Hot Rods 1937 tube axle 1939 i beam - different dimensions
Discussion in 'The Hokey Ass Message Board' started by nobby, Apr 30, 2019.
  1. nobby
    nobby
    hello, did the 37 tube axle have its own wishbone
    or did it run a 37 wishbone
    the I beam pictured is 1939 does it needs 39 bone
    It wont fit my incoming 37 unsplit wishbone then, so don't buy it and dop it a bit, wait for mine to come
  2. 1946caddy
    1946caddy
    from washington
    Looks to me like your tube axle is made to fit a 28-36 Ford with 36 1/2 spring perch spacing and narrowed to 48 1/2 " for king pin spacing.
    I would send the I beam to Sid for him to drop if it was up to me.
    Sid can stretch the drop to maintain the 48 1/2" kingpin spacing on the I beam.
  3. alchemy
    alchemy
    Are you sure that's a 39 I-beam? Show us a front view.
  4. Fordors
    Fordors
    That beam looks to have the wider perch spacing of a post WW II axle. And as @alchemy said show us a front view. There are easily seen details that will help ID it.
  5. Bruce Lancaster
    Bruce Lancaster
    This info should be re-checked as it has been a long time since I read it in the 1938-9 Ford resto book from the V8 club. Roughly, Ford installed tube axles on small sample numbers of 1938-39-40 85 HP cars ***embled in michigan and on some of the very few 1940 '60's. No mention of other 60's or of 1937. These seem to be just a few tubes at a time as a sort of consumer durability tests.
    Now, what you may have...some were made for Model 62 for V8 60's
    If 62 use a slightly narrower than regular US?Canadian pattern wishbone, I think that's what you have. The 62 also got small numbers of partial production tube axles. I think the tube axles for them were slightly oval?
    The 62 was an England and Europe only Ford that looked like a mix of Zephyr and '37 ford styling.
    Most common was probably the French Matford. These were all V8-60 until WWiI...then they got 85 engines foe WWII use, and kept them as the Ford Plot until about 1953.
    Moriarity likes this.
