Technical Chevy 3100 pickup - Clutch or transmission noise only under load
Discussion in 'The Hokey Ass Message Board' started by Road Runner, Apr 25, 2019.
  1. Road Runner
    Road Runner
    I am trying to figure out, if I should replace my clutch and flywheel in my 52 chevy truck, or if it may just be a bad throw-out bearing or pilot bushing.
    The clutch was replaced only about 20K miles ago.
    I started hearing a growling and squealing sound with metallic smell, only when under load and driving forward or backward.
    When I press the clutch pedal down the noise goes away.
    In neutral I can rev the engine and no noise.
    I think a bad or dry throw-out bearing only makes noise when pressing the clutch pedal down.
    But my clutch disc should not be worn that soon?
  2. X-cpe
    X-cpe
    From what you have described I would suspect the output shaft bearing in the trans. Are you sitting still or driving in neutral when you rev the engine? Is the clutch pedal up or down? If you are in neutral (engine running) with your foot on the clutch, sitting still, the disc and input shaft (and therefor no part of the trans) are not turning. In neutral (engine running), sitting still with your foot off the clutch, the flywheel, pressure plate, disc, trans input shaft, cluster and speed gears are turning, but not the output shaft. When you are driving put it in neutral and push the clutch in. A bad output shaft bearing noise will still be there but should diminish. If it is the cluster bearings or the rollers in the back of the input shaft, any noise from them should go away or diminish in third gear (3 spd.) because you have taken the load off the cluster and the input and output are now turning at the same speed.
    If the clutch is slipping, check the linkage for binds and adjust the toe play, Also check to make sure all the pressure plate bolts are tight and there are no broken fingers. Your ***essment of the throw out bearing is one of those 99.9 per-centers.
    Another possibility is the 'U' joint in the front of the torque tube.
    King ford and F&J like this.
  3. Road Runner
    Road Runner
    Thanks for your reply.
    Your descriptions start to makes sense now and point more towards the output end of the transmission.
    I can confirm more symptoms...
    Clutch feels fine and doesn't slip (engine does not rev up in speed)
    When I rev the engine in neutral, it is quiet and no low-mild-rumbling vibrations regardless of rolling or sitting still.
    Also regardless if I push the clutch in or release.
    And then this, probably telling clue:
    The low rumbling is stronger when driving in first gear and second gear.
    It gets less in third gear and that's why I felt comfortable driving home the 20 mile road trip with hardly stopping or shifting.
    Then the next morning backing out of the garage and cold 40s temps in February, I could hear the metallic grinding high pitch squeal all the time when under load then going into first and second.
    I turned around back home and parked it.
    Now the temps are warmer to work in the garage and I want to get into it.
  4. Bill Rinaldi
    Bill Rinaldi
    Is this a stock 52 Chevy truck? 3 speed on the column or granny 4 speed on the floor?
  5. Road Runner
    Road Runner
    235 with stock 3 speed on the column and torque tube with 3.55 rear.
  6. X-cpe
    X-cpe
    A fluid level check would also be in order. From your description, though, at this time it is probably a moot point.
  7. Road Runner
    Road Runner
    I top it off every 1000 miles, as per manual recommendation. 1500 miles at the latest.
    That's why I didn't suspect the transmission at first.
    When the noise started, I was at 700 miles since the last top-off and topped it off after getting home with the usual amount it needs.
    I use GL-4 rated gear oil because of the br*** parts.
    Then next cold morning it sounded like this had no influence and it now was a steady bright dry metal-to-metal squeal, under load only.
  8. tb33anda3rd
    tb33anda3rd
    does the noise go away if you just "rest" your foot on the clutch pedal?
  9. Road Runner
    Road Runner
    Interesting - I am not sure at what point of the pedal travel the noise stops.
    But I know the moment the clutch pedal relieves the load, the noise stops.
  10. tb33anda3rd
    tb33anda3rd
    I asked because I had a 37 that would growl under load. if you just pushed the clutch a little bit it would stop. I can't remember exactly what was worn but the fingers were coming too far back.
  11. Road Runner
    Road Runner
    It is more like you have to remove power from the engine interacting with the transmission so the noise stops.
    But the drive line behaves just fine, if you would want to ignore the noise and faint metallic rubbing smell or just don't know any better.
