Projects 31 Chevy 5 Window Coupe
Discussion in 'Traditional Hot Rods' started by Fast Eddie 27, Nov 5, 2018.
  1. mlagusis
    mlagusis
    Dude, nice engine choice. I have a 283 for my 31 Chevy sedan with a 3 speed over drive. Should be plenty of power for what you are doing. I would follow the marvel oil suggestion by Mike and try to run it as is. Nice score!
  2. mlagusis
    mlagusis
    oh, and the rectangle with the triangle in the middle casting mark identify those are power pack heads.
  3. Fast Eddie 27
    Fast Eddie 27
    Good call....I’ll get into it soon and report back.
    Tooth, Dyce, loudbang and 1 other person like this.
  4. Fast Eddie 27
    Fast Eddie 27
    Yes I’m stoked on the look of these heads but also wanting this to be a snappy little power plant with good throttle response. I plan on running a Muncie behind it and low gears.
    Tooth and loudbang like this.
  5. Fast Eddie 27
    Fast Eddie 27
    Managed to get a shot of the progress of the wood removal and all the temporary bracing going in. You can see the new floor sills starting to take shape tho.
    Have at me. I feel like I’m starting to get on the right track. From the new sub rails I’ll go straight up and work from there is what I’m thinking. This is certainly a head scratcher! The car will be channeled 5-7”
    Ps anyone else have/solve the problem of only being able to post one pic on the app? [​IMG]
    Tooth, loudbang, TFoch and 1 other person like this.
  6. Fast Eddie 27
    Fast Eddie 27
  7. Fast Eddie 27
    Fast Eddie 27
    Tooth, loudbang, tb33anda3rd and 2 others like this.
  8. thirtytwo
    thirtytwo
    I built subrails that mounted to the frame first then built out to body subrails mounting the cowl rockers and quarters then filled the center of the floor last, I wouldn’t go more than 5” channel , make the rest of your ride height with suspension mods
    Fast Eddie 27 and loudbang like this.
  9. Just settled in my new home in Mesa, Arizona. How's your build coming along? I should be hanging with 'ya soon enough, sharing the street with identical hot rods done in different styles...
    Tooth, TFoch and loudbang like this.
  10. Fast Eddie 27
    Fast Eddie 27
    Oh cool Mike. Been chugging along. Got my kick up done for the 4 link in the rear
    Tooth, 31chevymike, nunattax and 2 others like this.
  11. Fast Eddie 27
    Fast Eddie 27
    I ended up really liking the shape the rails took. Wasn’t sure at first, but it’s growing on me. Any thoughts?
    Parallel bars are pre mades from eBay but should suit my build proper. I intend on driving this car hard.
    Tooth, nunattax, Stogy and 3 others like this.
  12. mlagusis
    mlagusis
    Looks like you channeled that body a lot. I remember you saying earlier in the thread you want it low. Did the body and cowl fit over the frame? I am going to channel my sedan 2"-3" but have not checked to see if the cowl will drop over the frame.
    My two cents...I would add a plate at the top weld in the inside and outside of the frame rail. I will also add a gusset at the bot horiz to vert joint. I ***ume you are using coil overs attaching to a cross member at the upper part of the frame. If so, you will have bending forces at the vert to hoirz joint so beef that up a little. I added a sketch to go with my comments.
    Over all looks like you are building what you want which is great.
  13. Very nice work Eddie! I agree with Matt on the additional bracing, although the frame looks very stout, it can't hurt to look into it.
    Mine is resting in a very tight 10x15 space at Public Storage because there was NOT an available garage at my new community. But, they just called me yesterday and told me they HAVE a garage directly in front of my apartment, looking like a 10x20. The wheels broke on one side of my hemi engine dollie with the move, so I need to fix this ASAP before the end of this month, moving my hot rod and equipment on the 26th of this month!
  14. Fast Eddie 27
    Fast Eddie 27
    Yes it’s definitely giving me the freedom to go as low as I’d like. Although it keeps getting a little higher and higher as time goes by in my head. Who knows. Once I get some rubber and wheels I’ll play with the ride Height a bit.
    Yeah it did fit right over. Some slight manipulation, but it makes it over the rails very snugly and nice. As far as the joints I 100% agree. I had originally thought to put in a cross member there at the top inner horz to vert joint but now I’m thinking plates. The outers already have plates and the joint (can’t see in pic)
    Great sketch by the way! That makes it too easy ...
    I
  15. Fast Eddie 27
    Fast Eddie 27
    Ended up with a one piece setup that I’ll later cut and weld in a driveline hoop once motor and trans is set. [​IMG]
    brEad, rtomss, 31chevymike and 2 others like this.
  16. Fast Eddie 27
    Fast Eddie 27
    My next hurdles are panhard placement and coil over angles. Feeling like I’m just going to Widdle a bracket coming off the top of the housing. How much clearance am I looking for at the pumpkin to bottom of panhard bar? [​IMG]
    31chevymike, TFoch and loudbang like this.
  17. nunattax
    nunattax
    id go with a z snaped reinforcement inside the frame,with a few 1 1/2" holes weld the perimeter and around the holes
  18. mlagusis
    mlagusis
    It's funny how things evolve along the way. For ride hieght, I did not buy tires yet as I want to buy them a little closer to when I will drive it. At this point, I do not see the need to spend $750 to have tires sit for two years. I do know the tire size I am running. So I took the measurements from the bottom of rim to bottom of tires and used 2x4's as blocks to set the rims on so I can get an idea for how everything would layout. So far this has worked out pretty good. I have the rear suspension figured out and all the fab work done. I am just starting the front suspension but have it all figured out. After I get the front end done, I will drop the body on and rebuild all the structure inside the body.
    You are making good progress and it looks like its coming together.
  19. Fast Eddie 27
    Fast Eddie 27
    Thanks! I agree as well with the bracing, as I mentioned, I originally intended on placing a cross member there, but now It'll get some reinforcing..I like the hole idea!
    31chevymike and loudbang like this.
  20. Fast Eddie 27
    Fast Eddie 27
    Thank you Matt..as far as the rubber I have a couple tires that will get me close so I can get my eyeballs on it sooner than later. I need literally everything up front other than my 32 crossmember.
  21. Fast Eddie 27
    Fast Eddie 27
    Rear end is as close as it’s gonna get. Checked pinion angle and square about a hundred times. Re adjusted and fit till the cows came home. I think it’s solid back there.
    Tooth, brEad, tb33anda3rd and 3 others like this.
  22. Fast Eddie 27
    Fast Eddie 27
    Tacked in the first draft of motor mounts. I’m thinking they need a little more beef. I was going for simple, still need to round the edges on the plate. IMG_2452.JPG
    tb33anda3rd, loudbang and 31chevymike like this.
  23. Well done Eddie - looking really sharp!
  24. mlagusis
    mlagusis
    Any updates on your build?
  25. TailDrag
    TailDrag
