Vintage Sun Tune Up, Testers, Scopes, Analyzer, Distributor Thread
Discussion in 'The Hokey Ass Message Board' started by Flathead Johnny, Oct 14, 2013.
  1. Truck64
    Truck64
    from Ioway
    Huh, I didn't know that. Isn't there a ballpark figure available for what the full kit might have cost though? Cabinet, bells + whistles and the rest of it? Just curious.
  2. The Big Shop
    The Big Shop
    hi we have the tut-1015 and cant seem to locate a manual anywhere. Do you have one or can lead me in the right direction? we mostly need a wiring diagram to get it up and running
    Bowtie Coupe likes this.
  3. The Big Shop
    The Big Shop
    Hi im needing some help please we have a sun tut-1015 and need a wiring diagram and manual for it and I cant seem to find one anywhere. We would love to get it up and running for our shop
  4. sirstude
    sirstude
    There is one on Ebay right now.
    Bowtie Coupe and loudbang like this.
  5. rowdyauto
    rowdyauto
    just acquired this, wiped it off and that's about it haven't tried plugging it in yet. 032.JPG
    Kan Kustom, cactus1, loudbang and 2 others like this.
  6. Truck64
    Truck64
    from Ioway
  7. Nice find. I have never seen a King tester, and it looks like a nice unit.
    I have a Sun and a Precision tester, and still use the Precision on my older engines. I hope your machine turns out to be functional, but it probably wouldn't take too much work to restore it. Normally these machines can be repaired by simply testing and replacing the defective electrolytic capacitors.
    Bob
    Kan Kustom, Bowtie Coupe and loudbang like this.
  8. ClayMart
    ClayMart
    Thanks for the link to that manual. That makes for a nice "tune up" refresher course. Even shows how to test old Ford Load-O-Matic distributors. :rolleyes:
    loudbang, Bowtie Coupe and Truck64 like this.
  9. Truck64
    Truck64
    from Ioway
    There sure is a lot going on inside an ignition distributor! 'Course it's all done by soul-less, inscrutable electronic boxes and gee-gaws today, which is of course a big improvement.
    Any of you Wizards know if this superimposed primary waveform indicates excessive distributor shaft wobble? It was a rebuilt Cardone distributor. I put in a different rotor and it tightened up some.
  10. dan griffin
    dan griffin
    Check the end play between the cam gear and the dist. housing. If the shaft has to much play [.120 or more] there will be a slight change in point opening. If this so shim it to .010.
    Bowtie Coupe, loudbang and Truck64 like this.
  11. Terranova
    Terranova
    This is a Sun "engine speed control" tool /fixture. Anyone have instructions or experience with one? How does it work? I mean, I get the general concept, but how/where is it placed?
  12. Terranova
    Terranova
    I picked this out of my parents garage while cleaning and decided to check it out. !
    Low and behold, look what it mentions! Ha!!!
  13. oj
    oj
    I wonder how many of them got left on the engine when it was ready to actually start?
  14. tinsled
    tinsled
    I bought an old "Mac Allied Tools ET-440" tester as shown in photo below:
    Inside it looks othervise Ok, but the battery holders were rotten because of leaking old batteries.
    Looks like it had 6pcs size C 1,5V batteries (add up to 9V in total) and one size D 1,5V battery in another circuit.
    The holders were beyond repairable, thus I hooked a 9V power supply for the main circuit and common 1,5V battery for the other.
    When tested, it shows the dwell angle, but needle does not move when switched to tacho mode.
    Any suggestions, what might be wrong with the tester?
    (I hooked the red wire to distributor (-) terminal and black wire to car ground.)
  15. WTF really
    WTF really
    Done some horse trading and got this today. It's double sided with the hangers. 20190425_132756.jpg
  16. I added this little guy to the collection recently. 3B83FBC2-AA7B-47D6-846C-6F30471B273E.jpeg
    Cleaned up and placed with its counterparts.
  17. Nice find.
    Bob
    cactus1 and loudbang like this.
  18. Terranova
    Terranova
    Anyone have a spare one of these gauges they’d let go of? AC257879-828A-491D-91C4-19FB5EBBD718.jpeg
  19. egads
    egads
  20. That's a beaut'! Is the finish close to original, or did you have to "touch it up"?
    egads and loudbang like this.
  21. egads
    egads
    Thanks, Found it on the top of a 10 foot tall junk pile. I repainted the stand and rear cover, blasted the aluminum tray but just gently cleaned up the chrome ring,face and gauges. Still have to put on the cables and find the missing gauge.
    Bowtie Coupe, loudbang and WTF really like this.
  22. ClayMart
    ClayMart
    That's a beauty! :eek: I think that's gotta be the earliest piece of Sun test equipment I've ever seen. :D
    Any idea what the missing gauge is? Wouldn't mind seeing some more pictures of this in better light and from a couple different angles if you have time to mess around with it.
  23. egads
    egads
    Don't know what the gauge is, found a manual, but it only show's 3 gauge's.:( Hope this is not too many pictures. DSC00006.JPG DSC00007.JPG DSC00015.JPG
    Bowtie Coupe, loudbang and cactus1 like this.
  24. Any markings on the back of the instrument panel? I was going to say "high voltage" for coil output, but that might be what the center "Resistor In/Out" does for you? Lead connections seem to indicate it only tested voltage or current.
    Can you draw or photograph how what is there is wired? That might tell you what the missing component was supposed to do?
  25. Truck64
    Truck64
    from Ioway
    Betcha it was a vacuum gauge?
    egads likes this.
  26. egads
    egads
    I was thinking a tach-dwell ? There are 2 empty wires behind the hole.
  27. Truck64
    Truck64
    from Ioway
    Ok... I bet that's it
    egads likes this.
  28. loudbang
  29. Truck64
    Truck64
    from Ioway
    I want one! There was a time, ya probably couldn't give those away. I've never seen one available.
