Technical Bob Drake U Joint
Discussion in 'Traditional Hot Rods' started by Branded, Apr 8, 2019.
  1. Branded
    Branded
  2. Bursonaw
    Bursonaw
    I am using one on my 36 Ford and I have had no issues. It is high quality.
    I have also used an original Lincoln U-Joint on my 41 Ford for over 40 years and it is still runs strong.
    Hope this helps in your decision.
    Sent from my iPad using Tapatalk
  3. I installed one 4 years ago, have over 5000 miles on it since, no issues, seemed to be well made.
  4. Branded
    Branded
    I’ve read ! The u-joint doesn't tighten up against the rear out put bearing thus allowing the output shaft to move forward and trash the front synchronizer.
    With the u-joint installed and the bolt and washer tightened up the u-joint can be moved about 1/4" in and out on the output shaft. With the bolt tight the u-joint should tighten against the rear transmission bearing to prevent any movement of the output shaft.
    Fairlane500 likes this.
  5. rusty valley
    rusty valley
    that is correct, with the bolt tight, output shaft should be tight against the bearing. i cant believe drake would make that mistake. while i dont like his business practices, "back order bob" usually makes pretty good stuff. just my opinion, never used the lincoln joint or heard of the issues
  6. rusty valley
    rusty valley
    quite a bit of chatter over at the barn on this, good thing you asked over there !!
  7. Branded
    Branded
    Yes there is, I think I’ll stick with the tried and true Ford U joint. Probably take a stab at rebuilding my original u joint, can’t be that much to it.
