Hot Rods Model A body on ‘32 chassis WITH FENDERS- Help!
Discussion in 'The Hokey Ass Message Board' started by RiffRaffRoadster, Dec 24, 2018.
  1. big duece
    big duece
    from kansas
    The Stewart Warner panels that I have like that are chrome plated br***. If this were stainless, there shouldn't be any copper showing through the wear spots. Looks like the chrome plating was "turned"??
    RiffRaffRoadster likes this.
  2. RiffRaffRoadster
    RiffRaffRoadster
    Well I’m going to get the black painted Pierce-Arrow dash surround rechromed and the Model A dash will be painted gloss black, so I’ll see how this worn out looking insert looks against the new background.
    jimgoetz and Stogy like this.
  3. RiffRaffRoadster
    RiffRaffRoadster
    Could be-never thought of that. Does stainless steel eventually tarnish this color with enough oils and grime?
  4. big duece
    big duece
    from kansas
    no, not that I have seen.
  5. Gotgas
    Gotgas
    from DFW USA
    That is incredible. I would NEVER consider replacing it with a new panel.
    Some day you're going to be at a big show with dozens of perfect 1-800 deuces, and those guys are going to be drooling over those authentic original parts in your real hot rod. Polish all that **** up and run it!
    brEad, slv63, Blues4U and 4 others like this.
  6. RiffRaffRoadster
    RiffRaffRoadster
    Gotgas-im secretly relishing that day
    slv63, Stogy, big duece and 1 other person like this.
  7. big duece
    big duece
    from kansas
    I have to agree with this one...
    Stogy, Gotgas and RiffRaffRoadster like this.
  8. big duece
    big duece
    from kansas
    I am not a gun collector, BUT my favorite gun that I have is a basic 870 Wingmaster by Remington. My dad bought it new and carried it for may years pheasant hunting, he handed it down to me when he bought a new 1100. He and are the only two people to carry that shotgun, wearing the bluing off, nicking the **** stock climbing over barbed wire fences... that gun is priceless to me.
    brEad, jimgoetz, loudbang and 2 others like this.
  9. Stogy
    Stogy
    Yeah that's the ticket...Hello SOUL...darn near as shocking a transition as the interior clean-up...I'd be pretty darn proud of that...you should clean those gages next and sit them in.
    loudbang, brEad, brad2v and 2 others like this.
  10. That insert looks great!
  11. RiffRaffRoadster
    RiffRaffRoadster
    You guys are all geeks and you’re not going to let me have anything new and shiny, are you?
    catdad49, IowaMercMan, brEad and 6 others like this.
  12. Stogy
    Stogy
    Shine those gage bezels...;)...the dash plate looks brand new...you know that dirt on the dash dates back to 1952 but you reached back to the original Hotrod.
  13. redo32
    redo32
    That dash is solid br***. It was engine turned..THEN chrome was flashed over the engine turn. No copper, No nickel. Just a 2 minute flash of chrome. About 0.000005.
    catdad49, Tim, Torkwrench and 2 others like this.
  14. alchemy
    alchemy
    That insert is fantastic! You’ve got another part done and can check that off the list.
    brEad, brad2v, Stogy and 2 others like this.
  15. BigChief
    BigChief
    There is an excellent metal and gl***ware cleaner used in test labs called Micro 90. Its used diluted and does an excellent job cleaning up the surface. It's not an acid and wont remove oxidation but itll pull grime out of all the smal crevices.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    loudbang, Stogy and RiffRaffRoadster like this.
  16. jimgoetz
    jimgoetz
    Just wow! If I could have gotten mine looking half that good I never would have covered it but it was just too far gone. IMG_3935.jpg
  17. ROADSTER1927
    ROADSTER1927
    ANOTHER GREAT PART AND JOB! Geek Gary:D:D
    jimgoetz, Stogy and RiffRaffRoadster like this.
  18. RiffRaffRoadster
    RiffRaffRoadster
    Great I’ll try it
    Stogy likes this.
  19. Torkwrench
    Torkwrench
    You're Welcome, Riff.
    It could have been a bit expensive, too. If the 55 - 56 axel shafts are not shortened, they will bottom out on the pinion shafts that are inside the Posi unit.....Generally when driving around a corner, or a curve in the road. When the shafts bottom out, quite often the center section blows up.
    RiffRaffRoadster and loudbang like this.
  20. RiffRaffRoadster
    RiffRaffRoadster
    Redo-do you think the dash insert is the original from a 33 Pierce-Arrow? Were they originally solid br***, or do you think this was this a repro done back in the ‘50s/‘60s?
    Stogy likes this.
  21. redo32
    redo32
    This is a stock '33 Pierce Arrow dash.
    RiffRaffRoadster and Stogy like this.
  22. big duece
    big duece
    from kansas
    Might have been from a different year, they were engine turned in '32 too. If you look close there is wear on the left hand side next to the clock, so those wear marks are traditional;) dash2.jpg
  23. RiffRaffRoadster
    RiffRaffRoadster
    Can Y’all help me find a pair of Edelbrock valve covers, polished aluminum, with offset bot pattern (fits a 1957 283 SBC). With breathers/oil fill? They look like this but with offset holes. Thanks.
    loudbang and Stogy like this.
  24. Stogy
    Stogy
    I don't think you need the Filler as it is on the Manifold...These are sold...and were straight bolt pattern. The breathing is done thru the cap on the filler tube...You also have that road draft tube in the back of the block near the distributor and not sure how your addressing that yet however we all discussed it for a bit earlier in the thread...there are options.
    I think in a mixed Vintage car keeping branding as in Chevrolet non visible is appropriate...
    What I'm saying is Corvette/Chevrolet Script I would stay away from...This Edelbrock, Offenhauser, non branded all fit the bill I suppose...
    https://www.jalopyjournal.com/forum/threads/early-edelbrock-finned-valve-covers-sbc.988195/
    Here's a current set on Ebay...;)
    https://www.ebay.ca/itm/202572865040?ul_noapp=true
    There is this type too which are Cal Custom and they ain't cheap either...
    https://www.ebay.ca/itm/2-VINTAGE-C...ash=item2856dc9246:g:D0UAAOSwZrtaxr2S&vxp=mtr
    Both of the above may be reproduced as well...
  25. Dick Stevens
    Dick Stevens
    Why not get a set of Corvette valve covers, they are most definitely traditional!
  26. Whats wrong with the early ribbed Cal Custom Chrome valve covers that were on there.
  27. RiffRaffRoadster
    RiffRaffRoadster
    I didn’t know they were an identifiable model. I can re-use them though they are pitted and rusted as well.
    [​IMG][​IMG]
    catdad49, loudbang and brEad like this.
  28. Stogy
    Stogy
    It no doubt is but it mixs up branding visibly with a hoodless car where as others look either as add on speed pieces without the Ford Chevy Mix...
    On my sport coupe I have a Chevy V8 with Either Knock off Cal Custom or Vintage original but there is no brand distinction...Most know its a Chevy But I like the No Name approach in a Ford.
    Yes they are Awesome and Traditional I get that.
    Heres where I would stray a bit as Dad could have went and bought traditional upgrades to the covers and the Rusted Steelies hang in the garage as reminders. But of course thats me...;)
    loudbang and RiffRaffRoadster like this.
  29. RiffRaffRoadster
    RiffRaffRoadster
    I’m not stuck on having a logo but I like the polished aluminum and deep ribbed look.
    loudbang, slim38 and Stogy like this.
  30. RiffRaffRoadster
    RiffRaffRoadster
    These are real close to what I would like to use
    jimgoetz, loudbang and Stogy like this.
