City: Orange County State: California Price: $28k OBO USD So the time has come let her go. FOR SALE MY 1931 Ford Model A Roadster. All Original Henry Ford. Lincoln Zephyr, Mercury and Studebaker parts exempt the body, body is Brookville -Brookville 30-31 Roadster Body -1931 Ford Model A frame -1932 Ford K Member and Pedal ***embly -Original 1932 Ford Grill Shell and Insert -1941 Mercury Flathead w/ Harrell Heads -Harmon Collins Cam -Harrell Dual High Rise Intake w/ 1939 Lincoln Zephyr LZ Stromberg Carburetor -1939 Ford Transmission with 25 Tooth OEM Lincoln Zephyr gears -Spalding Brothers Lincoln Zephyr V12 Distributor converted to V8 by Jerre Jobe -Model A Rear End with OEM Ford 3:54 gears -1932 Ford Heavy Front axle -1932 Ford Unsplit Wishbones -1932 Spindles -1940 Ford Juice Brakes all around -1931 Houdaille Lever Shocks all around -1932 Ford 18" Wire Wheels -1921 Ford Model A Roadster Leather Bench seat -1932 Ford Dash with 1932 Studebaker Dash Insert, all gauges have been refurbished and functional -1932 Steering Column with 33-34 Ford gears -1939 Lincoln Zephyr Steering Wheerl. The 17" one 1932- Ford Gas Tank installed in the trunk I built this car with a vision of a PreWar Hotrod. Car is still on 6volt, starts right up no problem. Using a 6volt Optima battery. Car made July 2018 issue of Ol' Skool Rodz Jimmy and Omar at Circle City Hotrods did the metal work. Recessed the firewall, welded motor mounts, cut down the 32 Ford K Member to fit and weld into the Model A frame. If you have any questions about the car and price, DM. Car is running great and have taken it on the freeway at high speeds. Car is ***led as a 1931 Roadster. Email agonzalez@sdcoc.net Phone 714 922-5081 Archie-
