Technical 54 bel air clutch adjustment
Discussion in 'The Hokey Ass Message Board' started by 54 Chevrolet, Apr 23, 2019.
  1. 54 Chevrolet
    54 Chevrolet
    from Wv
    I took out A Auto zone clutch kit on my 54 bel air v8 with A supert10 transmission and replaced it with A Ram muscle car preformance clutch kit.
    I'm using A G body bellhousing and original 54 clutch linkage and with the cheap clutch in it all work great.
    With the Ram clutch kit I had to adjust the link about 3/4in to get the clutch to release about one inch of the floor and one inch of free travel. I only have about 1/2in left on the link and would like the clutch to release more off the floor. The car is still up on Jack stands and I was turning the drive shaft with my daughter pushing the clutch.
    I contacted Summit racing and the guy said I might have to put A longer release bearing in it.I hate to take it back out and was wondering what y'all thought.
  2. squirrel
    Did the clutch kit come with a release bearing?
  3. BJR
    BJR
    Can you make a longer adjustment link to take up the play?
  4. jimmy six
    jimmy six
    I've got 3 different lengths when I use the stock fork depending on the style of clutch. After I put in the trans I look where the arm is sticking or of the bell. If it wasn't where the last one was, I slide out the trans and try a different one. Good luck
  5. 54 Chevrolet
    54 Chevrolet
    from Wv
    Yes sir, it looked like the one I removed, I kinda think the heights on the pressure plat is different.
  6. squirrel
    Does the new pressure plate have significantly more spring force? If so, it might be that the linkage is flexing.
  7. 54 Chevrolet
    54 Chevrolet
    from Wv
  8. 54 Chevrolet
    54 Chevrolet
    from Wv
  9. 54 Chevrolet
    54 Chevrolet
    from Wv
    No it feels light, maybe even lighter that the Auto zone clutch.
  10. RICH B
    RICH B
    We used an adjustable pivot ball to get the geometry right one time, that was on Lakewood steel housing, so may not be something that would work on a stock housing.
    Sent from my Nexus 5X using The H.A.M.B. mobile app
  11. 54 Chevrolet
    54 Chevrolet
    from Wv
    Picture of the linkage before I removed it, the new set up I had to adjust the nut about 3/4in but have about 1/2 left . 20190412_003050.jpg 20190412_003057.jpg
  12. fastcar1953
    fastcar1953
    i think truck throwout bearings are longer than cars. i thought i had to change one once, unsure been to long.
  13. sdluck
    sdluck
  14. BJR
    BJR
    When the clutch pedal is pushed all the way down does the clutch fork hit the bell housing? Looks awful close in the picture with the red pressure plate. Maybe space the pivot ball so it is more forward to get more clearance for the clutch fork.
  15. 54 Chevrolet
    54 Chevrolet
    from Wv
    I was looking at the picture last night and wondered the same thing, you could hear it hitting the last inch when pressing the pedal. I used A flat foul and removed about 1/8 in that era and corrected it.
  16. 54 Chevrolet
    54 Chevrolet
    from Wv
    I adjust the link about A 1/4 and now have 3/4in of free play in the pedal and clutch will release about 2 to 2 1/4 in off the floor. I'm thinking about trying it and seeing, what do y'all think. 20190424_182315.jpg 20190424_182110.jpg
  17. Memphis T.
    Memphis T.
    from New York
    I had a similar problem with not enough travel to get the clutch to release. On the stock linkage there is a thick rubber bumper to prevent the linkage from tapping the firewall. By removing the bumper I gained the travel I needed.
    54 Chevrolet likes this.
  18. 54 Chevrolet
    54 Chevrolet
    from Wv
    I talked to A tech at Ram clutch yesterday and he said to put some miles on it ,that it would loosen up some.I finally got it out of the garage today and have been driving it and it is starting to release higher off the floor, think goodness.
    I also installed A set of 3.73 gears in it last weekend and really like them.
