Projects 5wKy33: another coupe build thread
Discussion in 'Traditional Hot Rods' started by ls1yj, Jan 15, 2017.
  1. ls1yj
    ls1yj
    from Kentucky
    Got the p***enger side a pillar welded on, and smoothed up some...
    brEad and loudbang like this.
  2. ls1yj
    ls1yj
    from Kentucky
    Started in on driver post,
    And found some funk that needed cut out
  3. ls1yj
    ls1yj
    from Kentucky
  4. Tim_with_a_T
    Tim_with_a_T
    My God that lid is hammered! Looks BAD! As in really good...
    ls1yj and loudbang like this.
  5. ls1yj
    ls1yj
    from Kentucky
    Thanks Tim_with_a_T
  6. ls1yj
    ls1yj
    from Kentucky
    loudbang, patman and akoutlaw like this.
  7. ls1yj
    ls1yj
    from Kentucky
    Drewfus, brEad, Tim_with_a_T and 2 others like this.
  8. Tim
    Tim
    from KCMO
    Dang that’s going to look mean!
    loudbang and ls1yj like this.
  9. ls1yj
    ls1yj
    from Kentucky
    I haven’t given up, guys.... just took a new job, and it’s a travel job, so been on the road for a few weeks... this is first weekend that I spent some time in garage in quite awhile...
    Tim, Roothawg, Bondo Slinger and 4 others like this.
  10. curbspeed
    curbspeed
    Like it.
    ls1yj likes this.
  11. ls1yj
    ls1yj
    from Kentucky
    curbspeed, el Roach, Drewfus and 5 others like this.
  12. ls1yj
    ls1yj
    from Kentucky
    Working on a good location for rear wheels... I’ve been told that wheels should move rearward 3/4-1” from stock, but looks like stock location is pretty close to matching body reveal around wheelwell... oh, these are setup wheels, and are a little short, only 30” tall... will be getting 31’s later to fill up well...
  13. deathrowdave
    deathrowdave
    from NKy
    I did not know wheels were not in the correct location on Fords. I know the Chebbies need to be moved back to be correct .
  14. ls1yj
    ls1yj
    from Kentucky
    Dave
    I’ve been told the axle placement is to match the openings in rear fenders, so losing the fenders changes position slightly
  15. deathrowdave
    deathrowdave
    from NKy
    I see . I ran my 32 for a bit without fenders and wheel was correct . But the location could have been changed , because of the buggy spring mount I used to mount the 9 in moved it without me knowing it . You are correct in saying that the tire must fit the opening for the look . I’m just a bit stupid when it comes to Ford issues .
  16. ls1yj
    ls1yj
    from Kentucky
    Heck, I’m learning as I go along... lots to learn on this ol’ gal
    31Vicky with a hemi and loudbang like this.
  17. loudbang
    Looks pretty good right there.
    brady1929 and ls1yj like this.
  18. brEad
    brEad
    Looks like that wheel is just right as compared to the reveal to me, too.
  19. ls1yj
    ls1yj
    from Kentucky
    brEad, loudbang and Shadow Creek like this.
  20. Magoo motors
    Magoo motors
    I am watching and learning as you go forward ! what you are doing looks Great!! Thanks and keep it up.
  21. ls1yj
    ls1yj
    from Kentucky
    Thanks Magoo Motors
    It is slow going.... heating and beating the arch plates for rear axle clearance today... will post a few pics soon
  22. ls1yj
    ls1yj
    from Kentucky
    brEad, Shadow Creek and loudbang like this.
  23. ls1yj
    ls1yj
    from Kentucky
    Got one side roughed in, just a little more welding and grinding to get other side
  24. brEad
    brEad
    I like your attention to detail on the notch. Very nice!
  25. ls1yj
    ls1yj
    from Kentucky
    Thank you, my friend... I’m on the road for work this week, but will get it all finished up this weekend
  26. ls1yj
    ls1yj
    from Kentucky
    Got both axle cuts cleaned up, and frame back in jig, realigning cross members, and laying out placement of rear bones
    loudbang, Shadow Creek and brEad like this.
  27. ls1yj
    ls1yj
    from Kentucky
  28. ls1yj
    ls1yj
    from Kentucky
    Got the holes in, and back to mocking up rear T spring...hmmmmm... don’t think these stock brackets are gonna work...
    Gonna have to either gouge these all up, or fab up some that will work for new extreme angle
  29. Rocky
    Rocky
    Classified Editor
    I used stock model A u-bolt location but ran mine with the nuts on top....flipped them upside down for quick change clearance. Worked great! Just like this photo captured here off the HAMB...can't find a photo of mine but it's just like this. 34fordsmallbottomsideoffhamb_CwithAspring.jpg
  30. ls1yj
    ls1yj
    from Kentucky
