Technical Why Are Tube Front Axles So Common on T's?
Discussion in 'The Hokey Ass Message Board' started by Blues4U, Jul 14, 2018.
  1. Blues4U
    Blues4U
    from So Cal
    It seems like Model T hot rods are more likely than not to have a tube front axle, something that is rare on a Model A or 32-34. So why are they so popular on T's? This seems to be so especially on T buckets, and especially Fad T's, but also on Track T's. Seeing as a tube axle has issues with hairpin mounts due to the lack of twist in a tube axle, yet this is the typical setup. What's up with that? Just curious why this is so common on T's, is there a historical context I'm unaware of.
    Some examples:
  2. LM14
    LM14
    from Iowa
    Lighter looking, cleaner looking when that much is exposed, racier looking
    . Simple to chrome. Laziness....that's why I did it when I started the build on mine years ago. Sold it before it was finished, it's still running around.
    SPark
    TrackT1.jpg . Simple to chrome. Laziness....that's why I did it when I started the build on mine years ago. Sold it before it was finished, it's still running around.
    SPark
    OFT, catdad49 and Hnstray like this.
  3. Unkl Ian
    Unkl Ian
    Factory T axle wasn't a good choice.
  4. Blues4U
    Blues4U
    from So Cal
    I get that, but plenty of I-beam axles around to use.
  5. Hnstray
    Hnstray
    from Quincy, IL
    I think LM14 covered it pretty well. The tube, I think, looks better to most eyes. Smoother, cleaner, "less industrial" than an I beam. None of that is to say the I beam doesn't have merit, it does, and is a proven part. But if there is one thing that is an almost universal truth, it is Looks or Cool beats 'better choice' every time if looks are a factor.
    Ray
  6. 49ratfink
    49ratfink
    many T buckets are built from "kits" or at least an ***embled frame that comes with a tube axle. most old cars are built from old cars that came with an I beam.
    two of your examples are V8 60 axles from Ford.
    metlmunchr, RICH B, bct and 3 others like this.
  7. Tim
    Tim
    from KCMO
    ^ what he said
    The track t’s are likely using v860 axles which... maybe weigh less?
  8. HOTRODPRIMER
    HOTRODPRIMER
    I would thing T bucket axles have the hairpin brackets welded to them,a large majority of T's that are on the road were offered as kits back in the 6o's and the tube axles are made in house along with all the suspension parts. HRP
    49ratfink and Blues4U like this.
  9. mkubacak
    mkubacak
    Look at the photos above. To my eye the most pleasing axles are the V8 60 axles.
    Also, look at Tommy Ivo's car and the Kookie Kar. They both are sporting V8 60 axles.
    LOU WELLS, Just Gary and 49ratfink like this.
  10. Tim_with_a_T
    Tim_with_a_T
    The way I see it, two of the first, and arguably most famous, T buckets ever built were V8-60 tube axles. That look is what many people are after. Then, along comes the "kit" T buckets... Tube axles are much easier and far less costly than a forged i beam to produce, so that's what's sold with the kit. There's nothing wrong with using an i beam on a T, but it's quite uncommon to find one in "kit" form. The Tribute T from Speedway is an exception. I prefer an i beam, but I believe I am in the minority when I say that as far as buckets go....
    Deescott, AndersF, Blues4U and 2 others like this.
  11. Jmountainjr
    Jmountainjr
    Cost and reduces a bunch of unsprung weight on a very light car.
    gnichols and Blues4U like this.
  12. oj
    oj
    I'd say the tube axle on the kit cars were dirt cheap to make, 2 bends and a couple welds? a production shop would have a stack of them made in a day.
    Blues4U likes this.
  13. fiftyv8
    fiftyv8
    from CO & WA
    I believe it was because:
    1. it was a follow over of building T buckets which wanted wider tracks.
    2. tube was a new style.
    3. a carry over from speedway dirt track racing.
    4. greater drops in axle height could be achieved.
    5. just to be different.
    6. and it all started with T's so era correct...
    patmanta, Ned Ludd and Blues4U like this.
  14. 56don
    56don
    Cause they are purty....
    Al's.C.D.T and Blues4U like this.
  15. JOECOOL
    JOECOOL
    after spending a couple of hrs getting the bolts out of the bones, blasting and grinding rust for another couple hrs , yep and tube axle looks better all the time.
    The37Kid likes this.
  16. Jim Bouchard
    Jim Bouchard
    ^^^^ This is the reason ^^^^
    Tim_with_a_T likes this.
  17. tubman
    tubman
    Because I found an unused one at a swap meet for $10.:D
    Hnstray likes this.
  18. A Boner
    A Boner
    Cheaper to manufacture for a T bucket kit......don't have to heat and bend steering arms like with old Ford beam axles. Lots of T bucket kits during their hay day = monkey see monkey do, becomes part of the fad in fad T's. Doesn't hurt that they are simple/smooth looking.....and V8-60 axles are very slick!
  19. gnichols
    gnichols
    from Tampa, FL
    Looks, easy to fab, looks, light, looks... Gary
    dana barlow likes this.
  20. Ned Ludd
    Ned Ludd
    I believe the Fad T was definitive a good decade before they could be had as a "kit".
    A tube axle has a more delicate look, which ties into the Fad T idea of near-humorous ironic inversion of "antiqueness"; making a (arguably) fast car out of the most unlikely raw material. Hence emphasizing the br***-era spindliness which the Hallcraft wires also pick up. The tube axle also allows for the sort of proportional shenanigans which went along with all this; most often in the form of a wider track.
    A tube axle is easier to make, not so much in the sense of easier to productionize for a kit manufacturer as easier to make up one-off for a hot rod builder. I did some illustration work many years ago for a build series in a local magazine. One issue contained a full how-to on building your own tube axle. As I remember it didn't have welded-on batwings, but round-bar bosses for various functions. The location was by four-bars and Panhard bar, with spherical rod-ends bolted directly to the axle bosses.
    Hnstray likes this.
  21. jnaki
    jnaki
    A great photo shot by C. Ryan Mac on Shelter Island, San Diego Bay, facing the downtown as background. Thanks Jim Reid, Prowlers of San Diego for the photo.
    Hey B,
    The round axles were used for some resemblance of streamlining over the curved surfaces. But, there were a lot of I beam axles around with set ups already in place for roadsters and Ts. Just buy, clean up, paint, and bolt on...that was the set up to get your hot rod, up and running. There were a ton of variations of each, with the addition of holes to lighten the front end of any of the cars. Strength? It was hit or miss with intelligent drilling without going overboard.
    But, in the 60s, the parts were there, complete or otherwise. In the 70s, it exploded, up to today’s modern ch***is companies offering all sorts of choices.
    Jnaki
    But to throw a wrench into the matter, here is a photo from a HAMB reader from Ohio with an unusual axle.
    Ron Funkhouser and Blues4U like this.
  22. Atwater Mike
    Atwater Mike
    ^^^That axle gives me the 'Willys'! Oh, that's probably 'cuz it IS a Willys...
  23. Al's.C.D.T
    Al's.C.D.T
    I used a tube on my Center Door
    On the Coupe I built I used an I beam.
  24. Bruce Lancaster
    Bruce Lancaster
    History of the early influential/famous cars AND because most t-buckets had a suicide front end allowing any degree of lowering desired without dropping the axle...most 28-34 Fords come out too high with undropped tube, and dropping a Ford tube is not an easy problem.
    Moriarity likes this.
  25. Loose Ctrl
    Loose Ctrl
    from Upstate,SC
    Pretty much cause they're cheap, easy, and look good most of the time. If I was building a steel car, P/U, or RPU it would have an old I beam axle. I prefer them. I like the way they look.
  26. Marty Strode
    Marty Strode
    dana barlow, rooman, RICH B and 4 others like this.
  27. Budget36
    Budget36
    I always figured it flowed well with the exhaust, sorta tying things together.
  28. Loose Ctrl
    Loose Ctrl
    from Upstate,SC
    That is one spartan looking rear. I do like that torsion bar set up and those brackets for the pins. At least those look like hairpins.
  29. clem
    clem
    I always thought that the T’s had a narrower track width so the later Ford’s looked too wide, hence the manufactured tube axle.
    Interesting comments above, nice to hear the more likely reasons behind this.
    twenty8 likes this.
  30. Marty Strode
    Marty Strode
    Loose Ctrl and clem like this.
