Technical Does any recognize what car this came from? Temperature gauge
Discussion in 'Traditional Hot Rods' started by THIRDPEDAL, Apr 16, 2019.
  1. THIRDPEDAL
    THIRDPEDAL
    Picked this up at swap , would like to find matching oil pressure , I’ve checked high and low , any help in identifying would be appreciated (it’s going in my 30 ford coupe )Thanks again IMG_2763.JPG IMG_2790.JPG IMG_2792.JPG
  2. alchemy
    alchemy
    Autocar trucks and Cords had a very similar gauge design, except I've only seen them with maroon outer rings and yellow lettering. The Autocar and Cord have the rings silkscreened on the center like yours too, but the wrong color. All I can say is they are probably late 30's and made by Stewart-Warner.
  3. HOTRODPRIMER
    HOTRODPRIMER
    It looks like the kind of gauge that was used on old White & Freight-liner cab-over trucks. HRP
  4. pprather
    pprather
    Neat looking gauge. Hope you can determine it's origin and find the oil pressure companion.
    Phil
  5. THIRDPEDAL
    THIRDPEDAL
    Thanks for leads ,
  6. goldmountain
    goldmountain
    Why run this gauge Anyhow? The Bourdon tube is broken off and it pegs at 220. Most pressurized systems can run a lot hotter than that.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  7. 51504bat
    51504bat
    Maybe he's gonna run it in a flathead. If so Williamson's can repair it with a new sending bulb.
  8. alchemy
    alchemy
    Probably because Summit has the Dolphin gauges on back order.
    F&J likes this.
  9. manyolcars
    manyolcars
  10. BJR
    BJR
