Customs New project: 56 Olds!
Discussion in 'The Hokey Ass Message Board' started by chopolds, Nov 10, 2018.
  1. K13
    K13
    Looking great Mark! I love purples and pinks on customs so really love the colour ideas!
  2. Peanut 1959
    Peanut 1959
    I posted your comments over on the Photoshop thread and this is what the moose came up with. Getting closer. tapatalk_1557641906629.jpeg
  3. Baumi
    Baumi
    That' s a way cool project , this is going to be great! I' ll be watching and learning!
  4. BJR
    BJR
    That looks awesome!
  5. chopolds
    chopolds
    from howell, nj
    Thanks guys! And thanks Peanut 1959! Got a quandary now. I was offered a pretty nice Safari shell, with ALL the trim and gl***! It would save me a bit of work, though at this point we're pretty far along. Is it really saving me that much work?. I could use all the little detail parts, as well as all the good sheet metal, but I feel a bit guilty cutting it up just for the upper quarters and tailgate area. I'll have to see how the deal works out.
    chryslerfan55, Sancho and loudbang like this.
  6. Hot Rods Ta Hell
    Hot Rods Ta Hell
    If you're going to leave the roof stock height, consider if it would be easier to hang the Olds quarters, front clip and dash onto the Safari shell...
    Either method leaves you welding the upper quarters/roof to the quarters or the quarters to the upper quarters/roof.
    Hanging the Olds sheet metal on the Safari, keeps the main structure of the body together and solidly aligned (roof and posts, gl***, inner structure, tailgate jamb), leaving you installing/skinning one "minor" body panel at a time. It keeps you from having to reposition/weld in a roof ("major" body panel) and saves all that gl*** work.
  7. Peanut 1959
    Peanut 1959
    Here's another Photoshop version, this one by Rot 'n Kustom:
  8. Peanut 1959
    Peanut 1959
  9. Rocky
    Rocky
    Classified Editor
    56safarindrive.jpg 56 olds88.jpg I'd love to see it with the 88 trim..I know, beating a dead horse but I love that 88 trim[ATTACH=
  10. Rickybop
    Rickybop
    I must say...some of you guys are absolutely fearless with the slicing and the dicing and and and...everything.
    The the version in Peanut's post #67 looks factory-built.
  11. chopolds
    chopolds
    from howell, nj
    Well, I got the Safari. Wasn't quite as "clean" as described, but it DOES have all the trim I need, the interior moldings, back seat, and gl***! Dis***embling it now, hope that the metal behind the stainless is in good shape.
    Big "Thank You" to Vic Collins and his brother Ed, for digging this out and bringing it to the shop, and to Lou Callisibetta for letting go of this hard to find car!
  12. chopolds
    chopolds
    from howell, nj
    Still working on it! Summer brings lots of heat and humidity, so the going is slow (Plus I like to go on vacation!!!!) The Safari parts car yielded much needed interior trim, gl***, back seat, but the sheet metal is pretty much wasted. I may be able to use the tailgate jamb skins, possibly the inner structure, but nothing outside.
    Screwed up the front roof seam BIG time! so cutting it out and putting in a new strip of metal. I eliminated the downward curving section of the roof, so it should be easier to control the sheet metal while welding. I though I could just hammer and dolly it out, but got out of control. Also took a break to fix the mess of the front of the hood. My old mentor did a ton of brazing to fill in the hood ornament, and front emblem. Then the owner tried MIGing in small patches to fix the rot. I just cut it all out and started from scratch. 100_1011.JPG 100_1139.JPG 100_1134.JPG 100_1324.JPG 100_1314.JPG 100_1316.JPG
  13. HOTRODPRIMER
    HOTRODPRIMER
    Beautiful work.
    I gotta ask, what the heck is the tow vehicle in the first photo? , I can't figure it out. HRP
  14. Sancho
    Sancho
    Did you read the post? LOL
    "Another good friend, Dave Quail, helped me get the car back to my shop, with his 49 Cadillac Limo, mounted on a Ford F350 Ch***is, running a Caddy engine!"
  15. guthriesmith
    guthriesmith
    Just found this thread and love the concept! When I was in high school, a buddies folks had a 55 Nomad that we cruised regularly and I also worked on some as well as doing paint and body on a 57 Nomad for the same family. That and my love of Pontiacs years ago made me want a Safari even more. But, this will be better than either the Nomad or Safari and will sure make folks think.
  16. chopolds
    chopolds
    from howell, nj
    Been a long time since I posted. I have been working on the car, in between other projects. 41 Willys, I did body and paint on, as well as fixing as many mechanical issues, as I could stand to (the owner tried to do it all himself!). Also working on collision repair on an old friend's custom 50 Chevy. Gearing up to get back on LesPoPo (waiting for the owner rebuilt ch***is). Even with "lockdown" there doesn't seem to be enough time in the day to get it all done!
    First, how about a shot of the messy shop! And the distractions. 100_1923.JPG 100_1948.JPG 100_1949.JPG
  17. chopolds
    chopolds
    from howell, nj
    Now on to the build. I finished up the roof, except for some pinholes in the rear corners. Fabricated the area around the tail gate. Finished most of the window channel replacement.
  18. chopolds
    chopolds
    from howell, nj
    Finished up the rust repair on the hood. My buddy with the chopped 54 Plymouth, Kenny, helped out by punching and belling the inner support of the hood. I also added some tubing for support, since I took off the 'hood bird' that had support rods bolted to it. May replace the square tubing with round sometime later. 100_1324.JPG 100_1341.JPG KIMG0053.JPG
    BigRRR, X-cpe, chryslerfan55 and 7 others like this.
  19. chopolds
    chopolds
    from howell, nj
    Non-HAMB modifications! 76 Impala sub frame installed. I drive the wheels off my cars, so I want good steering and brakes. I also shrunk down the fresh air boxes on the firewall. Going with aftermarket AC on the p***enger side, and hanging a booster/master on the p***enger side.
  20. chopolds
    chopolds
    from howell, nj
    Back to bodywork. Both quarters had the usual Olds rot up at the top of the wheel well inners. They had been patched once before. Cut them out and redid them. There was also collision damage on both sides. Drivers side I worked out. Pas. side I cut out and replaced, as it was so bad. Also welded up the gas filler door.
  21. chopolds
    chopolds
    from howell, nj
    The PO used a 56 Chevy patch panel to fix the rust on the p***. side. He didn't car about the shape of the wheel well opening, as he was running bubble skirts. I picked up a set of new Foxcrafts at Carlisle, so I had to reshape the openings to fit the Olds skirts.
  22. chopolds
    chopolds
    from howell, nj
    The extensive work on the quarters, plus rust on the inner wheel wells, made me cut out the interior panels. Now I could access the quarters for hammer and dolly work. Plus, the hardtop interior panels had different structure than a wagon's, so I took the opportunity to make my own, to match up with the Nomad's quarter windows. While I didn't need an access door for the quarter window any more, I figured I would for the side trim.
  23. chopolds
    chopolds
    from howell, nj
    I was lucky that the PO had found a set of '98' tail lights, way back when. Since the Nomad was the top line trim package on the Chevy, I hoped to make my Olds a '98', as well. The tails are very different, so I got out the cut off tool and welder! Still looking for the '98' side trim, though!
    Originally I was going to just move the gas filler to the interior, but now I want to move it to behind the driver's tail light, so it isn't in the interior cabin. Gotta figure that one out!
    Caught up for now!
  24. belair
    belair
    Really imaginative and quality work. Thanks for taking us along.
    OG lil E and loudbang like this.
  25. Chaz
    Chaz
    I really enjoy watching your work..... You know your stuff.!
  26. Peanut 1959
    Peanut 1959
    What a treat to see your progress on the wagon. Keep at it!
  27. guthriesmith
    guthriesmith
    Looking good! Thanks for the update. I’ve been wondering how it was coming. :)
  28. Tony Ray
    Tony Ray
    Man that looks great!I follow you on facebook as well.I actually messaged you a couple years ago about possibly chopping the top on my 51 shoebox coupe, but ran into some house issues that kinda killed that. years ago I bought that 54 merc off Mike and met you. Was actually hoping to see if I can maybe get some work done to you this fall. Not going with a chop,but need several other mods done instead.. Anyway the Olds looks great!
  29. Rocky
    Rocky
    Classified Editor
    Alright, alright! I like the 98 trim better than the 88 trim on the photo-shopped versions. It really does flow better than the 88 trim. In fact........the version with the 98 chrome is very pleasing!
  30. chopolds
    chopolds
    from howell, nj
    Yes, you came by and got the crossmember for your car. You are welcome to visit any time! Small jobs I can bring in pretty quickly. Big ones, a bit of a wait
