I ran across this adapter that uses a 32 to 36 V8 water pump on a Model A, looks like there's a block off plate for the original upper water Outlet. Anybody have a picture of one installed? It might help with getting the cooling system to purge better on one of my projects.
Note that I'm using an electric fan. Also used the block off plate for the temp gauge. Replaced my V-8 water pump with a reproduction and had to do some grinding on the adapter as it was not a very good fit.
