Projects My 54 Chevy build [emoji4]
Discussion in 'Traditional Customs' started by Ceegan, Apr 30, 2019.
  1. Rickybop
    Rickybop
    Thoughts...FYI
    It's good to know what you have. I would find numbers on the block and heads and do some research. Determine cam, intake, carburetor, etc. too. If you can, maybe visit the PO again and ask? Knowing what you have will give you an idea of how the engine will behave, determine possible upgrades, changes, future replacements, etc.
    It's also good to know the condition of the engine. Chances are that it's a typically mild build, the components are in good condition and it was ***embled correctly. But at this point, you don't know for sure.
    A compression test is a good method of determining the overall condition of the "top end"...the heads and valvetrain. Buy a decent compression tester that threads into the spark-plug holes. Do a search to see how to use it. Basically, you want good pressure readings (search online for specs) and consistent for all cylinders. Past that, you could pull the heads and inspect/measure the cylinder bore for wear. It should be nice and smooth with no ridge near the top. You could dis***emble the heads and check the valves, seats, the fit of the valve-stems in the valve-guides, (no wiggling) etc.
    The bottom end should also be checked. Turn the engine up-side-down on the stand, pull the pan, remove the main caps and rod caps, (keep them in order!) and at least visually inspect the bearings and bearing journals for wear or damage. Possibly use a micrometer to actually measure the journals. Look for a number on the bearings that will tell you if they are standard size or oversize.
    Or just run it and cross your fingers...lol.
    If you can, test run the engine when it's out of the car. Or at least test run it in the car before you put the whole front end back on. Be sure to take a video and share the moment.
    A 2-part epoxy paint sprayed with a gun is much more durable and will last longer and continue to look better than non-hardened paint from a spray-can...especially on a hot engine.
    I like your new valve covers better than the other ones. Super-fine-sand them and polish with rouge and small buffing pads and hard-rolls. Tape off everything except the fins and logo. Paint. Wipe off the very top edges of the fins and the raised areas of the logo. Cool, man.
    You're gonna learn so much. I bet you're reading a lot and watching a lot of videos. Hmmm...let's see..."How to do a compression test". Ah yes. Well shoot...that's not hard.
    Go for it, C.
    Oh...by the way. This hot rodding stuff is gonna ruin your life. You won't have ANY time for bowling...golf...bingo...nothing like that. LOL.
    Me too. Gotta go. Replacing some wheel bearings on the pickup so I can finally go get my 440/727 for my '53 Chrysler!
    Later!
    Saxman and Ceegan like this.
  2. Ceegan
    Ceegan
    I fired the engine when I first got it for a few seconds, I also have a new carb for it that I think is a rip off of a holly and I got a rebuild kit for it. When I pulled the cam I got the model numbers off of it and called the makers of the cam and they recommended what converter and valve springs,pushrods etc. when I pulled of the oil pan I looked it over with my dad and it looked really good. I also stuck a camera down every spark plug hole and saw cross hatching. We did do a compression check while it was in the car we took it out of and it checked out. As for going and pulling the heads off and main caps I didn’t do that but I think I’ll just cross my fingers and hope everything goes well. Thanks for the reply
    Good luck on your car!
  3. Rickybop
    Rickybop
    You're way ahead of me. Nevermind. Lol.
    And thanks.
    OLSKOOL57 and Saxman like this.
  4. Ceegan
    Ceegan
    Got the front clip off going to take out the motor and install the new shifter torque converter flywheel!! I’m super excited
  5. Ceegan
    Ceegan
    Need help I bought a shifter kit that’s supposed to bolt up to my turbo 350 in the picture the shifter bolts to the ****** in a spot but there is no threads on my transmission for it to thread into. Here are some pictures if anyone can tell me what’s wrong it would be appreciated!
    Edit I figured it out it has these round things that go in it. These instructions had no mention of that!
  6. phat rat
    phat rat
    Have you considered getting the top right and making sure you can get gl*** cut to fit before spending a bundle on it?
    OLSKOOL57, jvo and Ceegan like this.
  7. fastcar1953
    fastcar1953
    keep going. if the top doesn't work out you can still get another body.
    Ceegan likes this.
  8. Ceegan
    Ceegan
    Got the front clip off, pulled motor and trans, installed starter and flex plate and got the shifter mounted on the turbo 350! Lots of progress today oh and I also got the old hood off and grabbed my new one. IMG_0001.JPG IMG_0001.JPG IMG_0001.JPG
    DIYGUY likes this.
  9. Ceegan
    Ceegan
    I’m confident I’ve got a good gl*** guy, and the top shouldn’t be to bad because my dad has a lot of experience fabbing and a lot of tools to get the job done.
    DIYGUY likes this.
  10. Ceegan
    Ceegan
    It’ll work out! Or a hope so lol.
    fastcar1953 likes this.
  11. typo41
    typo41
    See Carson at Street Rod Gl*** in Woodcrest,, he is great with gl***
  12. Ceegan
    Ceegan
    I talked to him a while back, his pricing wasn’t compe***ive. I know of 3 different gl*** guys that are better priced.
  13. typo41
    typo41
    I didn't say he was cheap, he is just one of the best.
    How many windshields to you want to buy to be chopped?
    Tman and OLSKOOL57 like this.
  14. punkabilly1306
    punkabilly1306
    from ohio
    Gl*** is something you do NOT want to be cheap about! Just because a guy is cheaper than the next doesn’t mean he’s better...think of it this way, is it really cheaper if you have to do it 2 or 3 times?
    nunattax likes this.
  15. Ceegan
    Ceegan
    I have all my windshields for the car.
  16. Ceegan
    Ceegan
    Thanks for the suggestions, I’ve got the gl*** handled by the same guy who did the gl*** on my dads car
  17. lumpy 63
    lumpy 63
  18. phat rat
    phat rat
    Is that Merc your dads car? If so that's all flat gl*** that's a lot different then cutting the curved gl*** in the Chevy windshield
    Tman likes this.
  19. Ceegan
    Ceegan
    Knew someone was going to say that lol, the guy I’m going to use for my gl*** has done a lot of our cars not all flat. Yes my dad built that Merc.
    jimmy bruns and Surfcityrocker like this.
  20. punkabilly1306
    punkabilly1306
    from ohio
    ...so your dad built the merc but the only photo you have is from street rodder [emoji848]
  21. Ceegan
    Ceegan
    I don’t need to prove anything to you lol.
    Cosmo49, jimmy bruns and JFK Killer like this.
  22. Ceegan
    Ceegan
    Starting to grind on the firewall!
    The combo of my Eastwood contour and a regular old grinder is making quick work of everything.
    [​IMG][​IMG]
    I won’t be able to get a lot done today as I’m going to show n go in downtown riverside.
  23. Ceegan
    Ceegan
    [​IMG][​IMG]
    Making progress! Flywheel on, stall converter, starter, new transmission seals, and got the motor and transmission married.
    I also ordered a billet alternator bracket that comes off the head. I’ll sand blast it so it looks cast aluminum. Going to try and get the seats in today to mock-up where I want the shifter to be.
    slv63 likes this.
  24. engine138
    engine138
    from Commack NY
    Great project Ceegan looks like a great start to nice kustom keep up the work
    Ceegan likes this.
  25. Ceegan
    Ceegan
    Thank you!
  26. jimmy bruns
    jimmy bruns
    from Chatsworth
    Don't mind these jack***es on here.... going to be a bad*** kustom dude. Keep it up! I'm pretty sure i've seen that merc before. Does your pops still own it?
    Cosmo49 likes this.
  27. Ceegan
    Ceegan
    Since your being cool unlike the other guy here’s a piece of the story. It was built by my dad for the show Chop Cut Rebuild. Since then the car was sold, got damaged and is now apart with my dad to be repaired and repainted. The car is going to be back together soon.. Here are some pictures [​IMG][​IMG][​IMG][​IMG][​IMG]
    Cosmo49 and jimmy bruns like this.
  28. LSJUNIPER
    LSJUNIPER
    from ct
    WOW!!!!!!!!!
    Ceegan likes this.
  29. Flamed48
    Flamed48
    When it comes time for suspension upgrades hit up Alex gambino ant gambino kustoms in San Jose he has the kits your looking for. He also built this 54 which may provide some inspiration [​IMG]
    jimmy bruns likes this.
  30. Ceegan
    Ceegan
    I looked into it, I may use him actually or build one with my dad if he has time. Whatever works but that’s a ways down the road.
