Technical are scatter shields necessary?
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, May 3, 2019.
  1. tb33anda3rd
    tb33anda3rd
    glad to hear! sorry for the damage. thanks for the update and the tip about not drilling into the housing.
    I started the thread, so damage and/or any injuries might be avoided or minimized in the future, not to spread rumors or face book drama.
  2. jnaki
    jnaki
    https://www.jalopyjournal.com/forum/threads/willys-owners.999990/page-9#post-11609788
    No rumors or made up comments, "just the facts, ma'am."
    Hello,
    That is some scary photo. (some work, cir***stances prevent it other times…)
    In August 1960, upon seeing our C/Gas Willys coupe the next day after the clutch explosion, fire and crash into the Lions Dragstrip fence, we were amazed. It did not have a huge plate sticking up like the photos, but there were a million metal pieces wedged into the steel dash, door and window frames and lower kickplate areas.
    Luckily, my brother did not get any metal fragments on or in him. A helmet, long sleeve shirt and his lucky, favorite, nylon Wynn’s Friction Proofing jacket helped. But, those items did not prevent the 3rd degree burns, despite the fire extinguisher.
    We had the required two piece metal ****ter shield that all of the top racers were using at the time. The explosion was so horrific and powerful that the ****ter shield, the clutch and bellhousing were in pieces and nowhere to be found in the burned out interior. Just a giant hole in the floorboard where there used to be a nice, curved, metal replacement floor.
    https://www.youtube.com/watch?v=1zYm8Mqfvfo
    Jnaki
    Yes, a 360 degree one piece probably would have helped. (not made at the time, but several months later by Lakewood) But, the brute force in those explosions is unparalleled in power. The burns were terrible with 30% in 3rd degree. The Moon Tank in the cab was the culprit for the fire. (the law was p***ed to move all tanks to the outside within two weeks…)
    Sorry, if we started the outside Moon Tank, awful fad…Most of the top racers put them just behind the grille, where they should have been in the first place.
    upload_2019-5-4_4-59-30.png Thanks, @elgringo71
    BUILT IN 1961-64, PUBLISHED IN 1966
    (In 1961, he had the Moon Tank inside of the cab, but being with us (pit crew) on August 1960, Atts Ono immediately moved the tank to the front, behind the grille)
    https://www.jalopyjournal.com/forum/threads/g***ers-good-or-bad.1063887/page-4#post-12864215
    catdad49, wicarnut and Dog_Patch like this.
  3. Deuces
    Deuces
  4. PHIL COOPY
    PHIL COOPY
    If you could see my friends legs you would say yes.
    OLSKOOL57, loudbang and Deuces like this.
  5. greg32
    greg32
    from Indiana
  6. Deuces
    Deuces
    Years ago, I installed a Lakewood in my Z/28 due to the high winding nature of the little 302... I felt a little more secure after that....;)
  7. town sedan
    town sedan
    @Dog_Patch I'm glad you're unhurt. As a kid I remember seeing the photos of Don Garlits' car when it's clutch blew. I was also at the HAMB drags a few years back when one of the racer's flywheel took out the mirror of a truck parked in the pits.
    Good luck and safe travels in the future.
    -Dave
  8. bobss396
    bobss396
    I run cast iron truck bells in my cars, have been doing that for years, on the street and on with stock cars. Not a tremendous amount of protection and I stopped pulling hole shots decades ago.
    But that sudden release of the clutch pedal at 7 or 8-grand is another story. I would think that QT would want a closer look at the blown up one and pony up a fast replacement on the house.
  9. Rickybop
    Rickybop
    Wow.
    Seeing this kind of stuff helps me to be plenty satisfied not being a drag-racer. And having engines for my cars that will likely never exceed 5000rpm.
    OLSKOOL57, Deuces and scotty t like this.
  10. Deuces
    Deuces
    Yep! Now days I keep my revs below 4500 rpm...
    Even though the tach don't start redline till 7400... :confused::D:rolleyes:
  11. '34 Terraplane
    '34 Terraplane
    from Western PA
    Are ****ter shields necessary? Two pre-****ter shield days pictures are worth two thousand words !!
  12. Rickybop
    Rickybop
    You know how they make a particular component the weak link so that the rest of the components don't break?
    Just wondering if it might work to make the right side of the bellhousing/****tershield a little bit less strong than the left side... so that if it does explode, the flywheel would tend to go to the right side of the car... away from the driver.
    Sent from my VS835 using The H.A.M.B. mobile app
  13. jimmy six
    jimmy six
    Looks like the trans input shaft broke by the center of the disc. All of our sticks have SFI housings but do not see launches. We also use solid centers. I glad he wasn't hurt.
  14. Rickybop
    Rickybop
    The direction of the rotation of the flywheel would tend to send it to the p***enger side anyway... if anything. There's such great force though... It might not make any difference.
  15. Rickybop
    Rickybop
    I may be ***uming wrongly that the flywheel would even stay in one piece. Tell me... does the flywheel actually explode... breaking into multiple pieces?
    OLSKOOL57 and loudbang like this.
  16. Deuces
    Deuces
    Or, how about a dual disc clutch setup like on my car????......
  17. 51504bat
    51504bat
    Unless of course you're in the UK or down under!
  18. If the fly wheel is cast it will break into pieces large and small. If it's a steel fly wheel it won't. Just the other week I upgraded my 66 chevelle with a ****ter shield and steel flywheel. It's good insurance.
  19. tb33anda3rd
    tb33anda3rd
    what are the best ****tershileds out there?
  20. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Agreed on them needing to do a postmortem on the blown part to look for failure points and opportunities for improvement.
    Looks like Holley now owns Quick Time. They also own Lakewood.
    I run a Lakewood bellhousing in my street car. Good piece of mind.
  21. bchctybob
    bchctybob
    I would not want to beat on a stick shift car without one.
    My Austin has scars from some sort of clutch catastrophe, makes me wonder if that's the reason it went into hibernation for so many years. Nowhere near as bad a QnD though. (I closed up a lot of the damage)
  22. s55mercury66
    s55mercury66
    from SW Wyoming
    Does anyone know the test procedure used for testing the containment capabilites of ****tershields? I used to work in a grinding wheel factory, where we speed tested each wheel to 1/3 over it's rated speed. It was quite an experience when a 42 inch wheel (rated @900rpm, tested to 1200) would let loose. I had a neighbor who got hit in the head with debris from a clutch explosion at Indy in 1969. He was blinded for life at 16, had gone to Indy for his birthday, and due to the accident he never got to drive his brand new Boss 302. His dad drove him around in it though, for years afterward.
  23. gene-koning
    gene-koning
    An 1/8" thick ****tershield is pretty thin considering what is expected of it, that should be the 1st warning. The Lakewood I ran was 1/4" thick, or 2x the protection.
    Years ago I put a Lakewood ****tershield on my street driven Road Runner, the guy at the local speed shop wouldn't order one for me because he thought it was a waste of money on a street car. History proved it wasn't necessary, but it wasn't the speed shop owner's feet next to my bell, it was mine. I ordered the Lakewood from someone else. A few weeks before I had went in to order the ****tershield, I spent some time one night digging chunks of a flywheel out of the street, the results of a very fortunate Nova driver's holeshot.
    The rotation of the flywheel is clockwise. If the flywheel (or clutch) come through the bell at the bottom or on the left side of the rotation, everything would be coming towards the drivers feet and the dash. He was lucky the ****tershield failed where it did. Gene
  24. Imperial Kustom
    Imperial Kustom
    I too run cast iron bellhousings. Right now I am using a '60-63 GM truck bellhousing (hydraulic clutch) in my '62 Chevy II. It has scars inside from a 6500+ RPM clutch explosion but I still have all my pieces and parts. I do think a can is in order though. ( gonna have to switch to a hydraulic bearing too )
    Deuces likes this.
  25. Elcohaulic
    Elcohaulic
    Manually shifted Turbo 400 all the way.....
    mohead1 likes this.
  26. Don't think a automatic can't explode with the same results. A blanket or shield is needed on those. I have blown a few. Parts come through the floor and dash the same.
  27. Dog_Patch
    Dog_Patch
    C1A8FF3F-AEDF-4C6A-975B-8356DACB19A8.jpeg Goals- saw this at the top fuel pits yesterday
    saltflats, OLSKOOL57 and Deuces like this.
  28. I say go old school!
    This is an Ansen I found at a yard sale a few years ago.
    The guy was using it to hold a tarp down and seem shocked I or anyone would it! "Are you sure you wouldn't rather buy some used baby clothes or junk lawn equipment?"
    Note the bottom piece that is always lost came with it
    Sold
    [​IMG][​IMG][​IMG][​IMG]
  29. Dog_Patch
    Dog_Patch
    That’s why I had to make a drawing - looking from the front it’s clockwise. From the back it’s counter clockwise. The steel hat beat the dowel pin out of the block and the bell bolts weren’t meant to support the side load and they all sheared. Engine tilted forward broke the front motor mount, trans popped out of the pilot bearing and away squirted the disc
    saltracer219, saltflats and catdad49 like this.
  30. Mr48chev
    That solid disk has to act like a giant throwing star when the clutch blows. I'm just wondering if that may be too much spinning force for the way most ****ter shields are made that have contained clutch explosions of less stout disk ***emblies. That what looks like 1/4 plate hub is going to go somewhere no matter what you have around it.
    Dog_Patch likes this.
