Technical Are heads worth the cost on a flathead?
Discussion in 'Traditional Hot Rods' started by Machwon169, Apr 27, 2019.
  1. Machwon169
    Machwon169
    I’m doing a flathead in my 30 A.....
    I’m pricing out rebuild etc. my question is... is the $700-$800 price worth the cost in terms of performance for a flathead?
    Or is it just for looks mainly....
    What are we talking 10-15hp
    Or 40-50hp?
  2. manyolcars
    manyolcars
    What??? Are you talking about buying high compression heads?
  3. Tim
    Tim
    from KCMO
    The smaller number.
    A hot Flathead is like 150 hp I can’t see you getting 50 of that from the heads. I’d like into getting the stock heads milled for some compression and move on
    alanp561, 3340 and Texas Webb like this.
  4. kadillackid
    kadillackid
    ...and don't forget to include the price of attaching hardware..quality stud kits are not cheap ;)....in saying that I love the look of finned heads on a flatty !!
    Spooky likes this.
  5. 49ratfink
    49ratfink
    I have a good running 350 I'll sell you for $700.00.
  6. Machwon169
    Machwon169
    I’m saying does the higher compression heads make how much more HP. Or is it mainly for looks....
    Also I would never put a 350 in my A
  7. greybeard360
    greybeard360
    Which flathead are you starting with ?
    You say you are rebuilding it.... What pistons and what compression will it have with the stock heads?
    Are you changing the cam?
    Which heads are you considering ?
    ironrodder likes this.
  8. Aman!!!
    Gasser 57, Lil Fatso and 49ratfink like this.
  9. oldtom69
    oldtom69
    from grandin nd
    I'm guessing he already has a belly ****on
  10. rusty valley
    rusty valley
    i had the iron heads angle milled to get .050 over the pistons, used studs, new nuts, i think it looks fine for a whole lot less. in the old days not every kid had money for fancy heads, this kid dont either IMG_1328.JPG
    Lil'Alb, Packrat, Lil Fatso and 23 others like this.
  11. Machwon169
    Machwon169
    It’s a 1946 59ba
    Just rebuilder pistons.
    Didn’t change the cam but could if needed.
    I was looking at the edelbrock or Offenhauser heads.
    Just looking for decent runner in my coupe
    dsiddons likes this.
  12. Never2low
    Never2low
    Spend the money elsewhere.
    If you decide you want to go that route, you can always switch later.
    Personally I prefer stock looking heads in Ford green.
    But, them again, I'm more of a prewar look kinda guy.
    Spooky, clem, Cliff Ramsdell and 2 others like this.
  13. Fortunateson
    Fortunateson
    What is the purpose of the piece of wood on the left framerail with the two alligator clips?
  14. rusty valley
    rusty valley
    that is a temporary ballast resistor so i could run it the first time. so far, all good.
    Spooky, jimmy six and clem like this.
  15. hotrodrhp
    hotrodrhp
    from Wisconsin
    Building my first flat head model A myself and went the finned alum. Edelbrock head route while it was still on the run stand. Won't be fast and it won't be doing 100 foot burn outs so what modest horse power gains are to be had will be modest. There is something special about a flat head powered A. Your choice so build what you can afford it's strictly a personal decision.
  16. Machwon169
    Machwon169
    Ya I’m thinking the heads arnt going to add much in any more power so it’s mainly a look piece...
  17. 51504bat
    51504bat
    JMO but if you're going to run the fancy heads put them on before installing the engine. Yes, you can change them later but its much easier to do it with the engine on the build stand. On a stocker they probably don't had much in the way of performance but they might have some benefit in the cooling department. But they do look cool as hell, but again that's JMO.
    samurai mike likes this.
  18. Roothawg
    Roothawg
    That’s good because it sounds painful...
  19. Chappy444
    Chappy444
    A flathead us expensive enough without willingly adding g to the cost...
    I have a copy of the receipt the PO spent building the flattie in my car...over $5k...
    And that is with a set of EAB heads... a lot of that bill was shop time, machine work, and ***embly.... on the other hand, those finned aluminum heads sure look good....
    Chappy
    Spooky, patmanta, dsiddons and 2 others like this.
  20. sloppy jalopies
    sloppy jalopies
    IMO... when buying a flattie, don't pay for what you can't see...
    every flattie stuffed under the bench or out in the shed, ran great... that must be why they pulled them out...
    Atwater Mike, Baumi and clem like this.
  21. Blues4U
    Blues4U
    from So Cal
    Yes, he said he has a flathead......
    loudbang, zzford, Hnstray and 2 others like this.
  22. Brian Penrod
    Brian Penrod
    Best reply in the thread!!!
    zzford and Truckdoctor Andy like this.
  23. plym_46
    plym_46
    from central NY
    well I have a flat head six. from the factory the compression ratio was just under 7 to 1. for 45 bucks I had .050 taken off the head and for a few bucks more I also decked the block .010 and run a thin solid copper marine style head gasket. I can tell you by the seat of the pants dyno the current 8 something to 1 compression ratio is quite noticeable. So my opinion a bit milling is the best bang for the buck. my engines valve to cylinder flow route is not as fussy as the ford engine but more squeeze makes more bang especially with todays fuel blends.
  24. rusty valley
    rusty valley
    agree. a little higher compression is often the best thing you can do to old motors
  25. Ziggster
    Ziggster
    Add another 40% when you have CAN$$$. I just can't justify an additional CAN$2K for "performance" aluminum heads, intake, and carbs. I'm in already in over US$2K in parts alone for a non-performance build and counting, and still waiting on the cost for the machinist work for a short block.
    Desertislander and ramblin dan like this.
  26. tubman
    tubman
    I like Edmunds aluminum heads because the slight relocation of the spark plug so it's not over the valve head allows me to run extended tip plugs. I have had great success with them. I have been lucky enough to find two sets of the 8BA version used for less than half of what new ones cost. Not matter which you chose, make sure and check the clearances and modify them for a consistent .045-.050 clearance over the piston dome to get the proper "squish". A couple of posters have mentioned this in p***ing, but I believe it will do as much or more than the increase in compression will. Check 'em, mill 'em, and grind 'em to get the "squish" right, and you'll be happy with the results.
  27. Machwon169
    Machwon169
    Ok I’ll have to just decide how the budget looks at the end
  28. Torana68
    Torana68
    from Australia
    You can’t find good usable second hand aluminium heads where you are?
  29. 51box
    51box
    from MA
    It all depends on what you are after in the end. Any engine stock vs. more carb, bigger cam, higher compression, heads etc will make a big difference. It’s about a matched combination, not one part alone that makes an engine perform.
    patmanta likes this.
  30. Machwon169
    Machwon169
    It took 3 months to find a decent engine let alone a set of heads. I’m in a NJ
