Projects '24 T Roadster build
Discussion in 'Traditional Hot Rods' started by Anderson, Aug 21, 2012.
  1. 51box
    51box
    from MA
    Anything new happening?
  2. Anderson
    Anderson
    As mentioned in post 1 of this thread...I had a couple "dramatic" years and deleted just about everything in this thread. That was weird! I'm over it now...sorry to all who were watching. Wanted to fix this for a while now and currently have a good bit of free time on my hands so I'm going to add as much back in as I can. This'll certainly be a digest version of the build. I sold the car back in June of '16 and it went over to Japan.
    As it was listed for sale, purchased from Flip in Santa Cruz via eBay. flips t 005 (800x600).jpg
    And delivered to me in Garland, Tx by BenD
    Not much room in the garage so it stayed in my living room until I moved to Rowlett. I collected windshield posts and chopped them, and a very nice polished V860 front axle.
    Once moved the real work started. It was originally set up for a flathead but I picked up a '49 Olds 303 to use.
    Motor mounts modified from some available Hurst reproductions
    Wanted to use quarter elliptic springs up front so I cut some factory spring perches to weld into the V8-60 axle
    This was the first spring setup hacked together from a cut up speedway spring, I later changed to a Posies setup
    Everything mocked up again
    The frame originally had a suicide style perch but I wanted a T crossmember
    Made some hybrid front wishbones from Model A yokes and '42-'48 bones.
    I wanted a full frame around the windshield so I used parts from two originals
    Heavily modified a '30 firewall
    Used a cross steer '35+ box turned 90 degrees to point the pitman up
    Transmission crossmember
    Shock mounts with the headlight bar tying them together
    Front crossmember replaced here with large square tubing notched for radiator clearance.
    Recessed a couple gauges into the firewall
    Getting ready to move to Austin Tx at the end of '14, here she is all ***embled and ready to go
  3. Anderson
    Anderson
    Had a couple weeks inbetween jobs after moving and got a lot done on the car.
    Had the frame blasted, boxed it and cut out the cowl hoop
    Worked on a column drop and dashboard. Dash started a '38 Olds.
    F1 pedals installed an clutch linkage done
    Floor structure built
    Major upgrade with a Rodsville quick change
    Cut down a '50 (I think) Olds wheel
    Built some new structure around the door
    Here's the newer spring setup
    Added a flange around the firewall
    Wanted less of a kick up on the body so I did a piss-poor job of making new pieces with what I had at home. Also raised the deck 2"
    Had to re-angle the deck as well since it changed as it rotated up on the curve of the rear of the body. Began filler pieces underneath.
    Ended up making a new rear body panel, again not very well with what I had at home.
    The frame was pretty much done at this point so I cleaned it up and primed it. Had the front end chromed and painted the wheels.
    Before I moved to Austin I was doing engine machine work for a living and machined the block. Once in Austin I found a shop to machine the heads for me. Got it all put back together.
    don colaps, Vic Walter, Tim and 14 others like this.
  4. Paul
    Paul
    Editor
  5. Anderson
    Anderson
    Realizing that the pictures on my computer aren't in any kind of order so I apologize that they are a little disorganized here.
    Built floors and a trans cover from a heavily modified '37 Zephyr piece and tied it all into the firewall.
    Built a seat from some round tubing and plywood
    Modified a speedway stainless tank
    Some inner door structure and latch mounting
    Built a battery mount
    Finished up the headers. These are in earlier pictures in various states, ***embled from a Gear Drive driveshaft style kit
    Best option for a radiator was a cheap aluminum one but had to stretch the shell to cover it all up.
    And unfortunately the most practical option for a fan was an electric one. Made a mount and shroud for it that wasn't quite so ugly.
    Somewhere along the line I rebuild the '39 box
    Shaved the fins off of some no-name covers for a Gotha/Isky look
    Started some quick and dirty bodywork and got the car in primer, then painted the firewall to match the drivetrain
    Something else done along the line was modifying the belt line to continue uninterrupted all the way to the cowl. I cut the bottoms off of the windshield posts and welded studs to the back side so no hardware would be visible.
    By now I brought the car up to my workplace to get it finished for the Roundup, '15
    The car mostly ***embled.
    Deck primed...had to change steering wheels temporarily as the Olds wheel wouldn't let my knees fit in the car!
    Spent a couple days wiring the thing
    I believe this was taken just after the first drive around the parking lot
    The only thing missing was a windshield which I couldn't get cut in time.
    Made it to the show and had a good weekend overall.
    And finally back home in one piece
    Flipper, Vic Walter, Tim and 14 others like this.
  6. Anderson
    Anderson
    The Monday after, Tim from Hop Up came and took some great pictures of the car. Then I just enjoyed it for a while, fiddled with a few things and getting it all to work right. I had a major driveshaft issue which I worked out, changed the fuel pump, added a couple leaves to the rear spring, some other odds and ends.
    This was a **** Spadaro u-build it setup...guess the 303 had a little too much torque. It was replaced with a shortened solid shaft.
    Drove out to Wimberly with the Mrs. for some lunch
    It didn't take long for me to want to improve on the car though. I had gained a lot of sheetmetal fab knowledge and wanted to apply that to the car. Apart it came for a bunch of upgrades.
    Big change #1 was a '40 dash.
    The wheels I had on the car were 4.5" rear and V8-60 3.5" fronts. I worked a trade for a set of chrome 4" wheels and kept my tires.
    I also wanted to try my hand at redoing the deck. I had seen a Ron Covell DVD on doing the same so I gave it a shot. Made hammer forms for the sides from MDF and plywood for the rest of the buck.
    I had access to a pullmax at the workplace and was able to punch the beads in the quarters.
    It was close in appearance as a stock deck but I didn't run a bead around the bottom or front edges and made the deck lid fit flush with model A style hinges and a '32 latch.
    Since I made the deck as symmetrical as possible, I found that the body tub itself was pretty far off from when I did the work the first time. Took a lot of cutting an filling to correct.
    I made new lower louvered filler pieces that fit much better as well.
    This sides belt line was never level to the driver's side as it should have been and the door was actually crooked in the body. I cut out and rebuilt most of this side of the car.
    I made a roll pan for the deck the same way as the deck itself and bolted it underneath. It has a notch just enough to access the quick change.
    Another change was putting a reproduction early Corvette steering column in. I wanted turn signals (though they were never wired) and to use the Oldsmobile wheel.
    I had to get another fuel tank to modify and relocate the filler to the center which I thought looked better.
    Flipper, 49ratfink, Tim and 11 others like this.
  7. Anderson
    Anderson
    The only other change was to Arrow 775 headlights from what I cant remember I used before.
    I had been without hubcaps on these wheels until this point because before chroming, they had been polished so much that the nubs would not hold onto a hubcap. I built the nubs up with weld to put my Merc caps back on.
    And that's it. I held onto this one longer than most cars I have done and really enjoyed building it. But after so long in a roadster I decided I wanted a coupe (which I got and promptly got rid of in favor of another roadster) and couldn't afford to both build and own another car. I don't regret selling it, but it is by far my favorite car that I have built and I do miss it.
    Flipper, gonzo, Paul and 27 others like this.
  8. OFT
    OFT
    Wonderful build!!! thanks for sharing!
    Anderson likes this.
  9. mkebaird
    mkebaird
    Very nice, probably my all time favorite Model T. Thanks for posting!
  10. chop job
    chop job
    from Wisconsin
    kidcampbell71, Stogy and Anderson like this.
  11. Old-Soul
    Old-Soul
    Without a doubt one of my "top ten" model T's, caught myself wondering what happened to it/you the other day when I was ****ing around on IG.
    If you don't mind me asking, how tall are you? How did you find it to drive?
    brad2v likes this.
  12. Anderson
    Anderson
    Thanks! I’m 6’. I wish the car had a taller windshield on it and I was getting ready to make a new taller one before I sold it. And I struggled some with leg room, first using the repro ‘55 wheel with a big offset to clear my knees. Then later changed to a longer steering column with the flat Olds wheel. Forgot a picture but the gas pedal was up high over the side of the trans cover. It was a pretty comfortable spot though you wouldn’t think so.
    Old-Soul likes this.
  13. brad2v
    brad2v
    Hmm, I was also wondering about it the other day. I always loved it, neat car. Do you know if it ever got paint?
  14. Anderson
    Anderson
    It did. The car kinda went a different direction by the time it was finished but of course the only way to control that is to finish them myself for a change. The work done on the car though was very nice. Really, I don't think I'd mind it at all if they'd just put the windshield back on.
    Paul, Tim, D-Russ and 8 others like this.
  15. tjm73
    tjm73
    I love this car. One of my top 5.
  16. The 39 guy
    The 39 guy
    Anderson, thanks for the update! You did a great job on the car!
    Blue One and Anderson like this.
  17. Dan Hay
    Dan Hay
    One of my favorite T's! And yes, the windshield needs to go back on.
    Tim, Anderson and Blue One like this.
  18. brad2v
    brad2v
    I looks good, but I sure would have likes to see it completed to your vision of the lighter blue metallic, with the gold engine. Where did your valve covers go?! Agreed, definitely needs the windshield
  19. Anderson
    Anderson
    They’re floating around Japan somewhere. I’ve reached out multiple times to try and buy them and the Star emblem I put in the radiator shell back but never got a reply.
    Stogy likes this.
  20. alchemy
    alchemy
    I don’t mind the longer exhaust, but the stock valve covers are definitely no improvement. Black is a good color on that car. Maybe a buckskin colored leather seat though.
    Tim likes this.
  21. Great to see you added the pics back to the thread, one of my favourite Ts. I agree it needs a windshield.
    A couple pics I saw on IG
    16465478_744485845716744_6363191093533605888_n.jpg 16465685_159805397852724_2090781257829974016_n.jpg
    D-Russ, A Boner, Stogy and 3 others like this.
  22. Tim_with_a_T
    Tim_with_a_T
    My favorite T. Thanks for re-sharing your build.
    brad2v and Anderson like this.
  23. dumprat
    dumprat
    from b.c.
    Agreed ! Awesome car.
  24. DeadFast 33
    DeadFast 33
    from Santa Cruz
  25. I've always loved this build. Thanks for the quick recap. Enjoyable to see the whole build again!
  26. ol'stinky
    ol'stinky
    from New Jersey
  27. topher5150
    topher5150
  28. Blue One
    Blue One
    from Alberta
    Let’s see. Now we have this.
    382F6E77-2768-47C2-8D57-17A61483F977.jpeg 570E084B-3728-4672-AF69-376DD341424B.jpeg
    But first we had this.
    Maybe I’m the only one but I’m just not really liking the Japan version of the car.
    I thought it was pretty much perfect the way you built it to begin with Eric. :cool:
    don colaps, Tman, Tim and 6 others like this.
  29. For once we agree on something @Blue One ...;)
    jebbesen, Tman, Tim and 4 others like this.
  30. touring20
    touring20
    The guy who has a 24 t build is a member of the HAMB His avatar name is anderson
