Technical VISE
Discussion in 'The Hokey Ass Message Board' started by johnfin, Apr 21, 2019.
  1. johnfin
    johnfin
    from Florida
    My vise needs to be opened up by hand, handle wont open it. It clamps ok. What is screwed up?
  2. Jack E/NJ
    Jack E/NJ
    from NJ
    Thrust washer around lead screw is missing from the movable jaw. Jack E/NJ
  3. Mike VV
    Mike VV
    from SoCal
    A vice is a pretty simple tool. Only a coupla moving parts.
    Take it apart and...find out..!
    It's far from rocket science.
    Mike
    lucky ink, B Bay Barn, 56don and 3 others like this.
  4. BJR
    BJR
    My vise is simple, my vices are not.:D
    brad2v, Thor1, Petejoe and 14 others like this.
  5. Truck64
    Truck64
    from Ioway
    The yolk might be bad
  6. sawbuck
    sawbuck
    from 06492 ct
    youir profile says engineer ?
  7. Truck64
    Truck64
    from Ioway
  8. fastcar1953
    fastcar1953
    try garage journal lots of info there
    48fordnut likes this.
  9. Safety precautions are necessary when it comes to the handling of mechanical instruments and panels to ensure incidents and injuries do not occur. A bench vise has proven to be quite a substantial piece of armor when it comes to performing work tasks. But users need to first understand some safety tips and warnings.
    2x, TAKE IT APART AND FIX THE BROKEN WASHER, I cannot count how many times I have fixed other peoples vices for the same problem, Do not buy one from Harbor Freight or you will be asking how to weld it.
    LWEL9226, pitman, mgtstumpy and 2 others like this.
  10. G-son
    G-son
    from Sweden
    …and add a bit of grease where metal slides against metal, especially the screw, it's washers etc. Preferably MoS2 grease. A "dry" vise may seem to move easily when not tightened down, but when it comes under load you really get friction between the loaded parts. Any grease helps things move better, MoS2 particles are slippery and keeps lubricating when the grease has been squeezed out from between parts = last line of defense before metal contacts metal. (That's why you lube new camshafts with it.)
  11. Desmodromic
    Desmodromic
    Opened by hand!?!? How primitive; my vise is motor operated!
    mgtstumpy and sawbuck like this.
  12. lothiandon1940
    lothiandon1940
    ......Apparently they don't make engineers like they used to.:rolleyes:
  13. LM14
    LM14
    from Iowa
    This has inspired me to take one of my old vises apart and grease it. It’s getting a little gravely when that final cinch comes along.
    mgtstumpy, G-son and lothiandon1940 like this.
  14. Mr48chev
    I've got a Wilton that was tossed in a school shop junk pile (rescued by me and not the shop I taught in) that I think has the same issue It might be time to see if that is the issue issue with it.
  15. G-son
    G-son
    from Sweden
    Pulled this apart, wirebrushed moving parts and greased them two days ago. Works great. No problem opening it, even has a spring for that job. ;)
  16. dirt t
    dirt t
    Another name is HOG HEAD!
  17. johnfin
    johnfin
    from Florida
    iam an engineer but i slept thru that cl*** 101 vise design. its bolted down to the bench and parts are concealed, hence the question. guess its time to remove it from the bench or buy a new one.
    lothiandon1940 and Truck64 like this.
  18. blowby
    blowby
    from Nicasio Ca
    I took vise design 101 back in '58 but if memory serves you can just unscrew it all the way, pull the movable jaw out, replace the broken washer and screw it back together without unbolting from the bench.
    Andy, iwanaflattie and lothiandon1940 like this.
  19. 56don
    56don
  20. squirrel
    might be the snap ring or roll pin or locking collar that retains the washer, that is the problem.
    I take apart everything just to see how it works, which I think is related to why I went to engineering school.
  21. lothiandon1940
    lothiandon1940
    ^^^^^Real engineer^^^^:D........... 3595.jpg
  22. dirt t
    dirt t
    In the old rail road days an engineer was called a HOG Head because the were so stubborn.
    Truck64 likes this.
  23. RmK57
    RmK57
    My Chinese clunker of a vice is missing the coil spring that goes on the screw. It doesn't keep pressure
    on the jaw when your opening it up either, has to opened by hand.
    Would a valve spring be a good subs***ute?
  24. fastcar1953
    fastcar1953
    love those post leg vises. i have one that dates back to early 1800s.
    G-son likes this.
  25. ROADSTER1927
    ROADSTER1927
    Don't even take it of the bench. Screw it all the way out, take the 2 screws out and see what is wrong. vice.jpg vice 1.jpg vice 2.jpg
    Just Gary and lothiandon1940 like this.
  26. belair
    belair
    Check the ground. It's always the ground.
    firstinsteele, 62rebel, clem and 14 others like this.
  27. Pete1
    Pete1
    from Wa.
    Las wek I kunt spel ingunear, now I ar wun.
    (That is a joke from school days, NOT a slur.)
    iwanaflattie likes this.
  28. Slopok
    Slopok
    Unless it's a Dodge!;)
  29. Ebbsspeed
    Ebbsspeed
    There are many types of engineers. The ***le of the guy that picks up our trash each week is "sanitation engineer". I've chatted with him a couple of times, and suspect that he may not be able to find his own *** with a ten man hunting party.
    Nostrebor, Blue One and scott27 like this.
