Technical Backfire/Spitting through carb - troubleshoot?
Discussion in 'The Hokey Ass Message Board' started by NewToMeT, Apr 29, 2019.
  1. NewToMeT
    NewToMeT
    OK, so having a bear trying to get the SBC running smooth. Thought I had it, but alas seems to change its mind if I look at it funny. Now getting a backfire through the carb (seems to always be the one over the 5/7 cylinders) on acceleration.
    SBC 283 with 4 Holley 94. All recently rebuilt. 1 turn out on all 4 seems to give the best response.
    Timing was set to 10 initial. Vacuum advance pulls another 15 or so, on the manifold. Mechanical is working and goes all in by 3000 rpm. Richening the mixtures (1.5 turns all carbs) made the car run like ****, so not sure if would have helped the backfire. Checked the accelerator squirt in the offending carb and seems to be doing its job.
    Double checked the wires, all in the right spot. Made sure they were all separated.
    Starts and idles OK.
    Not sure where to head next other than an intake with a single 4 barrel :)
    What would you guys do next?
  2. sevenhills1952
    sevenhills1952
    "Timing was set to 10 initial. Vacuum advance pulls another 15 or so, on the manifold. Mechanical is working and goes all in by 3000 rpm."
    All in...what? 10° initial, +15° vacuum advance (intake...not ported?)... what's the total?
    Sent from my Bell Candlestick
  3. Starts at the basics square 1.
    Build up from there.
    Doing this I always start with a compression test.
    Piston stop timing marks verification.
    Plug wire routing and firing order.
    Funny that 5/7 is most common mix up too.
    If you’re getting fire out the carb that generally means something is sparking with an intake valve open,,,
    missysdad1 and olscrounger like this.
  4. squirrel
    What intake manifold is it?
  5. TRENDZ
    TRENDZ
    ***uming the ignition is correct, and the engine is mechanically sound, I would say that that particular carb is way lean.
    Popping through the intake is a lean condition.
    While the engine is running, p*** an un-lit propane torch over that carb. If the rpm picks up, its lean.
    3340 likes this.
  6. Blues4U
    Blues4U
    from So Cal
    I don't know if this will cure the backfiring, but just setting the idle mixture screws all the same at 1 or 1.5 is not how you do it. Each idle mixture screw on each carburetor has to be fine tuned individually. Use either a tune up tach that will show precise rpms at low speeds, or a vacuum gauge, and adjust each screw, one at a time, to achieve maximum idle speed or vacuum reading. Then turn the screw back in slightly to achieve about a 20 rpm drop, or a slight drop in vacuum. Then readjust the idle speed set screw and move to the next screw/carb. Do this one screw at a time until you've done them all, then start over & do it again. This is quality time spent with your engine, better than polishing valve covers.
    Boryca likes this.
  7. NewToMeT
    NewToMeT
    It is an Offy
  8. squirrel
    I figured it probably was.
    Tell us about when it backfires, what are the driving conditions? you said it's under acceleration...but at what RPM range? what throttle opening range? does it always do it, or only under certain conditions?
    Also, as mentioned, what is the total timing advance? you told us initial, vacuum, and that it's all in by 3000, but we dont know what the total mechanical advance is.
  9. NewToMeT
    NewToMeT
    Timing was verified with piston stop tool. Marks were accurate, halfway between the stops.
    Compression was good in 7 of 8 cylinders. One was a bit lower, but not much. Got better with oil added to the cylinder. This was the #3
    I checked and rechecked the firing order around the cap, but will check again now that my frustration has worn off from the weekend..
  10. NewToMeT
    NewToMeT
    Will have to check my notes, but if I remember it was adding 12-14.
    Engine was warmed up. Have only been taking it around the block as its all in testing phase. Will do it accelerating when at cruise. Less so from a stop but still occurs. No tach in the car so would be guessing at the RPM at cruise. Tested the mechanical with the RPM gauge on the timing light.
    Have not really tested all the condition because I didn't want to blow something out before I had a better handle. Majority of my wrenching to date is from book learning, so figured I would stop for some real world input before I hurt something..
  11. squirrel
    do you have a dial or digital readout timing light, so you can see what the total timing is? If you are getting 12 degrees in the distributor, that's 24 at the crank, added to 10 initial, would put it at 34 degrees total (without vacuum), which is about right. but checking it with a light would be a place to start.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    I get a kick out of people : "compression was good"....
    Well, how good was it ?
    " one was lower but not much"
    Well how much is not much?
    " 12-14° "
    Crank degrees or can degrees ?
    Seems that getting accurate , usable , specific information is REALLY difficult ... .,
  13. NewToMeT
    NewToMeT
    its a Digital light, and has the ability to set (not sure what this is called) the timing reading (i.e. input the advance on the gun to 34 for example, and it will bring the timing mark back to 0 on the balancer to confirm the reading).
  14. NewToMeT
    NewToMeT
    Sure, thanks for asking. I did note that I am new to all this ;)
    Compression was in the 130s in the 7. (all well within 10% which I understand is important). the other was 110s
    the 12-14 degrees was measured with a timing light using the marks on the balancer.
    Any thoughts?
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    If your initial timing is 10° and the mechanical is only adding 10-12,° then your timing is severely retarded at 20-22° .You should have a total of 34-38° total (initial plus mechanical) . Vacuum advance is for cruising , don't worry about it .......
    squirrel likes this.
  16. NewToMeT
    NewToMeT
    Advance is attached to the intake manifold. The two rear carbs on the motor have vacuum ports (These are ported vacuum? Currently have plugs in them) Tried using one of them for a vacuum source, but there was no impact on performance. I then checked them with a vacuum gauge and they they barely pulled any vacuum at all, not enough to move the vacuum advance. I checked the Vacuum advance function with a mighty vac and it needed more vacuum than the carb was pulling to give its full advance)
  17. squirrel
    disconnect the vacuum advance, leave it disconnected and plugged for now....
    Set the timing so the total at 3000 RPM or so is 36 degrees, and then tell us what the initial timing is.
    And take it for a drive, see how it does.
    Rich S. and jimgoetz like this.
  18. After verifying timing - advance - firing order, that sort of thing, check the distributor cap for carbon tracks (allowing wrong cyl. to fire at wrong time). It's also possible you have a loose or broken rocker arm or a worn camshaft lobe causing you problems.
  19. Doublepumper
    Doublepumper
    from WA-OR, USA
    Points adjustment OK?
  20. NewToMeT
    NewToMeT
    Gotcha.
  21. NewToMeT
    NewToMeT
    Will do
  22. NewToMeT
    NewToMeT
    measured with a feeler, seem to be right based on the what the book stated. Have not done a dwell measurement.
  23. Petejoe
    Petejoe
    from Zoar, Ohio
    Ported and Venturi vacuum operate differently.
    Holley 94s normal port is Venturi.
    The power valve will blow out whenever you backfire.
  24. Thoughts -
    That cranking compression ****s at 130
    110 is not good .
    Did you say this was a recent rebuild on the 283?
  25. Doublepumper
    Doublepumper
    from WA-OR, USA
    Valve adjustment OK?
  26. Rickybop
    Rickybop
    X2
  27. Rickybop
    Rickybop
    Check for full motion of valvetrain.
  28. NewToMeT
    NewToMeT
    If this was ever rebuilt I am not aware
  29. NewToMeT
    NewToMeT
    Cant speak to it other than I dont hear any noticeable clacking.
  30. Doublepumper
    Doublepumper
    from WA-OR, USA
    Was thinking tight side.
