Technical Help Flat head only runs while key is turned
Discussion in 'The Hokey Ass Message Board' started by Youngster51, Apr 16, 2019.
  1. Youngster51
    Youngster51
    from Fresno ca.
    I just picked up a 53 Ford Victoria with a older rebuilt flathead that hasn’t ran in a few years. I tried starting the Flathead and it would only run while the key is turned and cranking I can rev the Flathead using the key also which is wild. So far I have replaced the plugs, plug wires, coil, ballast resistor, key switch, new battery, rebuilt carb. It is getting fuel checked spark from coil and spark from cap to plug all have great spark. The Flathead has been hopped up and is running a Mallory unilite distributer. I can not figure out why as soon as I let off the key it dies please help
  2. TrailerTrashToo
    TrailerTrashToo
    Symptom indicates no voltage on the coil when the Key is in the "ON" position. Break out your voltmeter (or test light). Check the voltage at the ignition coil with the key in the "ON" position. I suspect that the wires to the ignition switch are in the wrong places.
  3. m.kozlowski
    m.kozlowski
    Or ignition switch is broken.
    clem likes this.
  4. Kiwi 4d
    Kiwi 4d
    So the starter is spinning and the engine is running let the key go back to power from the start position and it dies, correct?
    If this sure seems like a bad ballast ,though you have checked this , is it worth trying another ballast?
    Saxman likes this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    If that’s the case, it seems odd your starter hasn’t burnt up. Even Being engaged at a low idle would be the end of that starter. Please let us know what you end up finding?
    egads likes this.
  6. GTS225
    GTS225
    Youngster; In the "start" position, the ignition switch byp***es the ballast resistor, but in "run", power goes through the resistor to the coil.
    Trailer Trash's suggestion is a good one, as you say you've replaced the resistor. Check that out, and if it doesn't help, look into the voltage requirements for that Unilite. The ballast resistor drops the voltage down to give longer life to the points and coil. Might it be to low for the Unilite to operate?
    Roger
    Atwater Mike, ClayMart and Saxman like this.
  7. sunbeam
    sunbeam
    You are only getting power from the resister byp*** terminal on the starter solenoid.
    Atwater Mike likes this.
  8. 32phil
    32phil
    from New York
    The first thing I would do.....
    If it has a conventional Ford solenoid I would check to see if the main feed for the whole car is on the wrong side of the solenoid. You're looking for a larger wire about 10 ga. with a large loop connector big enough to mount on the solenoid. It's probably on the solenoid where the battery cable from the solenoid to starter cable attach. Move it to the other side of the solenoid where the battery cable FROM the battery is.
    When you turn the key you energize the solenoid/starter and the car will start and run....it stops running when you let the key go because it's dropping the main power feed when the starter drops out.
    I think......
    alanp561 likes this.
  9. Youngster51
    Youngster51
    from Fresno ca.
    I put a test light on the positive side of coil while key is on and no power. the hot wire coming from the Mallory unilite is not running thru the ballast resistor it is mounted to the positive side of coil. on the ballast resistor there is a wire running to a switch under the dash and a wire running from the switch to positive side of coil
  10. Youngster51
    Youngster51
    from Fresno ca.
  11. TrailerTrashToo
    TrailerTrashToo
    1. Most likely, wiring error at the ignition switch.
    2. Or defective ignition switch.
    With the test light, start at the ignition switch a verify the switch positions, i.e. OFF, ACCESSORY, RUN and START.
  12. Mr48chev
    SWITCH UNDER THE DASH! did you turn that switch on or see if there is power to it? My guess is that someone put it in the line either as the primary ignition switch after the ignition switch went bad or as an anti theft device or otherwise disable the ignition. Check to see if you have power to that switch with the key on (or off for that matter and then power coming out of it.
    X-cpe and TrailerTrashToo like this.
  13. AChopped1950ford
    AChopped1950ford
    With the mallory unilite distributor you do not use a ballast resistor, I believe your wiring is not correct, simple repair though.
  14. How the **** do you rev the engine with the key?!? WTF is going on.
    Google Mallory unilite wiring
    No power out of ignition switch in run position ???
    Or
    No power to coil in run position ??
    Petejoe likes this.
  15. BJR
    BJR
    When you find out what the problem was, please let us know and thank whoever gave the correct solution.
  16. sunbeam
    sunbeam
  17. Youngster51
    Youngster51
    from Fresno ca.
    I squeezed under the dash and started following wires from the ignition switch and ballast resistor the switch was good found that the switch was wired into the headlight switch and the electric fan switch so to start the engine you have to have the headlights on fan on and the switch to the ballast resistor on... kill switches was the problem thanks for all the responses
    AChopped1950ford and alanp561 like this.
  18. ClayMart
    ClayMart
    I think it's like when your car won't start and you instinctively turn the key harder, hoping that by doing so it will make it start. :mad: Except it usually doesn't. And you end up twisting the key off in the ignition lock. :oops:
  19. See how simple that was :p:D
    They wired it like the green acres tractor
    Bet the dome light needs to be on for the blinkers to work,,, at least the door opened
    AChopped1950ford likes this.
  20. Atwater Mike
    Atwater Mike
    Yeah! ,,,At the Junctionnn.......
  21. blowby
    blowby
    from Nicasio Ca
  22. AChopped1950ford
    AChopped1950ford
    Glad you got it figured out.
