking nice and even around the door.
    Doors are closing with no effort and locking very nicely. Even my younger daughter can close and open them :)
    I will do some more adjusting tomorrow and see if I can get all the minor misalignments to fit better. I might have to settle for what I have, since the doors are closing so nicely right now.
    Once I get everything fully line up, it is welding time for the sub rails!
  23. roll of the dices
    roll of the dices
    A lazy Sunday. Spending time with the family.
    No progress this weekend but always time to find inspiration in others and move forward...
    47a7391f81a4aa16aa172abd499db86a.jpg 867dc767e1b8ff3a36cdd5d8e8440d44--poker-street-rods.jpg 82930f397bb9_low_res_1932-ford-roadster.jpg b68b330ff230762d2247762efcb4421e--le-mans-vintage.jpg
  24. brEad
    brEad
    Looking good, you’ll get it all fit.
  25. sloppy jalopies
    sloppy jalopies
    Mikie gives his vote to the light blue, tan top, '32 grill, maybe general jumbo wheels rig... yup.
  26. roll of the dices
    roll of the dices
    Not a lot of progress. Just working on adjusting the doors and making sure the body is straight and square before I start spot welding things in place.
    Mostly going back and forth on adjusting the body, playing with wood block heights and different amounts of tightening on the bolts to see what feels good.
    Bolting the fuel tank, or whatever is left of it, made a big difference. Those bolts are 10-24s for of those like me that struggle finding bolts sizes.
    I am very happy with the way the doors are fitting. Took a bit of persuasion with a woodblock in a corner and the right amount of pressure on the other. The gap down the side is looking nice and tight.
    The p***enger door locks a bit easier and better than the driver size door but I think at this point I am just splitting hairs.
    I will be moving to the rear sub rails again in the next few days.
    The plan is to mark the holes for the frame and insert and weld a metal tube to the sub rail to avoid crushing the rail when tightening the bolts down. Those frame bolts are 3/8-16....yes, I do struggle finding the right bolt size.
  27. brEad
    brEad
    The fit on the doors look excellent to me. I’m sure it is better than when the car was new.
  28. GordonC
    GordonC
    Doing some nice work! I want to warn you that after you hand sand all those louvers a couple times you will only be able to pick your nose with a knuckle!:D
  29. roll of the dices
    roll of the dices
    Thank you! Hope they stay looking this good.
  30. roll of the dices
    roll of the dices
    LOL...I believe that! I
    That black paint looks beautiful!
