Projects My '32 5 Window Project - Done and Cruising!!!
Discussion in 'The Hokey Ass Message Board' started by LM14, Apr 14, 2018.
  1. loudbang
    Man you sure push a LOT of sandpaper.
    Nicholas Coe and brady1929 like this.
  2. LM14
    LM14
    from Iowa
    Sandpaper is cheap. Gotta' scuff and lever that jell coat or you have nothing. I don't actually have to do that much sanding on the putty, it's pretty close when I'm done putting it on. Get artistic with it. Also found if you hit it when it's still a little "green" you can get rid of the ridges and bumps a lot faster than waiting for it to completely cure and then start sanding on it. Knock the high spots down then let it cure to really sand it. Saves a lot of time. I like to do thin layers and sneak up on it so I'm not sanding a ton of material. I do need to sweep the floor, all that sticky back sandpaper I drop is starting to stick to the bottom of my boots!
    SPark
    loudbang and Stogy like this.
  3. Rich B.
    Rich B.
    from Portage,IN
    Fill sand prime, fill sand prime, over, and over again, seems like It will never end! Been there done that! lol
    The painting is a piece of cake. You’re prep is the most important part of the job. Once again you’re doing a great job!
    Rich
    loudbang and brEad like this.
  4. s55mercury66
    s55mercury66
    from SW Wyoming
    Another advantage to your use of thin layers of filler, is the fact that pinholes will be greatly reduced. The thicker you go, the more heat is generated when it kicks off, enlarging the inevitable air pockets, resulting in more, and larger, pinholes in the filler.
  5. LM14
    LM14
    from Iowa
    Thanks for the kind words and advice guys. Air bubbles and pinholes are about nonexistent with this method.
    Had another sleepless night so mudding it was! Right behind the door was the only low area and it was shallow. Couple light coats brought that up nicely and the rest of the quarter was great once it was blocked out. Can’t go any further on this side until the door is back on and the body is mounted on the frame again. Then I can address gaps and lines across those joints. Quarter came out nice.
    Spending the rest of today chasing parts so maybe I can start the other quarter when I’m not sleeping tonight!
    SPark
    C7C7E608-C850-4713-BE09-4C5AC5F609C2.jpeg 76131905-46C8-4D5C-B521-FC89CC521C4A.jpeg 170022F9-DD58-449E-BFF8-D87FE259D0EA.jpeg 14E1D96A-673B-460E-A570-1AE5E5224AC0.jpeg 3B871725-8D2A-4CAB-AA66-FA8177D19098.jpeg 823D0F3C-2E66-46EB-AF90-020718446C86.jpeg 5F6A554C-2563-488D-BDF1-576D01B8DEF1.jpeg
    loudbang, Stogy, brEad and 1 other person like this.
  6. DDDenny
    Besides being a great mini tech thread you are quite an inspiration.
    Great work here.
    loudbang, Stogy and brEad like this.
  7. Blue One
    Blue One
    from Alberta
    So now we're expecting to see similar progress on your deuce ;) :D
  8. LM14
    LM14
    from Iowa
    I think that sounds fair. We can shame him into working on his more!
    SPark
    loudbang and Blue One like this.
  9. DDDenny
    SPark (I think your name is Scott if I remember correctly).
    Hope you don't mind me horning in on your thread a little.
    Larry
    Believe it or not you have been an inspiration also, though I have yet to put it in play yet my plan is to get off my *** when SS money will allow some play $$$.
    SPark
    It's a long way from Iowa to Oregon but I would have let you use my poor mans' rotisserie for the underside work on your cars' body, many shoulder and neck surgeries dictated building this a mandatory approach at doing a lot of the work I can't afford to pay for.
    It's also worked well as a built in storage/roll around type dolly.
    Food for thought for your next project.
    loudbang, Stogy and Blue One like this.
  10. bchctybob
    bchctybob
    I just read through this whole thread, it's just amazing. Your talent and drive are way beyond most. Best of luck with your treatments, can't wait to see the coupe finished.
  11. alchemy
    alchemy
  12. DDDenny
    Looks like that's had a lot of rolling over use!
    Stogy likes this.
  13. LM14
    LM14
    from Iowa
    Little bit of progress today. Finished up the left quarter to the trunk lid and below the belt line. That’s all been worked with 120 grit, filler as needed then had a round of 320 paper on it and my final coat of fill primer. Will still need work across the door openings so no need to go any further until the body is bolted back down on the frame. If it’s gray it’s basically done!
    Tomorrow (or tonight if I don’t sleep again) I start on the right quarter.
    SPark
    A6717A90-3E8D-4AA1-B093-540C1D7BD6B6.jpeg 6095B397-E395-4F24-B157-4280EF92DE29.jpeg E5715F40-6EAC-4AC7-A747-5550CE21101B.jpeg 7ABFB88B-D105-4ECE-844D-49B4FB96D3B5.jpeg 1DB72571-9B9E-4A1A-A374-F91D28E099F1.jpeg 8A6C2B7E-A889-403F-A55C-98D65B231269.jpeg 419914C9-CAA3-4734-A268-CF48DA353E16.jpeg
    brEad, Tim_with_a_T, Blue One and 3 others like this.
  14. LM14
    LM14
    from Iowa
    Another sleepless night but we made more progress so it’s all good. Right quarter sanded, filled, repeat. Came out great. Back to the cowl top now.
    SPark
    4158841E-82CE-456C-8E3E-1D17091B2520.jpeg 6143E010-AE03-48CF-9C03-8AF1E93A4396.jpeg 0DCA47FE-EB27-442E-A53E-D5DB38B22DB4.jpeg CCDD1010-3177-4FF4-B010-1E310096122D.jpeg D625BB3D-5742-43D1-B9F2-802E2C7BB1CC.jpeg 7A42CBBC-6EAF-4AF3-A87B-48C839BDE210.jpeg DE8C28B2-112B-4288-9DC0-8569E6B65CE5.jpeg E4D8F96F-3ADF-4C32-AE99-D586C065FD7C.jpeg 5A27CB32-C094-4197-B237-AC12C15C9C61.jpeg F7C6853F-29EA-4D58-8F67-DBEE6C12D742.jpeg 022D49D1-A722-40F6-B5A3-D23964F8DA13.jpeg
  15. Steve, you're doing an awesome job. Keep doing what you can, when you can. I mentioned my buddy Mark to you before; he's just started a second trial yesterday, but other than getting winded quickly, he(with some help from me) just keeps plugging along. You guys are inspiring!
    Stogy and loudbang like this.
  16. loudbang
    Man you get more done than most folks. :)
    brEad and Stogy like this.
  17. LM14
    LM14
    from Iowa
    Cowl vent day! Figured there was no more putting it off. Back to work on the cowl vent.
    Masked around the actual vent to cut down on the area that could get mud on it and saved a lot of sanding (shared some of these pics in the thread on the "bodywork, getting a panel straight" thread so might see some twice). Also cut out the gap between the vent and cowl while the putty was still pliable. Saves a LOT of sanding. Things learned thru the years when you can remember to use them!
    Worked the whole area where the gasket sits down inside the cowl and the vent seals when closed. Not a great place to sand, no room and most of it will never bee seen again. Had to be done! One of the areas I had been dreading is done! I have photographic proof if anyone asks if I really worked that area!
    Got the entire cowl top sanded and ready for primer. Still a bit of mud work to do in a few small areas but the majority of it is done. Grandkids both have soccer games tonight so this is pretty much it for the day!
    Tomorrow the vent and cowl gets finished and guess I'll have to start detail work on the bottom of the floor pan again.
    SPark
    cowlvent8.jpg cowlvent9.png cowlvent10.png cowlvent11.png cowlvent12.png cowlvent13.png cowlvent14.png cowlvent15.png cowlvent16.png cowlvent17.png cowlvent18.png cowlvent19.png cowlvent20.png cowlvent21.png cowlvent22.png cowlvent23.png cowlvent26.png cowlvent27.png cowlvent29.png cowlvent30.png cowlvent31.png cowlvent32.png cowlvent33.png
  18. LM14
    LM14
    from Iowa
    You know the drill. Why waste time sleeping when there is sanding to be done? This pretty well finishes the cowl. Need to bolt it all back together and make sure everything lines up still. Need to let it sit for the day and dry.
    SPark
    C2D22AC8-6D07-467B-BD55-0559B77329C4.jpeg 955FE05D-8402-418B-BF15-864D8CAEA6E0.jpeg 2F124D33-773D-4931-B2AE-D77898680D80.jpeg 1AFF03B6-FD32-499E-A869-D3B982EF04A1.jpeg 8B350D01-B6C8-48ED-A348-666B5FAF1243.jpeg 7D41455D-B265-41D9-B0F2-98E099487791.jpeg 57646DE5-FF8D-49F9-B267-E5BBEED54CFF.jpeg 4D49C53B-9519-4490-9509-A79081D2CB8E.jpeg ACB18828-70ED-4ED4-BC00-386B027905F7.jpeg 594228A6-5A2B-428D-B971-7821D2FA54A3.jpeg A30D9878-A2B8-45DC-8556-FAD9AF78AC86.jpeg 53647D26-610C-4802-9CD8-28DE35930A40.jpeg 50B3A1C2-CD59-4615-953F-3BB64D9A1804.jpeg
    brEad, Shadow Creek and loudbang like this.
  19. swifty
    swifty
    Have you got a cowl vent gasket? I used a Bob Drake one and the vent sat about 1/8" above the cowl line. Ended up cutting one out of thinner rubber to solve the problem. Have heard that Vintique ones don't fit the hole properly also.
  20. alchemy
    alchemy
    I was thinking the same thing. On the one I put together (steel body) the gasket made it sit 1/8" high. Probably could have sanded down the gasket, but I didn't. I will on the next one.
  21. LM14
    LM14
    from Iowa
    Mine came with the correct gasket to fit the New Age Motorsports opening. Think it's a Vintique. Worked fine with the UP steel vent cover I switched to (after I slotted a few holes and made that little shim for the mounting surface). It's been in place all the time I've worked the fit and finish on the cowl vent. I covered it with thin, cheap masking tape so it wouldn't get mudded in. I'm also adjusted all the way up so I know it won't get any higher, can only go lower.
    I pronounce this cowl vent lid and top of cowl project done (for now). Very happy with the finish (it had the gasket laying under it in these photos but not glued in yet). That's pretty much everything I can do below the belt line. Now we have to get the body back on the frame when it's done in paint. Going to do a little preliminary work in the door jambs where the molds come together and left small imperfections and scuff the trunk jamb but I'm about to the point I need the body on the frame to finish door gaps. Have a couple days work under the floor to finish, too. Hopefully the frame is painted by the time I'm done with those items.
    SPark
    cowlvent36.jpg cowlvent37.jpg cowlvent38.jpg cowlvent39.jpg cowlvent40.jpg cowlvent41.jpg cowlvent42.jpg cowlvent43.jpg
  22. HOTRODPRIMER
    HOTRODPRIMER
    Your getting there!, go man go! HRP
    Blue One likes this.
  23. pprather
    pprather
    That body has better finish prep than anything Henry built back in the day.
    Phil
    Nicholas Coe and loudbang like this.
  24. LM14
    LM14
    from Iowa
    Spent the balance of the day working on the trunk rain gutter area, quarter windows and started cleaning up the door jambs. Almost no flat surface except the tiny steps in the door jambs. Lots of weird sanding blocks today.
    Have a good friend with 6 or 7 Chitwood Thrill Show cars. They’ve put on a few shows with some of Chitwood’s original drivers. Harley Davidson caught wind of it and contacted him. They wanted one of the cars for their thrills and racing display they are doing this fall. They sent a truck to haul the car to Milwaukee. Just happened to stop by his shop as they were loading the car today. Trailer already had a “Sphere of Death” and 2 of the motorcycles they ride inside the steel ball, already loaded. Off topic but kind of strange and fun way to spend an hour today.
    SPark
    22CCF60E-908C-47BB-8BE4-B832A8A1DB19.jpeg EFAD3E8A-5AFC-4C93-B47F-BC33DCE4D6ED.jpeg 6AEE6F05-A827-47E7-9C96-14C568A4BBE5.jpeg 7D05A357-C256-42C1-B3F4-9C39C847EF50.jpeg D3764CED-76A1-40DF-9CE4-846567C6803D.jpeg BA1B141C-0954-40D7-A4E0-70F1D5DC7D13.jpeg B9BCA303-F2B4-450E-9C8D-6A1287055E72.jpeg 398D8D54-710D-4460-8B85-80B8BBAA908C.jpeg 74FB5565-4517-4847-BC1C-D16285818E66.jpeg 726F7ADE-01D1-4F33-9838-FA45C6DFC7BF.jpeg 85A73427-4B0A-4AD7-9AE0-C23E008E7D42.jpeg 1487CF4F-C7D0-4537-AF8E-4C047C81FFC8.jpeg 79EC901C-A58B-4A73-85ED-3DCD5D0C71AB.jpeg 614EF73A-2375-41E2-BC70-D6875E219FE1.jpeg F10DC8C5-9ECD-42C4-9FF4-20C85A8D22A8.jpeg 421A6179-C232-48CC-82CE-EABF9ACBDE03.jpeg 85C57B37-2D39-40C8-A583-A299C1554E5D.jpeg E5E9CF63-7253-4A01-A706-9DD50CC87D30.jpeg 5840D76C-D3D3-489E-AFB1-F822C1A589CE.jpeg A4E82D31-5017-438B-90DE-CE1804D8DCA5.jpeg 113E03F8-48D8-4A11-A38E-B924D0F236AA.jpeg
  25. loudbang
    That's very cool. Chitwood's was the only stunt type show I saw live must have been 45 years ago.
    Stogy likes this.
  26. LM14
    LM14
    from Iowa
    Finished the left quarter window area and door jamb about half done.
    Looking at the trunk rain gutter. It’s just ugly. Thick, thin, up, down....just ugly. Break out the DA later and see if I can make myself itch. The gutter itself is great. Will take very little to finish it. The side exposed to the inside of the trunk is where it’s nasty.
    SPark
    A5A2C1F5-5E9A-4E9A-A754-FAB56E1DD82C.jpeg D229103F-B886-4928-BF47-217674B98FCC.jpeg 68C75507-21F3-4AB9-AE68-9B9CA3DCD300.jpeg 23AFD6E0-C509-487A-8665-8F7D9DAFCB01.jpeg 011F5296-17BF-45F3-AEE7-B7DF2765FA73.jpeg BABBFBBD-DFFE-4757-9F87-97C77675EF83.jpeg
  27. LM14
    LM14
    from Iowa
    Broke out the DA this afternoon. Had to improve the trunk side of that rain gutter. Got rid of a big glob of fibergl*** in one area on each side then generally shaped the whole thing. Made a spreader that fit the final shape I’m after and laid on a couple layers of kitty hair to build up the really low areas. Then my first layer of mud. Starting to look much better. Tomorrow we’ll try to get it finished.
    SPark
    6DAA3435-6885-42B2-A8BB-0716A086F940.jpeg D75D8F7A-2D72-481B-B3AA-F0AF4454A78A.jpeg FBB01BFE-DC52-4758-8B97-F623576B1F9E.jpeg D235CBBD-54EE-4779-80C2-5DB8FD8EE876.jpeg 21FED4BD-434E-49B3-A58A-E38349A2A930.jpeg 7B6E1F7C-E700-4215-A9D4-5E4590F5B1E4.jpeg 528B5D5F-FF4D-4955-9165-83435C05B860.jpeg 7E449BA5-1A83-408B-BDF8-B1ECF84D8B9E.jpeg DC6A22A7-F075-4018-84CC-F6FD4B4B7818.jpeg 250BAEE2-B6CC-4D5E-9FA9-9E4856062A8C.jpeg 322185C9-70AC-4A72-84EB-49D6D0ECFB2D.jpeg 307208EF-AB3B-43DD-ABA3-FDFC1D989A2D.jpeg B904F671-DC18-4B2E-A2DC-EDF896361CAA.jpeg 03CEB34C-F0C7-42AF-B18B-3852BC72E8AB.jpeg 6C5901AA-2A82-4CE8-8834-35CD995D428D.jpeg 3B55339D-DC99-449A-9660-C0AA5F3EB1C5.jpeg 402B33B2-9175-4C83-A2D2-483DC6A77A83.jpeg
  28. LM14
    LM14
    from Iowa
    More work on the rain gutters tonight. Think I’m about down to a couple very small low areas and glaze. 1000% improvement. Pretty uniform roll on the bottom edge all the way around and consistent crown and thickness.
    Also knocked out a bit more door jamb cleanup.
    Shooting for finishing the door jambs and rain gutter in the trunk tomorrow.
    SPark
    3FD1672D-428F-4D02-9800-1708F82F0DED.jpeg 5677E181-87B9-476F-BD69-19F433BCAFA7.jpeg 9C05D5A5-DFA2-4822-8BC3-3A519D3B1936.jpeg B7A41E82-6E40-4795-812E-5412BB73B88B.jpeg 1858A160-A940-4825-B3D3-167006129528.jpeg 9DF5F798-68A4-4FE7-B3F6-2255172C04A9.jpeg 3104AB3E-3F5C-4F07-A4ED-DC3FB1A41486.jpeg 678DAB77-D1A2-471E-BFF6-627214A7EF0F.jpeg 9410DC2D-CDA3-415F-AE4A-FA18CB962079.jpeg 3B41B375-253F-4CA8-921C-3ACBEF8F7250.jpeg C3B7CA38-E43C-4587-A37C-1C8EFEE9C0AE.jpeg B348BFDD-FCD2-44B1-ACA3-F2A20C133BAB.jpeg
  29. Stogy
    Stogy
    @LM14 I'll bet your Kitty is glad your almost done with the hair applications...:D. Your attention to detail is beyond admirable...and very well done...very much enjoying your build...;)
  30. LM14
    LM14
    from Iowa
    Thanks!
    We're lucky we have 3 cats, 2 indoors and 1 outdoor/indoor/shop/resident ******in. They are all shedding so it's a good time to be doing this. :)
    We're only doing this once, better get it right. This is why I usually drive my stuff in primer, I'm too picky for body work. I can do it but I can't quit until I'm to the point of being able to walk away and not have regrets.
    Glad you enjoy the build, it's been a lot of fun and very satisfying so far.
    SPark
    Super Syd the Wonder Cat!
    Monster MeMe, sneaky cat that hides from everyone.
    Crazy Ethyl the ******in. (Notice the dead bunny by the door, she kills anything that moves and eats it). IMG_2186.JPG
    Crazy Ethyl in my shop chair. If she gets there first I stand….. IMG_1811.JPG
    brEad, loudbang and Stogy like this.
