Technical ***April 2019 Banger Meet - No fooling - just 4***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 31, 2019.
  1. ratamahata
    ratamahata
    from Argentina
    Maybe the tube drain the excess oil from the front timing gears or the entire valve case? I don't see any return tube like the model A engine!
    Sent from my Mi A1 using The H.A.M.B. mobile app
    Jet96 likes this.
  2. Crazydaddyo
    Crazydaddyo
    That may not be a return. That may be a supply for a external oil pump. Returns rarely went to the bottom of the pan. The returns would have better effect to dump into the valve chamber or on to the timing gear.
    Sent from my SM-J320P using The H.A.M.B. mobile app
    Jet96 likes this.
  3. Jet96
    Jet96
    from WY
    Crazydaddyo- that could be, I sure wish I had another angle on that side of the engine. That engine is pretty cool any way I looked at it.
  4. railcarmover
    railcarmover
    Ideal 'quench' is .040,quench is the distance from the piston crown to the head at TDC..
    JT1930 likes this.
  5. burl
    burl
    from Minnesota
    Working on something similar but a little different.I have better picks I will post later with more of the finished parts together.It took a lot of trial and error to get the brake/clutch pedal shaft in the right spot for everything to work.Had to narrow up some of the areas on the pedals were they ride on the shaft to get them in the right spots to work correctly. Had to reshape the edge of the brake pedal where it hit the steering column as well.Theres not a lot of room in that space to get it to work like it should.I like the support bracket for the shaft shown in your pictures as mine needs more support for the downward pressure the clutch pedal makes when its pushed in.
  6. V4F
    V4F
    from middle ca.
    I have ross pistons that are 0000 out of bore ……...
  7. V4F
    V4F
    from middle ca.
    BURL , what pressure plate & clutch disc is that . looks good
  8. rwrj
    rwrj
    from SW Ga
    Burl,
    Isn't that a Volvo transmission?
  9. burl
    burl
    from Minnesota
    Yes it is I like to go against the grain in the end I hope it all works
    barrnone50 and Dannerr like this.
  10. burl
    burl
    from Minnesota
    Volvo Amazon
  11. burl
    burl
    from Minnesota
    Old Dawg and Dannerr like this.
  12. V4F
    V4F
    from middle ca.
    thank you
  13. V4F
    V4F
    from middle ca.
    has anyone tried a ceramic resistor with a resistor coil ? im killing coils faster than I can buy them ………. apparently not a good idea . talked to fsi , could harm things .
  14. rwrj
    rwrj
    from SW Ga
    Burl,
    Those are great transmissions. I want to try one of the ones with the Lay**** OD. I have one, but it's hooked to a real healthy b18 engine, so I'm not anxious to break that pair up.
    Dannerr likes this.
  15. winduptoy
    winduptoy
    No, haven't. So you are running 12V?
    Sent from my XT1254 using The H.A.M.B. mobile app
  16. winduptoy
    winduptoy
    So my OHV in the Vicky runs really good but....the block is cracked and no miracle in a bottle works.
    The cracks had been bondo up and painted over. The machine shop in Wyoming, Michigan, that I got the engine from, represented it as 'ready to install'. I've had to go thru the head as the valves were so sloppy and rockers so worn it was totally unsatisfactory.
    I'm going to lace the cracks with 10-32 hardware screws. After wasting two and a half days talking to s***ch-n-lock folks I've decided to do what I've had success with in the past. I'm using Lock***e and peening the end of the screw... IMG_20190420_095301990.jpg IMG_20190420_095304684.jpg I'll post finished photos
    Dannerr likes this.
  17. ^^^Are you saying THAT's repairable??^^^
  18. Jet96
    Jet96
    from WY
    Damn that's a shame!
    winduptoy likes this.
  19. V4F
    V4F
    from middle ca.
    what the heck happened ?? bummer
  20. V4F
    V4F
    from middle ca.
    yes but was told by FSI not to …… I trust them !
  21. winduptoy
    winduptoy
    Yes, I believe that it is. I am relearning things that I did a long time ago..and had a mentor....should have listened closer when he said "put attention"
    There is a technique and I recall the principles. I got the one on the right laced up. I found that there has been nickle welding on the cracks and I got into some hard stuff, really hard.
    I'm taking a break and I'll post some photos later.
    I haven't shown a photo of the crack under the water pump on the front of the block
    Got to pull the radiator
    Dannerr and Jet96 like this.
  22. winduptoy
    winduptoy
    Yes it is. I don't care, just tell me what I am getting ready to buy and don't represent it as something it isn't.
    I'm wanting to take this to the dirt drags and I clearly can't run it this way. I'll make it better or worse...but then It will be my fault.
    This is a B block and they have a reputation for having 'thin deck' material.
    The material really isn't very meaty here, about 3/16". I suspect someone got it really hot and put cold water in it....more than once. There is also collateral damage from the welding repairs. The only real way to weld cast iron is to preheat it in a furnace for around 850-900 degrees F. Then touch weld with cast rod. Then you have to have a controlled cool down. The existing welds weren't done that way.
    I really can't loose anything here
    Dannerr likes this.
  23. IMG_2160.JPG Anyone have a single intake they’d sell? Realized I can’t fit the flange on the right way after welding it on. Going on a budget banger project!!
  24. winduptoy
    winduptoy
    Dannerr, Binger and Jet96 like this.
  25. noboD
    noboD
    The machinist in me makes me want to do this sometime, just don't want to HAVE to on my own engine. Hope it works for you. In that area couldn't you braze it too?
  26. winduptoy
    winduptoy
    You can do this...I know that you are patient. The problem with brazing is multifold. The cast will continue to crack in the heat zone between the chilled and the hot material....you can chase a crack all over. Termination of the crack is difficult. Once the area is brazed you are committed...no turning back.
    I'd had to dis***emble to a point, at least taken the head off. I'm still working on the technique but it is coming along. IMG_20190420_124343078.jpg
    Dannerr, G Baese, Jet96 and 1 other person like this.
  27. JT1930
    JT1930
    Getting close.
    barrnone50, Old Dawg, Dannerr and 3 others like this.
  28. Jet96
    Jet96
    from WY
  29. Jet96
    Jet96
    from WY
    Only other pic of that Cragar banger I have.
  30. winduptoy
    winduptoy
    Jet96 likes this.
