Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. Keep up the great work, Matt!
  2. x77matt
    x77matt
    Major body work complete. Just doing some work now on the lower rear tail panel water drain system and then I will do some final hammer/dolly and shrinking work to get ready for body work...
    20190324_111601.jpg 20190324_111611.jpg 20190324_120219.jpg 20190324_120206.jpg 20190324_202336.jpg
    brEad, Shadow Creek and loudbang like this.
  3. ct1932ford
    ct1932ford
    Great coverage and work!:cool: Keep those trunk bumpers. The new ones I have found are much smaller.
    x77matt and loudbang like this.
  4. x77matt
    x77matt
    Thanks! Your roadster is one of my favorites! The bumpers are older Brookville I believe....
  5. x77matt
    x77matt
    Hollywood license plate light and 39 ford taillights mounted.
  6. 1-SHOT
    1-SHOT
    from Denton
    I use my TIG on most of my welding , in the body shop I used a MIG and the new Compression Spot Welders. But I can still make a spotweld looking weld with OX/ACTE and br*** it's a trick I learned a long time ago.
    Atwater Mike, sko_ford and loudbang like this.
  7. x77matt
    x77matt
    Yeah- I'm now pretty much exclusively using my TIG unless I need to do some fast welding that doesn't need to get body worked. Oxy weld still to get tight shrinks in or something delicate.
    Atwater Mike and loudbang like this.
  8. The37Kid
    The37Kid
    What a nice build, I have no idea why it took so long to find it. Bob
    Atwater Mike, loudbang and x77matt like this.
  9. x77matt
    x77matt
    Played with the seat this week. I made a bottom for it with cutouts for the webbing, reworked the bottom metal bracing, and then welded in some 1/2-20 bungs to bolt it in to the cross braces. For now it's roughed in for the mockup. I'll foam it later when I get upholstery done.
    deluxester, Stogy, 51box and 3 others like this.
  10. x77matt
    x77matt
    Improved the body bracing a bit today with some right and left hand 1/2-20 clevis and threaded bungs so I can adjust the door gaps and body easier after paint.
  11. x77matt
    x77matt
    Filling holes today :
    Also, ordered some seat webbing for the seat suspension, and the seat foam should be ready on Monday from the water jet cutter
  12. Travis latour
    Travis latour
    from Putnam CT
  13. qzjrd5
    qzjrd5
    from Troy, MI
    Looks awesome. Taking notes!
  14. touring20
    touring20
    Who made the patch panels you decided on to use ?
  15. Harms Way
    Harms Way
    The body bracing is genius !.... very ice
  16. x77matt
    x77matt
    The 1/4 panel patches were an ebay purchase that I re shaped in the shrinker. Driver side lower is from a brookville 2nd, and the door lower patches I made out of a compound curve roof panel from a 50's car that had a good crown. The eBay door lower skins are really poor . Not good fit, and no compound curve.
    sko_ford, Stogy and loudbang like this.
  17. x77matt
    x77matt
    Thanks! It's a 4 bar mechanism so you have to move both at once to get the body to move much. I'm sure there is an even slicker way to do it, but this will work for now!
  18. x77matt
    x77matt
    Spent a lot of time this weekend tightening up the metal lumps. The panel above the decklid needed about 18 shrinks in it to get all the oil canning and lumps out! The p***enger side quarter top started to come around today after several shrinks and a lot of hammer and dolly. Now, I'm no flop, but I should be able to get it to the point where it needs just a thin skim of filler to be ready for filler primer.
    20190422_111557.jpg 20190422_164210.jpg 20190422_180508.jpg 20190422_180516.jpg
    ct1932ford, 51box, brEad and 6 others like this.
  19. touring20
    touring20
    Er , what is a flop ? ?
  20. x77matt
    x77matt
    Hamb member @Flop is what I meant. Amazing talent- I don't have his talent, so I will do my best to get by with just a skim coat of filler
  21. x77matt
    x77matt
    Foam came in today. I need to take a couple inches off the bottom to lower the seated height, but the overall profile turned out nice.
    ct1932ford, deluxester, 51box and 5 others like this.
  22. stinson
    stinson
    from alabama
    Just curious where did you get the webbing and foam? Looks great
  23. 2deuces64
    2deuces64
    Did the foam come precut and shaped ? Also what is the metal in the seat back for? Your doing a great job!!
  24. x77matt
    x77matt
    Webbing I got on ebay- I got a huge roll for like $40 and then the foam came from a local store. It's called "Foam and more" and they specialize in recovering furniture but have a huge foam selection. They can wire cut small sections from a template and glue them together, or in this case, I paid extra for them to set it up in a water jet and they were able to do a full width cushion with my templated profile.
    Thanks- the metal is just sheet aluminum I'm using for door panel backing. It's just setting on the seat to get it out if the way.
    rpm56, Nailhead A-V8 and loudbang like this.
  25. 383deuce
    383deuce
    Nice work
    x77matt likes this.
  26. continentaljohn
    continentaljohn
    Any updates
  27. x77matt
    x77matt
    Hey- yes, slow progress. I’ve been prepping the body for paint - basically skim coat of filler everywhere, block sand and repeat. To be honest, I was a bit ebarr***ed to show you guys this part as I didn’t totally metal finish it as much as I originally envisioned, but rather got it pretty darn close and then relying on a skim coat to finish it off.
    I’ll post some pics from my other phone tomorrow...
  28. Deuce Daddy Don
    Deuce Daddy Don
    If you need FOMOCO blueprints with all stock measurements, I sell the roadster body & frame prints.------Don
  29. x77matt
    x77matt
    Hey Don- I've got your quarter panel print- do you have the other body parts now?
  30. pprather
    pprather
    Just like prepping a new Brookville body.
    Phil
