Projects just bought a 39 merc. pretty o.g.
Discussion in 'Traditional Customs' started by gas man, Apr 30, 2019.
  1. gas man
    gas man
    from socal
    just got this 39 mercury. my plans are to get it road worthy and just enjoy it. I think a guy with the last name newbill from socal owned it at some point . it also spent some time in north Dakota. I have most of the trim. just need the correct headlights , tail lights , and a ash tray. 20190427_092015.jpg
    pulled the old seat covers off
    found this tag under the seat
    going to install all new brake components
  2. hoodwinx454
    hoodwinx454
  3. 41rodderz
    41rodderz
    from Oregon
    Nothing like a new project to get the juices flowing.
  4. 0nedon
    0nedon
    Great project, makes a lot better when it is mostly complete, have fun with it!
  5. rusty rocket
    rusty rocket
    Mercs are kool! Did the 4 doors have the weird soup can tail lights hanging off the side?
    RICH B likes this.
  6. Boryca
    Boryca
    from Detroit
    Love that dash!
  7. edwardlloyd
    edwardlloyd
    from Germany
  8. 392
    392
    Cool project. Looks solid.
  9. gas man
    gas man
    from socal
    yes , it had the taillights that look like there looking the wrong direction.
  10. rusty rocket
    rusty rocket
    Never could figure that out, lice swooping body lines and a soup can hanging off the side in the rear. I can just imagine the designers being told- hurry up we have to get this on the ***embly line. Hey Fred that soup can from your lunch would work for a tail light.;):)
  11. brokedownbiker
    brokedownbiker
    Niiiice! I love cars that are uncommon and the fact that it is a more-door is icing on the cake! Long swooping lines and almost looks chopped, great project.
  12. gas man
    gas man
    from socal
    91459.jpeg i have tried everything and cant get the rear drums off. glowing red drum, hydraulic puller, regular pullers , I even made my own puller. i bent the axle where it exits the drum with the hydraulic puller so I grinded the damn thing off. so being new to old mercury's, what do you know, this is a 2 year mercury only axle shaft . I'm also learning its very hard to find these drums . what would be the best way to go about this ? find original axles ? convert to something else that accepts the later hub and drums ? I'm not really sure what fits and what's available. any help would be greatly appreciated.
  13. s55mercury66
    s55mercury66
    from SW Wyoming
    You might want to start a new thread on your drum/axle issue, with that info in the ***le. You will get a lot more attention if you do. Good luck!
  14. edwardlloyd
    edwardlloyd
    from Germany
    Well you're doing it wrong and could bend your hubs or snap your drums.
    Pulling a wide five is a problem I admit. There are hub pullers which fasten around the ridge on the hub nose so it's more direct.
    Sent from my SM-G935F using The H.A.M.B. mobile app
  15. edwardlloyd
    edwardlloyd
    from Germany
    Now you've cut the axle the whole thing is junk anyway.
    My advice: convert to 1940 hubs and use Lincoln Bendix brakes all round with 1940 wheels. You can buy the 1940 wheels in many widths new.
    You can get a complete Lincoln Bendix brake and hub set from MT Boling Brothers.
    You'll get money for your wide five take offs.
  16. gas man
    gas man
    from socal
    but what axle shafts do I use ? I found a 48 Ford rear end , should I just buy that ? its cheap
  17. rusty rocket
    rusty rocket
    My advise woud be to head over to ford barn and ask the old timers what interchanges with merc.
    Maybe do some research first before tackling a project. Theres lots of weird litte things about old ford that you should know.
  18. abonecollector
    abonecollector
    it seems like the best alternative is to change everything over to ford axles, that way you can find/buy the more easily obtained parts. On a side note, i bought an N.O.S. pair of those drums, & hubs at an auction a few years ago. I thought i did good. Seemed like i was going to have to give them away. I finally settled on an ebay sale for a little less than i had in to them
  19. gas man
    gas man
    from socal
    got a entire rear end from a 40 Ford .
