Technical What can I do about this brake/gas pedal position?
Discussion in 'The Hokey Ass Message Board' started by Do it Over, Jan 19, 2019.
  1. Budget36
    Budget36
    How about a swing pedal off column and reinforced to the firewall?
    Do it Over likes this.
  2. i'd do as i said in my first post , and also raise it up a bit as happydaze said . a little heat , a little bending and maybe some welding on the pedal arm and you are done, no need to modify anything else
    i see it is in a `35/36 Ford....i have a `36 Ford 3-window coupe and i have plenty of room for my size 12 feet without getting into the transmission cover. the pedal pad is at about the 4 o'clock position from the steering column and a lot closer , but not too close to cause problems
  3. not my coupe , but a `36 5-window i did. darn photobucket has their logo right over the pedal pad , but you can just make it out
  4. HOTRODPRIMER
    HOTRODPRIMER
    Yes it is and it can be re-positioned, It can be moved to the left, I have had to do it in the past. HRP
  5. X-cpe
    X-cpe
    It looks like that might buy you some more lateral foot room if the trans tunnel could be tightened to the trans. Looking at 36-3window's picture it looks like he built his trans tunnel close to the trans and will use the boot to cover the shifter tower.
    Going back and looking at your picture of the mounting bracket, if the pedal arm came off straight up from the short arm that operates the M/C rod, it would be problem solved. Call the manufacturer and see what they may have that would fit. That and tightening up the trans tunnel and you could drive it in snow boots. :D
  6. low budget
    low budget
    from Central Ky
    Looks like you have enough room to move the whole bracket and master forward, towards the front of the car therefore letting it move also to the left at the same time being the way the frame is angled, and still have enough brake pedal travel. Flipping the pedal pad to the left side would also obviously help as well.
    You would have to re cut your sheet metal but that can be re-welded, this is just a amateur opinion tho
    lothiandon1940 and Do it Over like this.
  7. Do it Over
    Do it Over
    from NYC, NY
    That's always been option B. Main issue is I want to keep the firewall clear and clean.
  8. Do it Over
    Do it Over
    from NYC, NY
    This car has a 4" recessed firewall. If it was stock I think it would offer more room.
  9. Do it Over
    Do it Over
    from NYC, NY
    Amateur options are how I roll :) . IMO your way will give me maybe 1-2" movement to the left before I have issues with the firewall.
  10. HOTRODPRIMER
    HOTRODPRIMER
    No reason why you can't heat and bend the brake pedal and move it to the left, you can also cut the mount on the end of the pedal and reverse it, you could gain a few inches,
    I suggest you take a close look at your user name and DO IT OVER! :D HRP
    robracer1 likes this.
  11. Do it Over
    Do it Over
    from NYC, NY
    I flipped the brake pedal pad mount which made a big difference. I've got enough room with the AOD to notch the tunnel 2-3" in I have to. I've decided to leave it as is and try it. Next I have to make an access panel for the master cylinder then I'll weld in the floors.
    Tim, goldmountain, 19Eddy30 and 3 others like this.
  12. Smokeybear
    Smokeybear
    Can you make some spacers for the bracket that mounts to the frame? It looks like you have room to move the whole ***embly over 2"-3".
  13. 1934coupe
    1934coupe
    What HRP says. I've had shelves full of stuff that did not work and yes I wasted money but you can try all that was said in this thread and still not like the results, that whole set-up needs to be moved over to the left.
    Pat
    lothiandon1940 likes this.
  14. Happydaze
    Happydaze
    Looks better but you've still got the pedal pad where it shouldn't be on your foot.
    Interesting seeing the bracket and pedal ***embly as I bought a '41 Chevy with something already fitted that looks to me like it was made by the same folks - the design of the arm, welded to the shaft and the grease ****** at the other end. I bet the pedal doesn't have a splined fit but a simple flat on a hole? Anyway, despite this being a design to fit atop the Chevy frame the pedal position was hopeless, but in this case too high up, unless you have clown feet. If it is from the same folks then they're clueless!
    As has already been said, moving that bracket forwards will move it and the pedal to the left and up the toeboard. It's a bolt on and easy to do. Might need to infill some frame holes though. Bending and / or shortening / lengthening as / if necessary could happen then.
    As a matter of curiosity, what is the pedal ration on that setup?
    Chris
    Chris
  15. jazz1
    jazz1
    although the throttle pedal in this OT truck is electronic the pedal itself pivots off the black piece attached. This method could be applied in mechanical setting, don't think I'd want any extra pivot points. I have the basic "s****" throttle pedal in my hotrod.
  16. banginona40
    banginona40
    It seems to me, whatever you do is going to take some time, and maybe the best time spent would be to move the master cylinder and booster over where it needs to be. Do you need a power booster?
