Technical Aluminum radiator leak
Discussion in 'The Hokey Ass Message Board' started by Joe H, Apr 23, 2019.
  1. Joe H
    Joe H
    I have a 10 year old AFCO aluminum radiator in my '37 that has begun to seep where a couple tubes enter the bottom. No one wants to repair it or can repair it. Stop leak is what I am being told to try, just didn't want to add that with a new heater core recently installed.
    Thinking about a pump and hoses to circulate water in radiator only
    with stop leak,
    Does stop leak need heat to work?
    Is one better then the other?
    Does it need pressure to work?
    Not really interested in the br*** verses aluminum radiator debate!
  2. They are disposable.
    Original Cost divided by 120 months means that radiator doesn’t owe you much. That is unless trying to fix it plugs your new heater core
  3. KJSR
    KJSR
    from Utah
    I have had real good luck using epoxy externally on the leak.It has to be very clean and prepped correctly.
    loudbang and Bandit Billy like this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    Mine ( afco) did the same thing after 6 years ,and like you found , no one would repair it , said I'd gotten my moneys worth !? If yours is seeping where the tubes enter the bulkhead , here's what I did . removed the rad and cleaned it/ flushed it , took a small stainless brush and cleaned some more , used acetone , then denatured alcohol multiple times ,then used the high temp JB weld as neatly as possible and made sure it .was all around the tubes . Mines been leak free for .12 years now . Try it .
  5. HOTRODPRIMER
    HOTRODPRIMER
    I have had a Griffin aluminum radiator and I too had problems with it leaking/weeping around a couple of the cooling tubes and the radiator shop tried some epoxy but never cured the problem, I went back to a copper/br*** radiator that can be repaired at just about any radiator shop that has been in business for long enough to know what they are doing.
    The Walker radiator in my old beater is now 31 years old and thus far I haven't seen any indication of a leak . HRP
    sidevalve8ba likes this.
  6. Tim
    Tim
    from KCMO
    I had mine fixed in Kansas City! Give me two seconds I’ll find the shop info
  7. Tim
    Tim
    from KCMO
    Super fast turn around, cost me less than $100. B6E46896-5C4D-4065-AEF1-DA35B81D9CB0.png C1EB5797-401A-4095-95FB-5B356D411B01.jpeg
  8. Texas Webb
    Texas Webb
    Now thats service^^^^^.
    loudbang and OLDSMAN like this.
  9. jimgoetz
    jimgoetz
    Why not just disconnect the heater core and try the stop leak ? you shouldn't be needing the heater anyway for the next 3 or four months or so. If it works good if not what are you out ?
    loudbang and scrap metal 48 like this.
  10. WOODEYE
    WOODEYE
    I had a similar problem and used Bars stop leak with good success. I think jimgoetz has a workable plan thats cheap and has a good chance.
    loudbang, scrap metal 48 and jimgoetz like this.
  11. Joe H
    Joe H
    Orr Radiator didn't want to try fixing it, not enough room without really cutting into it. I am going to try the epoxy, I have nothing to loose at this point.
  12. Tim
    Tim
    from KCMO
    Bummer, yeah I’d try epoxy that seems to be what everybody’s using to fix them anyways
  13. Is it the core or the tank?
    If it is the tank a welding shop can repair it as long as all antifreeze residue
    has been removed.
    I changed the outlet location on the aluminum Speedway radiator
    [​IMG][​IMG][​IMG][​IMG]
  14. NAES
    NAES
    Well dont Tim!
    Our home AC unit took a **** and leaked. We brazed it ourselves with MAP gas and filler rod. Very similar to the aluminum "muggy weld" we've probably all bought at the swap meets. Practice on a few beer cans first! Lemme see if I can find the correct filler rod.
    Sent from my SM-N910V using The H.A.M.B. mobile app
  15. NAES
    NAES
  16. Gman0046
    Gman0046
    Won't use Stop Leak. It clogs up heater cores, water p***ages, and backs up behind freeze plugs and rots them out. Radiators need a proper repair not Stop Leak.
  17. gene-koning
    gene-koning
    Buy another $200 aluminum radiator and move on. Hope the next one lasts 10 years, or buy a $600 br***/copper radiator and hope there will still be someone around that can fix it in 10 years (no one around here fixes any radiators anymore). Gene
    sidevalve8ba and loudbang like this.
  18. Blues4U
    Blues4U
    from So Cal
    If it's just a couple of tubes, pinch them off.
  19. tomic
    tomic
    they're brittle, thin, and very susceptible to electro-chemical corrosion ("dissimilar metals") when retrofitted to iron motors. lucky for us they're great at conducting heat and they're cheap. i too dislike "disposable" car parts, but finding good br*** radiators and parts became an increasingly pointless h***le. and i'm great at soldering.
    i mounted mine between 1/2" slices of surplus aircraft silicone/neoprene foam rubber which eliminates a lot of vibration and electrically isolated it (i didn't even think of that until later). only two years old so far.
  20. Montana1
    Montana1
    My PRC leaked from the day I got it! Been running Barr's in it for 13 years. When it gets below freezing it ****s the plug back in and leaks again. Put some more in and go again. Thought about the J-B Weld trick, but never tried it. One of these days I'll fix it right with a br*** one and send the old one to the s**** yard. :eek:
  21. Blues4U
    Blues4U
    from So Cal
    I tried JB weld on a crack in the top tank of an aluminum radiator, and it lasted about a week before starting to leak again. But it was where the radiator support rods attached, so there was some stress on the area. It might work OK on an unstressed part.
  22. Joe H
    Joe H
    If they were $200, I wouldn't be messing around, this truck takes the $650 ones, br*** add, $300 more!
  23. Gman0046
    Gman0046
    A temporary fix always leaves you stuck on the side of the road. I learned a long time ago that when it comes to Cooling, Brakes and Steering to always buy the best. How much quality can you expect out a $200 radiator?
    da34guy and Montana1 like this.
  24. $ 650 aluminum radiator?
    Maybe you should shop around a bit.
    Took me a minute to find that and post it
  25. Montana1
    Montana1
    My support rod brackets broke too, plus both lower radiator brackets (with springs) broke off. I had to reweld and reinforce everything before it was a year old. Just a bad design.
  26. Joe H
    Joe H
    Sorry, try '37 Chevrolet truck.
  27. tomic
    tomic
    aluminum radiators are different than br*** and require new techniques. it's a matter if deciding of the benefits outweigh the h***le. in my case i didn't have much choice, so i got over the hump.
    i installed one of whatever Speedway sells in june 2016. rather than weld brackets on it i made a sheet steel frame that bolts to the stock location, lined it with dense orange neoprene foam, and slid it in. the pusher fan bolts to a frame in front, not touching the radiator. nomex honeycomb, painted red, over the aluminum fins for bug/debris protection. a side effect is that the aluminum is electrically isolated which stops electrochemical corrosion.
    the engine was new 2017, since then annually i flush with purple degreaser (helps the next step work), then phosphoric acid type cleaner, then garden hose, then a rinse with distilled water. then drained and filled with distilled water and water-wetter. no antifreeze. one year i ran Dexcool (OAT type good for mixed metals). so far so good.
