Projects "I'm here to pick up the rubbish"
Discussion in 'Traditional Hot Rods' started by Drylake, Jul 18, 2016.
  1. Drylake
    Drylake
    20190430_100136.jpg Finished up the front cross member, after doing a mock up to ensure everything was going to fit correctly. I've trimmed the mech brake cross over down to fit the hydraulic brakes and got my head around the way it will function.
    It's not complicated, 20190430_130937.jpg but it is new to me. 20190430_100109.jpg
  2. sloppy jalopies
    sloppy jalopies
    Yet another good idea is those idle engine stands as a rotisary … the weight of the frame will not be a problem...
    this post has been great, lots of neat stuff going on...
    i am going to weld up a new set of '32 rails, A crossmember, drop out ****** mount, '37ish x member and a square / rectangular tube rear crossmember...
    going to pie cut the '32 rails just beyond the rear crossmember, tip them down, and weld on a pair of A front horns upside down with a 2" diameter stainless spreader bar between them...
    a rotisary like yours will be the cat's azz...
  3. Drylake
    Drylake
    Back on the ground to check a few things. I plan to drop the motor and trans in, and start work on shortening the radius rods. I'll also check how the rear wheels line up with the wheel wells.
    I'll need to make up a spring spreader to get the rear spring installed. The 36 radius rod perches need the angles tweaked to get them parallel to the spring ends as well.
    I'll also finish shortening the torque tube and drive shaft. 20190501_164806.jpg
  4. Drylake
    Drylake
    Back together for drive train adjustments. 20190502_150641.jpg threw the blower on it for fun!
  5. Drylake
    Drylake
    Lined up another 40 ford rear spring... sold the last one and forgot I needed it to help centre the rear wheels to the wheel well... 36 radius rods with the 32 spring doesn't work too well!
  6. Drylake
    Drylake
    Spring is in! So I rolled the roadster out to have a look. 20190506_171044.jpg 20190506_171119-1.jpg 20190506_171220.jpg 20190506_172209.jpg 20190506_173543.jpg
  7. tub1
    tub1
    from tasmania
    hello drylakes , I'm interested in this m/cyl adaption of yours, how the hell are you going to get to the dam thing when it fails ? , please understand I'm not being criticle of your idea I don't actually like were my m/cyl is mounted behind the cross member hanging down a bit ,I was thinking of raising my m/cyl and using a cantilever as I did on a model a some years ago I look forward to your thoughts by the way nice car you are building
  8. tb33anda3rd
    tb33anda3rd
  9. brEad
    brEad
    Car looks great with that swept windshield!
    drylakespeedshop likes this.
  10. Limey Kid
    Limey Kid
    That there is a great looking roadster!
    Cheers,
    Stewart.
  11. GEBHARD
    GEBHARD
    from TX...
    Everytime i look at this thread i just think ... WOW...
  12. Drylake
    Drylake
    The floor has a removable panel to access it from above. Not really anything wrong with running the master cylinder below and a lot of people do. I just like this alternative, didn't mean to offend any one.
    Here is an example of this method. Screenshot_2019-04-08-10-24-27-1.png Screenshot_2019-04-08-10-24-19-1.png
  13. qzjrd5
    qzjrd5
    from Troy, MI
    Looks great!!
  14. Wardog
    Wardog
    I ***ume @tub1 is thinking worst case scenario when/if the master cylinder has to be removed.
    Most under floor m/c’s are a bit of a pain to work on in general.
    And if it has to be done it’s usually a workshop type of a job anyway. Meaning you would have more tools, equipment and time available for such a job.
    I’ll admit I was sceptical at first but the more I look at the above photo I’m thinking I like the idea. It would definitely be more protected up in the ch***is rather than under it.
  15. tub1
    tub1
    from tasmania
    Thanks for the pics cool
  16. tub1
    tub1
    from tasmania
    Yep I like the idea however remember things don't fail in the workshop they fail on side of road in middle if Christ knows were
    chryslerfan55 and Wardog like this.
  17. simplestone
    simplestone
    Ha ha - I don't know of many people that would repair a failed MC on the side of the road.
    I love the roadster and how it's coming along. Truly inspirational.
  18. Drylake
    Drylake
    Bit of work done on the deck lid today. 2019-05-08 12.07.06.jpg 2019-05-08 12.20.17.jpg
  19. tub1
    tub1
    from tasmania
    great stuff looking wonderful
  20. sloppy jalopies
    sloppy jalopies
    clever mc placement...
    I don't like a mc on the firewall...
    so I let the pedals pull...
    mount a bel-crank behind the seat, with adjustable rod [red] and clevices…
    then added 4 holes for mechanical advantage in the bel...
    mount the mc behind that...
    hole in the trunk floor not the carpet to add fluid...
    I also paint anything you can't see from the outside white, if I have trouble it reflects light so I can use both hands and not need to point the light right at the screw / nut to see it....
  21. Drylake
    Drylake
    20190509_154000.jpg Surprising how well this original bonnet is cleaning up!
  22. brEad
    brEad
  23. Drylake
    Drylake
    20190516_143752.jpg 20190517_142417.jpg Played around with gauges recently and got the rumble lid installed. Still have a few things to sort out with the steering, such as shortening the adjustable drag link, getting the taper and key way machined to fit the steering wheel, outer steering column tube replacment, lots of little things.
  24. Drylake
    Drylake
    Bit of work on the backing plates. 20190523_084739.jpg 20190523_085841.jpg 20190523_102621.jpg 20190523_115644.jpg 20190523_130134.jpg
  25. Drylake
    Drylake
  26. continentaljohn
    continentaljohn
  27. RICH B
    RICH B
    Curious as to why you have two different kind of rear plates?
  28. Drylake
    Drylake
    It's all I could get my hands on.
  29. Drylake
    Drylake
    Played around with the rear fenders, mainly working out the lines I'd like for them. Also having a clean out of parts as I decide what I'm going to use and what I can turn into funds for the roadster. 20190524_132939.jpg
  30. Cut-up rocker cover for scoops?
