Projects East Coast Hustler 30 coupe AV8
Discussion in 'Traditional Hot Rods' started by Phil55Kratz, Mar 24, 2019.
  1. Phil55Kratz
    Phil55Kratz
  2. 'Mo
    'Mo
    You will need to join in order to view its contents. I recommend it. It is a very active community in the "real world".
    mo
  3. Phil55Kratz
    Phil55Kratz
    Crawled around like a worm for a couple hours and got my brake lines mostly done. I need some fittings and some adel clamps and hopefully that’s a wrap. I also gotta do the ebrake stuff but I’ll figure that out later.[​IMG][​IMG][​IMG]
  4. catdad49
    catdad49
    Phil, this is a sweet little rig. That rear under panel is a stout piece, great work!
    Phil55Kratz likes this.
  5. Phil55Kratz
    Phil55Kratz
    Thank you! Can’t wait to get this thing on the road.. list seems to be growing.. that’s how it goes though
    catdad49 likes this.
  6. 3banjos
    3banjos
    from NZ
    Cool build, and thread saved for future reference. Keep spreading the Hamb gospel.
  7. Phil55Kratz
    Phil55Kratz
    Thanks !!
  8. Phil55Kratz
    Phil55Kratz
    Flipped the steering balls around for the tie rod and drag link to clear. Still need to find a better driver side arm as it’s pretty worn out. Maybe I’ll just replace the balls on it...
    catdad49 and stinson like this.
  9. 3banjos
    3banjos
    from NZ
    Interesting the shallow spring shackle angle. I've had a few A axles and most of them had shackle wear on top of axle. I guess the only way to alleviate that problem would be a slightly shorter spring.
  10. Phil55Kratz
    Phil55Kratz
    Yeah it looks like it touches but it has 1/4” or so underneath of clearance... I’m also planning on changing the spring too
    catdad49 and Stogy like this.
  11. JimmyD3234
    JimmyD3234
    from PA
    Looking good nice little ride :cool::cool:
  12. Phil55Kratz
    Phil55Kratz
    Thanks[emoji106]
  13. redoxide
    redoxide
    great build neat stuff, very cool :)
  14. gallagher
    gallagher
    from califorina
  15. Phil55Kratz
    Phil55Kratz
    Fronts are 5.50 -16 and rears are 7.50-16
  16. 'Mo
    'Mo
  17. Phil55Kratz
    Phil55Kratz
  18. Phil55Kratz
    Phil55Kratz
    [​IMG]pulled the rest of the scruff from the car .
    Kinda been tight on car money lately so I’m doing all the little stuff I’ve been avoiding.
    catdad49, Dino 64 and Stogy like this.
  19. Phil55Kratz
    Phil55Kratz
    And this lid...! The rumble seat was glue and screwed and wired and all sort of crazy stuff and the lid was all kinds of hacked.. I buy the **** out Nd saved what I could without spending a ton of time on it. I still wanna get a new or better lid eventually cause the skin is pretty beat too. For now I’m tryin to straighten and save the old paint as much as I can cause I like the look of it. Plus it’s way easy to not worry about everything being perfect. I hope to paint this car really nice eventually but I wanna get the car where I want it over time and then do it right when I have settled on it all. Here’s the hacked mess and the botch I ended up with and that’s how it’s gonna roll till I find something better. IMG_2956.JPG IMG_2963.JPG IMG_2976.JPG IMG_2965.JPG
    ct1932ford, brEad, dwollam and 3 others like this.
  20. Phil55Kratz
    Phil55Kratz
    [​IMG] and I threw a fender on .. you can see the diff between the A sprin and the T spring. Right now it’s perfect but I’m afraid it might be a little too soft we’ll see. This is a fibergl*** fender I have a set of steel fenders I need to do some metal work on and they’ll go on later. I’ve been so back and forth on fenders or not. Think I’m gonna roll with fenders for a bit . Anymore I love seeing the fendered cars.
    brEad, waxhead, catdad49 and 9 others like this.
  21. oldbanger71
    oldbanger71
    I have brackets on the axles wehre i can fit fenders for a while, and take them off again for racing as i like
  22. IowaMercMan
    IowaMercMan
    Great build.
    Walt
    Outsiders CC
  23. Phil55Kratz
    Phil55Kratz
    Thank you! My car came from Iowa..
  24. Phil55Kratz
    Phil55Kratz
    Hung the fenders on one side of the car to get a look. Just about right.
    brEad, dwollam, catdad49 and 5 others like this.
  25. drdave
    drdave
    Great build! Love working with what you have and making it look like it belongs. I have the same issue with paint as you do...right now I don't have to worry about messing it up, but its chipping and flaking everywhere, so I'm sure I'll end up "as long as I'm.....I may as well...." myself into a paint job in the not too distant future.
    Love the look with the fenders....if your taking votes. LOL
    Carry on!
    brEad and Phil55Kratz like this.
  26. Phil55Kratz
    Phil55Kratz
    Right on man ! Thanks!!
  27. triumph 1
    triumph 1
    You’re car looks great! Nice work
  28. OLSKOOL57
    OLSKOOL57
    It takes a real man to cut one up!!!!!!!!!!
    wheeldog57 and Phil55Kratz like this.
  29. Phil55Kratz
    Phil55Kratz
    [​IMG][​IMG] made my drag link from an old tie rod and put the steering wheel on to make sure it’s
    Centered.. seems good so far
    brEad, Rathbone, waxhead and 6 others like this.
  30. Dino 64
    Dino 64
    from Virginia
