Hot Rods Model A body on ‘32 chassis WITH FENDERS- Help!
Discussion in 'The Hokey Ass Message Board' started by RiffRaffRoadster, Dec 24, 2018.
  1. big duece
    big duece
    from kansas
    What's the numbers closest to the distributor hole? That's the casting date.
    Stogy and RiffRaffRoadster like this.
  2. big duece
    big duece
    from kansas
    '63,'64, and '65 that intake was used.
  3. RiffRaffRoadster
    RiffRaffRoadster
    Wow-hard to look at its so cool...
    Stogy likes this.
  4. RiffRaffRoadster
    RiffRaffRoadster
    That is a cool look Stogy
    Stogy likes this.
  5. RiffRaffRoadster
    RiffRaffRoadster
    This looks awesome-would this be considered period correct for a 60s car?
    jimgoetz and Stogy like this.
  6. RiffRaffRoadster
    RiffRaffRoadster
    Stogy likes this.
  7. big duece
    big duece
    from kansas
    The stainless is just easier to work with. One thing that I can not tell in your picture, is if the edges have a step and it looks as if the edges near the gauges are rolled? The piece being turned has to be perfectly flat. The insert you have may have been turned, and then stamped to create the stepped edges. Any close ups of the edges and near the gauge bezels? Hard to look upside down, but the intake date looks like '65 , if the last digit is a 5
    RiffRaffRoadster and Stogy like this.
  8. jimgoetz
    jimgoetz
    If your asking about my firewall I would think so. There have been engine turned parts on cars and airplanes forever. As far as your dash panel Listen to big deuce. Sound's like he really knows what he's talking about.
    RiffRaffRoadster, loudbang and Stogy like this.
  9. Stogy
    Stogy
    Probably Polished too @Tuck is doing that to his 60s inspired Hotrod...it gives the reflected extended Dressed Engine look...
  10. RiffRaffRoadster
    RiffRaffRoadster
    Yep. And he really got my attention when he offered to to do the turning on my panel for FREE!
    brEad and jimgoetz like this.
  11. Stogy
    Stogy
    Meeting Fellow Hambers is cool and there a lot to be said for a Handshake and Comradery...Priceless
  12. Stogy
    Stogy
    @Tuck's post on an in work Polished Alumium Firewall which I believe he has changed to a Polished Stainless insert Early 60's inspired and I would hazard to say polished firewalls were done much earlier as well...Bling was always Big in Cars...Shiny Sells...Looks Good...AND Goes Faster...:D
    This is an Truly New Build Era Traditional Hotrod...
    Do yourself a favour and check this Fellas Work out
    Its interesting as your Roadster and Tucks are side by side in era but are two styles of build...
    All good of course...
    https://www.jalopyjournal.com/forum/threads/tucks-29-roadster-build.827448/page-19#post-12665381
    Credit to Photographer, Owner @Tuck
  13. RiffRaffRoadster
    RiffRaffRoadster
    Tork - the shop that installed the posi-track unit in the rear end did the necessary axle work to make it fit. Thanks for the attention to detail...could have learned the hard way.
    Torkwrench, loudbang and Stogy like this.
  14. RiffRaffRoadster
    RiffRaffRoadster
    Ok Duece-looks like stainless steel but pretty beat up. Spent 30 minutes polishing with Simichrome but design really didn’t come out. I hate to ask you to do a panel for me when I can just buy one from FPM Metals. What do you think?
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  15. Stogy
    Stogy
    :rolleyes:...built like a brick ****house...:D...Was that the ignition switch location where everyone washed their finger...:p...It looks like pretty thick plate and your still working it right...doesn't look to bad to me...
    Are there raised ridges or is it flat and why could you not re pattern the same plate IF it doesn't p*** after rework?
    Hey I have one of those yellow extension cord things exactly the same...I like it...
    dana barlow and RiffRaffRoadster like this.
  16. RiffRaffRoadster
    RiffRaffRoadster
    Stogy-panel is flat and pretty thin actually. It was mated up to a thicker metal panel with the welded studs. Yes-ignition ****on was on the panel and is pretty beat up. Panel is flat-no raised edges.
    Stogy likes this.
  17. Stogy
    Stogy
    From the photo angles it look like theres nothing then you flip it over and the turning is there...are you using laquer thinner on it that might take some of the grime off then theres soap and water on top of the cream or whatever that stuff is. Is it abrading/scratching the surface of the plate...To me that is a real gem of the equation. I got a silver plate s**** thing for the missus the other day and it looked like **** and I rubbed this cloth she uses on it and wow what a difference...I'll check if it works on stainless...Your sure its stainless?
    RiffRaffRoadster likes this.
  18. Stogy
    Stogy
  19. RiffRaffRoadster
    RiffRaffRoadster
    Stogy likes this.
  20. Stogy
    Stogy
    Don't forget a dish soap and water wash as sometimes simple basics take stuff off chemicals and thinners can't and Happy Easter back at you...
    Again I feel what your achieving does look quite good and thinking about it again turned metal isn't actually that shiny the gage bezels supply that.
  21. big duece
    big duece
    from kansas
    That's cleaning up pretty nice, if you can get the rest of it that clean I would just use it. It's an original piece, I would use the original if the engine turning cleaned up even if there were some battle wounds. If you start replacing everything with new parts, you will end up with a 1-800 car. If the engine turning is faded and hard to see, I can polish the stainless and engine turn the existing piece in very short time... its fun and would be an honor to contribute to the project!
  22. alchemy
    alchemy
    I'm with big deuce. Clean that panel as best you can, then shine it a little with the polish. I wouldn't re-machine it or replace it as you will soon be building a whole new car. That panel will stare you in the face every time you drive it, and those nicks, mars, and scuffs will remind you of when your dad drove the car.
  23. RiffRaffRoadster
    RiffRaffRoadster
    Stogy likes this.
  24. Stogy
    Stogy
    Your doing a great job...there is a fair amount of Hotrod love in those old pieces...I mean even the old ignition lock and key if working fine clean up all right are worth reviving.
    I really think since you started tackling things you are probably surprising yourself at how well many things actually are once they've had some tlc.
    Interesting to witness from this end...
    RiffRaffRoadster and pprather like this.
  25. Still watching and enjoying!
  26. pprather
    pprather
    How is work on the ch***is coming along?
    Phil
  27. RiffRaffRoadster
    RiffRaffRoadster
    It is progressing. I’ve been ordering a bunch of parts from Speedway to address some suspension issues (heim joints, brackets, etc.). Hope to have some photos soon.
    Stogy, Dick Stevens and pprather like this.
  28. RiffRaffRoadster
    RiffRaffRoadster
    This is about as good as it’s going to get...maybe a little too much “character”.
    [​IMG][​IMG]
    catdad49, brad2v, jimgoetz and 3 others like this.
  29. Dick Stevens
    Dick Stevens
    The back side doesn't really matter, and that looks like good character to me! :cool::cool::cool:
    brEad, AmishMike, slv63 and 2 others like this.
  30. big duece
    big duece
    from kansas
    That close up is the front side, not the back. I think all the distress tells a story...
    brad2v, slv63, jimgoetz and 2 others like this.
