Technical Frame clearance at rearend
Discussion in 'Traditional Hot Rods' started by four5four, Apr 15, 2019.
  1. alchemy
    alchemy
    Your subrails aren't sacred. Just Z the frame back there a bit and trim the inside of the subrails a little. If you want a hot rod you have to cut a little metal.
    four5four and XXL__ like this.
  2. RICH B
    RICH B
    Similar to guitar's suggestion, raises the rear cross-member for added clearance. Looks like it would entail some sub-rail work. ( FYI the ends of the tube and boxed A frame were filled when completed)
    four5four likes this.
  3. I never understood that frame of theirs
    It’s supposed to take an A body without modification to body or sub rails and get the important part of a 32 frame under it.
    Its going to be a high boy and that’s that.
    Until you want to lower it and now nothing is right and everything you paid for is useless. All of that convenience is gone.
    We’ve got to modify the “innovative” part of the frame back to traditional practices and then cut the body which this was supposed to stay intact. I can see why nobody would want to do that
    what the hell do they do with all the 32 tails anyway?
  4. four5four
    four5four
    from omaha
    No, axle tube will hit first and i still have clearance at the driveshaft loop crossmember. If the rear gets notched for clearance plus the 2" for compression it might get close. I will get some better pictures tomorrow
    Model A coupe. And there is a body mount at the rear most framerail.
    This was one idea I had if it would be strong enough?
  5. four5four
    four5four
    from omaha
    I got a deal on the frame, so now I have to work with what I got. Looking back I should have done full 32 rails. With the funny rear crossmember the body goes right on without any modification it just sits really high in the rear. I have a 7.50-16 tire and the wheelwell body line was 4" above the tire. I want it where it is now, just following the top of the tire.
    How it sat before I switched to the lower coilover hole.
  6. guitarguy
    guitarguy
    Yes, it will be plenty strong enough. You have to have overlap of the two rails.
    Rich B's pic I am reposting below is how you would do it. Close in the ends of the box and original frame and weld everything all around. If you need to drop the crossmember to where it was, add another piece of box tubing under the first higher piece you welded in. Effectively creating a C-notch--see the second pic for reference. Yes, you will probably have to make mods to the body to get it to sit back down.
    I know it's not a hot rod, but you get the idea of the C-notch with the front and rear original framing.
  7. Now you know why you got a deal on it
    That’s your normal high boy stance
    Bottom of frame (lowest line) thru center of wheel. It’s lifted 4x4, ground clearance
    You ain’t stuck with it, just bite the bullet and change it.
    XXL__ likes this.
  8. wuga
    wuga
    Add body weight, a tank of gas, either rear seat p***engers or a trunk full and a rough road. You are in trouble. Change the kick on the frame.
    Warren
    F&J likes this.
  9. Dino 64
    Dino 64
    from Virginia
    2BA6A85A-92C6-479E-8377-A36708A8BDCD.jpeg 1E3BD102-ED09-4992-A6F5-AD70ECC16DB9.jpeg 67E297B5-5B3A-4514-92D7-C334E4AA34B7.jpeg 23797AC5-448C-49DC-8E6B-7463C07BA6BC.jpeg This might help, I had a similar problem and C’d the crossmember to provide clearance. Added a piece of same size square tube, then made the cut out.
  10. Dino 64
    Dino 64
    from Virginia
    Pics out of order:rolleyes:
  11. Ebbsspeed
    Ebbsspeed
    I ***ume the appearance of this is due to some front-to rear angling of the C-notch tubing, which makes the two notches look totally mis-aligned.
  12. I had to rake the rear tails way up in order to get this to set right like four inches up to get the car Four inches down
    Its not to terribly difficult
    Figure out exactly what you want and draw up exactly what you want
    Put it together
    Wrap the edge with some Strap
    And it's a frame,
    It was boxed later
    Here you can see the lowest line is far below the rear tire centerline
    Dino 64 and four5four like this.
  13. guitarguy
    guitarguy
    I noticed that myself----just a quick pic I grabbed off the net.
    I was more trying to drive my point of carrying the front and rear halves up and over the axle for him.
