Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. mgtstumpy
    mgtstumpy
  2. mgtstumpy
    mgtstumpy
    OT Poncho however interesting reading, seems everyone tried OHC engines at ssome stage!
    Stebo27, egads, 63fdsnr and 3 others like this.
  3. mgtstumpy
    mgtstumpy
    Picking up where I left off, https://www.jalopyjournal.com/forum/threads/unusual-engine-photos.1123661/page-34#post-12991062
    The induction on the OHC engine on the bottom of p. 30 appears similar to that used on the experimental 1961 Pontiac Tempest Monte Carlo that was fitted with 195ci Pontiac four cylinder engine (1/2 389ci) and a Mickey Thompson supercharger system (GMC 3-71 blower) feeding the carburetor and adapted to the blower with a special elbow.
    Hot Rod Magazine produced ant article in March '68 on Pontiac' overhead cam (OHC) V8 engine and one of its first 'Cammer' engines. This test mule was built in late 1963 using a basic 389ci block and fitted with unique 4 valve per cylinder heads with dual overhead camshafts (DOHC) and a special cross ram intake manifold fitted with sequential port fuel injection. It never progressed beyond developmental testing.
    Stebo27, egads, Deuces and 4 others like this.
  4. mgtstumpy
    mgtstumpy
    OMG, an air cooled flat 10 Impala engine based on a Corvair flat 6. :eek::eek: Purportedly this power train led directly to the development of FWD Oldsmobile Toronados as it had been experimenting with FWD cars from the late 50s and seriously contemplated building a FWD car in or about 1961. The rest they say is history.
    OT marinised LT5
    motoklas, Stebo27, Deuces and 2 others like this.
  5. loudbang
    1912 Mecer 35C Raceabout
    1914 Rolls Royce Silver Ghost
    1947knuck, motoklas, Stebo27 and 4 others like this.
  6. Tree Fifty
    Or a slant sticks
    40two, VANDENPLAS, inaford30 and 6 others like this.
  7. loudbang
    1908 Mors Grand Prix
    1947knuck, Stebo27, mgtstumpy and 3 others like this.
  8. mgtstumpy
    mgtstumpy
    Stebo27, loudbang, Fordors and 9 others like this.
  9. mgtstumpy
    mgtstumpy
  10. mgtstumpy
    mgtstumpy
    Stebo27, egads, loudbang and 4 others like this.
  11. mgtstumpy
    mgtstumpy
  12. mgtstumpy
    mgtstumpy
    Stebo27, Deuces, egads and 4 others like this.
  13. mgtstumpy
    mgtstumpy
    A bit more on the Tornado flatty conversion in post #1095, again in Museum of Speed
    Stebo27, Deuces, egads and 3 others like this.
  14. mgtstumpy
    mgtstumpy
    Here's a rare NOS 350SBC Hemi that was listed on E-Bay in 2014, with a starting bid of $30K. :eek: Where it is now is anyone's guess
    Engine came complete with a plethora of parts and do***entation to support its providence and authenticity. Purportedly the Museum of Speed has one of these engines as well however I can't seem to locate anything on it. The heads featured hemispherical combustion chambers by Leo Lyons and came equipped with fuel injection and a magneto. They were built for drag racing and roundy roundy tracks. Speedy Bill Smith allegedly purchased his engine from Mauri ROSE, who was planning to run it in the Indianapolis 500.
    https://www.speedville.com/leo-lyons-chevy-hemi-pops-ebay/
    This was the Museum of Speed link on it's engine however it's not currently active.
    http://www.museumofamericanspeed.com/Chevrolet-Small-Block-Leo-Lyons-Hemi-Head-Conversion,9115.html
    A did a bit more research and discovered some trivia that pieces the puzzle together, ROSE may played a part in the R&D:-
    • Post WWII, he was an engineer who just happened to be a race car driver; and
    • After retirement he returned to engineering full-time with a number of enterprises including GM where he helped Chevrolet establish its presence in both hod-rodding and stock-car racing.
    These hemispherical heads are totally different to the rare factory GM 302SBC hemi heads I posted earlier (#1004). Carb intake as well as fuel injection intake. I can't locate anything else on this rare engine apart from a 2014 HAMB post where it was listed for sale, hasn't been on forum since 2017, for $60K :eek::eek: A quick flip and profit, maybe? actually he's the same E-Bay seller. It was also featured on Bangshift.
    .... 1 of 3 known to exist LEO LYONS ORIGINALS!! There's one in the Museum of Speed, owned by Bill Smith. The second is in private hands of Walt Austin, and BOTH of these are cast iron block engines. This engine was found sitting in storage for over 30 years. It's the only known ALL ALUMINUM example ever done!! The wife of the original purchaser found it in her storage and sold it after her husband's p***ing. EVERYTHING with it is brand new from 1978 and this engine has NEVER BEEN ***EMBLED!! Parts list includes, DONOVAN serial#0015(yep thats the 15th block DONOVAN EVER BUILT and if you speak with **** Crawford down at Donovan, he still remembers doing this very block!!), 350 small block chevy 4 bolt main block with cam bearings installed(4" bore)....
    E-Bay description:-
    • Donovan small-block Chevy 350 aluminum block
    • 4-bolt mains with No. 0015 cam bearings installed
    • One pair of small-block Chevy Hemi aluminum heads complete with valve train components (A-356 Prime at T-6 with heat treat)
    • Donavan intake and exhaust valves, one pair of copper head gaskets
    • One complete set (10) of Arias forged racing pistons 4.00 with wristpins and ****ons
    • One set of Speed Pro rings 4.00
    • One set of Carillo Rods with de-burred corners on the caps for bolt clearance (and shot peened caps)
    • One No. 4340 Billet steel crankshaft (Moldex) with a 3.625-in. stroke and knife-cut edges
    • Iskendarian camshaft with reverse-rotation distributor and cam gears
    • One complete set of Iskendarian roller tappets
    • A set of 4130 steel push rods (heat treated, and hard chromed)
    • Mackay water pump
    • Two aluminum water outlets
    • Aviad dry sump pump and drive, a Harrison oil cooler
    • Aviad Metal Products custom dry sump oil pan
    • Complete set matching pulleys
    • Timing chain cover
    • Complete set of head bolts
    • Valve covers with gaskets
    • One pair of top-mounted Offenhauser breathers
    • Eight high-performance spark plug wires and eight aluminum spark plug carriers aluminum
    • One set of plastic spark plug insulator tubes
    • Aluminum valley cover plate
    • Enderle fuel injection intake and one Leo Lyons carburetor intake
  15. mgtstumpy
    mgtstumpy
  16. loudbang
    1902 Mors Type Z
    1947knuck, Stebo27, Deuces and 3 others like this.
  17. XXL__
    XXL__
    1953 Gordini
    Stebo27, Deuces, 63fdsnr and 5 others like this.
  18. loudbang
    1930 Duesenberg J Phaeton
    Model T touring
    1947knuck, Stebo27, Deuces and 4 others like this.
  19. loudbang
    1908 Delaunay- Bellville
    1930 Duesenberg
  20. loudbang
    Factory photo of 1964 experimental Pontiac 421 Sohc
    1engine Rare factory photo of Pontiacs 1964 experimental 421 SOHC engine.jpg
    1933 Buggatti type 55 Super Sport
    1947knuck, motoklas, Stebo27 and 3 others like this.
  21. loudbang
    1927 Lancia Lambda Torpedo
    1947knuck, motoklas, Stebo27 and 2 others like this.
  22. loudbang
    1919 Ballot Indy car
  23. loudbang
    1931 Bentley supercharged
    1947knuck, motoklas, Stebo27 and 5 others like this.
  24. XXL__
    XXL__
    1931 Bugatti Type 54
  25. XXL__
    XXL__
    Auto Union V16 Type C...
  26. loudbang
    1936 Bentley 3.0 liter 100 Super Sport
    1930 Bentley Speed 6.5 liter Speed Six
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I wonder what that gizmo is sticking out of the rear of the RH cam tower on the 1931 Bugatti Type 54? Maybe a magneto - adjustable from the driver's compartment?
    Deuces and loudbang like this.
  28. 28dreyer
    28dreyer
    from Minnesota
    Exactly, mag drive shaft to ****pit mounted mag.
    And check out the robust right angle gear driven blower case.
  29. loudbang
    1932 Bentley Corsica
  30. loudbang
    1939 Bentley A 4 liter
