Hot Rods Crude modification picture thread
Discussion in 'The Hokey Ass Message Board' started by adam401, Oct 28, 2018.
  1. Sometimes they get refined.
    This car is now owned by @1934coupe's brother powder blue with Olds power
    At the U.S. Nationals
    upload_2018-12-24_13-8-27.png upload_2018-12-24_13-9-53.png upload_2018-12-24_13-10-13.png
  2. I sold these a few years ago.
    Vintage tow Hubs, for flat towing stock cars
    [​IMG][​IMG]
  3. Casey Riley
    Casey Riley
    from Minnesota
    I'd give anything to see a pic of that.
  4. If I find them I will post them.
    kidcampbell71 and loudbang like this.
  5. alanp561
    alanp561
    Nice pics. Been there, done that. Worked well.
  6. mgtstumpy
    mgtstumpy
    BB Mopar powered 34 Dodge coupe, tubbed frame rail supports behind the axle coil overs with wide offset rims. That 3/4 depth notch for ladder bar clearance doesn't leave a lot of strength above (2"x1") given the depth of the notch. That diagonal brace doesn't really do a lot either and is pretty agricultural.
    alanp561 and chryslerfan55 like this.
  7. A pair of old Stock Car wheels that were halved long ago.
    I am in a quandary with this do I fix them to race on my vintage car, or leave them alone and use them to put the car on and off the trailer?
    I don't dare use these for real racing!
    upload_2019-4-13_17-15-15.png upload_2019-4-13_17-16-56.png upload_2019-4-13_17-18-2.png upload_2019-4-13_17-18-54.png upload_2019-4-13_17-20-17.png upload_2019-4-13_17-21-21.png upload_2019-4-13_17-22-9.png
  8. mgtstumpy
    mgtstumpy
    Jag IRS install gone wrong, WTF :eek::eek: An out of work engineer?
  9. DDDenny
    F#@k me!
    chryslerfan55 and mgtstumpy like this.
  10. Colin HD
    Colin HD
    OMG!! WTF? Two washer !?!?
  11. mgtstumpy
    mgtstumpy
    Wait, there's more. It gets better :eek::eek::eek:
    Steering column shaft
    Motorcycle frame repairs
    Driveshaft
    Leaf spring shackle mount
    Welded brake pedals
    Brand name IFS. It just goes to show that even the professionals sometimes get it wrong; poor quality (Inadequate) welding, design and fit up.
    Jet96 and chryslerfan55 like this.
  12. mgtstumpy
    mgtstumpy
    Can you belief this brake push rod!!! :eek::eek:
    That's only a seat cushion hold down bolt!!
    Lowered coil springs, a little bit of heat will give you the desired ride height:D:D
    dan31, GuyW, Jet96 and 2 others like this.
  13. mgtstumpy
    mgtstumpy
    Wheel spacer ring
    Brake pedal push rod
    47ragtop and Dave Mc like this.
  14. mgtstumpy
    mgtstumpy
    Brackets on wrong side of panel, no radius on corners etc
    Bump stops
    GuyW, 47ragtop and Dave Mc like this.
  15. 26 T Ford RPU
    26 T Ford RPU
    This was on my RPU, it filled in where the old steering column was. JW
    GuyW, Jet96 and mgtstumpy like this.
  16. mgtstumpy
    mgtstumpy
  17. bschwoeble
    bschwoeble
    Please, no more. My brain can't take it. What hurts is there is more of this than you think.
    sidevalve8ba likes this.
  18. Yes, the modern stuff that has snuck in makes me cringe as well.
    I think this thread was intended to do***ent what was done in the early days before the 1-800 speed shops.
    When you made do with what you had.
    A time when if you wanted a hot rod or race car you had to build it.
    If you didn't have a tubing bender you used a hand grinder to fish mouth tube or simply mitered it
    patmanta likes this.
  19. alanp561
    alanp561
    Clean up the welds in pics 3 & 4, run a hot p*** of 7018 over them, run them. What's the problem?
  20. alanp561
    alanp561
    X 2
  21. I know I can fix them, it's the fact they have been this way 20 maybe 30 years before I was born. (1981)
    They have history this way. A true pioneer did this, I am just a guy trying to emulate the past what gives me the right to change it?
    427 sleeper likes this.
  22. 62rebel
    62rebel
    Wtf is that? Sheet metal? JFC
  23. Surely you can’t be serious.
    VANDENPLAS likes this.
  24. DDDenny
    Yeah, that one needs to be in wiring books under "don't do this"!
  25. 62rebel
    62rebel
    WTF in the world are people thinking
  26. They think plenty, just not past the end of their nose. That’s pretty ingenious, needs power out of that wire and gets it. No knowledge or thought of anything beyond that. Sort of like an animal with opposing thumbs,,,
    VANDENPLAS, chryslerfan55 and 62rebel like this.
  27. BamaMav
    BamaMav
    from Berry, AL
    I think of something like that wiring every time I read somebody talk about running a wood screw into a 12 volt battery to get 6 volts out of it. It might work, but just think, is it RIGHT?
